Old July 5th, 2006, 19:19   #1
bam_bam_dip
bam_bam_dip's Avatar
Fuel Economy: 51.3, 700 Club
Exclamation Help with a few fault codes, pleeze.
VAG-COM Version: Release 409.1-US
Control Module Part Number: 038 906 018 EB
Component and/or Version: 1,9l R4 EDC G000SG 2143
Software Coding: 00002
Work Shop Code: WSC 00066
5 Faults Found:
01282 - Intake Manifold Flap change-over Valve (N239)
31-10 - Open or Short to Ground - Intermittent
17957 - Shareware Version. To Decode all DTCs
P1549 - 35-10 - Please Register/Activate - Intermittent
17849 - Shareware Version. To Decode all DTCs
P1441 - 35-10 - Please Register/Activate - Intermittent
17660 - Cold Start Injector (N108) Open or Short to Ground
P1252 - 35-10 - - - Intermittent
17552 - Shareware Version. To Decode all DTCs
P1144 - 35-00 - Please Register/Activate
Forgive me for the shareware version..........
Want a good read? Me & my Red Rider Against the Squirrels!!
My Father's house is a big, big house.
bam_bam_dip is offline   Reply With Quote
Old July 5th, 2006, 19:49   #2
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 56.3/44/41
P1549
Boost Pressure Contr.Valve Short to Ground
17849
P1441
EGR Valve Circ Open/Short to Ground
17552
P1144
Mass or Volume Air Flow Circ Open/Short to Ground
-Jason
Present:
2012 Passat SE TDI DSG. 24,000 miles. Factory Alarm & LED tails 38/48 MPG.
99.5 Jetta "GLX" TDI. 289,000 miles. Half way there!!! Power Memory Seats, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 222,222 miles, 70,000 on engine. 18/27 MPG.
Past:
1988 Audi 5000S, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Old July 5th, 2006, 20:03   #3
MOGolf
MOGolf's Avatar
Blow a fuse? Check fuse 34.
MOGolf is offline   Reply With Quote
Old July 5th, 2006, 20:09   #4
bam_bam_dip
ok, where do I start?????
all fuses good.
Old July 5th, 2006, 20:13   #5
whitedog
TDI Scholar
Fuel Economy: 42 Jetta, 47 Beetle
I'm going to sound redudant here, but the search works fairly well for fault codes. Just do one at a time and plug in a code and see what others have come up with.
You could also plug in all of them separated by - and - then click the boolean button and see if they all come up in the same post.
Or check fuse 34.
whitedog is online now   Reply With Quote
Old July 5th, 2006, 20:20   #6
bam_bam_dip
thanks for the redundancy...........
not exactly looking for a translation, but a cure!!
i.e. I searched the codes......basically they all come back to
...yada, yada, yada...short to ground
Old July 5th, 2006, 20:29   #7
whitedog
TDI Scholar
Often the cure has been found before and a little research will reveal what others have found.
Old July 5th, 2006, 20:36   #8
bam_bam_dip
or you could just go to http://tdiclub.com/chat/ ..........jason, eric, and cincy_mike, et al were most helpful.
Old July 5th, 2006, 20:37   #9
whitedog
TDI Scholar
And what happens the next time when you have a code and no one is around?
Old July 5th, 2006, 20:40   #10
bam_bam_dip
Your joking right...........some people around here never sleep.
DUH, search fer it on my own, boss?
or
Go to bed and axe agin in the mornin'..........
Old July 6th, 2006, 06:27   #11
bam_bam_dip
Update
Yesterday, while intalling an amp in the trunk, I was having some power supply issues. As a rule of thumb, I always double check fuses and grounds first for electrical problems. All fuses, and I mean all, were operational. My problem was a intermittant grounding problem. Remedied that, then started having issues with CEL's above. I figured that with 1 grounding problem, might be another. Wrong.
MOGolf and Whitedog were right on the money with fuse #34. I went to double check fuses this morning, there wasn't a fuse in slot #34. I had accidentally moved it when checking all the other fuses last night.
OOPS!!!
Replaced the fuse, cleared the CEL's, and re-scanned. All is well with the bam bam mobile.
Thanks again for the quick and accurate troubleshooting last night.
Tim
Old July 6th, 2006, 06:29   #12
bam_bam_dip
I don't believe searching for "being a dumbass" would have returned the proper results. i.e. replacing a fuse into the wrong slot.
Old July 6th, 2006, 12:33   #13
whitedog
TDI Scholar
Just a note... My suggestion of fuse 34 was just an echo of MoGolf. He deserves full credit for it.
But since we are talking about fuse 34 and your question is answered, maybe a bit of discussion on this important fuse would be helpful for folks like me. I'll look it up tonight on Bently and try to get my mind around the wiring "diagram" to see what it does.
Page generated in 0.17147 seconds with 9 queries
[Output: 116.18 Kb. compressed to 96.87 Kb. by saving 19.31 Kb. (16.62%)]
