wjdell
I have a 06 Jetta with DSG and purchased the Ebahn manual. I am looking around and getting to know the car and decided to look at the trans oil change.
Under the section
Transmission oil and filter for Direct Shift
Tansmission oil and filter, changing - the last drawing shows the bottom view of transmission.
A - is the drain plug
B - is the called the check plug
Well I have looked and - DRAIN PLUG A DOES NOT EXIST
Check plug B is there just like the drawing shows and there is place in the housing for A but it was never installed -
If anyone knows anything about this please fill me in - maybe it was moved - maybe its to be tapped on first change.
Oh and get this when I called my VW dealer the parts man said we do not give out part numbers.
My trans is code HQN - July 2005 - Austria
Under the section
