Ironforger
- Joined
- Feb 18, 2003
- Location
- Lawrenceville, NJ.
I had some body work done on my NB TDI recently. Took the opportunity to snap these cool pictures and also do surgery on my air intake. By accident I discovered the root cause for a MAF issue that I've been experiencing during rain. The MAF would throw all kind of errors when driving in rain, and the car would run like crap. Turns out the air pipe was assembled wrong next to the tire, like someone squashed it together without making sure the rubber gasket was seated properly. If you look close (see 3rd picture below) you will notice the rubber gasket distorted since it was seated wrong for so long. This caused water to enter the intake system as this connector gets water spray and splash off the tire. Whenever the poor running issue occurred during rain, my air filter element would be damp. Thus water would also get on the maf. Issue has not occurred since I fixed it.
Yea boy! Mystery solved.
Also removed snow screen while I had it apart. (See last picture).
