frugality
My rear window regulator just recently developed a problem. There's some sort of 'disconnect' between the glass and the motor. When the problem first happened, the window was partway down and the motor ran a bit before something 'catched', and then finally started pushing the window up. The window hasn't dropped. I didn't play around with it too much since it's now in the 'up' position, and wanted to leave it there since it's rained off and on lately.
I did some searching and found that the problem is often a $1.25 pin that holds the glass carrier to the mechanism, so I've picked up a couple of those in advance, and have door trim clips since those often break. And I have a Metalnerd 8mm triple square bit for the latch, since I've seen the front door .pdf how-to and expect the rear is similar.
Does anyone have any advice before I start tearing in? I don't know if the glass should be 'up' or 'down' before I start pulling out the module that has all the inner workings of the door, or how to disconnect the regulator from the window carrier (if it's still connected).
Thanks in advance.
Thanks in advance.
