Old June 25th, 2006, 15:57   #1
BryanP
Default Memory seat not working
We picked the new car up last week. The sellperson told us the menory seat are not working, and that they did not do the proper input during the PDI.
Is there anyway I can do this.
I am 6'4" and my wife is 5'6"
The powered seat work, just you can not progam the memory into one of the three settings.
Bryan P
2006 Jetta TDI with DGS
Platinum grey/ Anthracite leather
Premium Luxury Leather Package
BryanP is offline   Reply With Quote
Old June 25th, 2006, 16:08   #2
DRbillZ
DRbillZ's Avatar
Fuel Economy: NB-usual:41-42 max:47; Jetta:usual: 44highway
Here's how to turn the memory seat on:
1) Pull the seat all the way forward
2) Tilt the seat all the way forward
3) Tilt the seatback all the way forward
It still amazes me that VW dealers don't know how to do this.
-2000 New Beetle TDI GLS. 154,000 miles. TOTALED
-2005 Passat TDI. Stonhenge grey,TOTALED!
-2006 Jetta TDI Platinum grey, 126,000 miles
-2002 2.0L gasser Jetta 125,000
-2012 Jetta Sportwagen TDI 13,800 miles DSG
DRbillZ is offline   Reply With Quote
Old June 25th, 2006, 16:31   #3
BryanP
Thanks DRbillZ
I now have my memory seats working
Bryan P
Old June 25th, 2006, 17:01   #4
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
About once a month, I see one of these "Memory seats not working - damn dealer - cram the seat fully forward" threads.
That's about 4 of them so far since I joined TDiclub.com, including the one I posted...
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old June 25th, 2006, 17:13   #5
BryanP
Default one more seat memory question
I pulled the seat all the way forward
I tlted the seat all the way forward
I tilted the seatback all the way forward
The memory is working except the up and down part of the memory is not.
Did I do something wrong?
Bryan P
Old June 25th, 2006, 18:16   #6
DRbillZ
DRbillZ's Avatar
YOu have to hold the memory position button down until you reach the position you set. If you let up until you reach it the seat wil stop where it is at that moment.
Old June 25th, 2006, 19:43   #7
BryanP
Default memory seat still not working
Hi DRbillZ
I hold the preset button till it stop, but it will not return to the up or down position that I have it set at
Bryan P
Old June 26th, 2006, 08:53   #8
DRbillZ
DRbillZ's Avatar
Try putting the seat all the way down and repeat the "turn on" procedure (??)
Old June 26th, 2006, 12:41   #9
HEMIHD
HEMIHD's Avatar
Fuel Economy: Still on my first tank
Why would this be a dealer problem. If the memory function is installed as part of the package in the factory, shouldn't it also be turned on there? I can't think of a reason that shipping would require this funtion to be disabled.
2006 Jetta PD TDI.
2003 RAM 2500 HEMI QC 4wd, 0-60 in 3 gallons
HEMIHD is offline   Reply With Quote
Old June 26th, 2006, 13:05   #10
DRbillZ
DRbillZ's Avatar
It's part of the dealer prep.
Old June 26th, 2006, 22:28   #11
BryanP
Default Off to see the dealer
The seat is still not rembering the up and down position, so I am off to see the dealer on Sat.
Bryan P
Old August 18th, 2006, 11:36   #12
Jeff Whip
Talking
Just wanted to say thanks for the info. I picked up my 2006 Jetta TDI pkg 2 two weeks ago and have not been able to figure out how to get the memory seats to work. Now they work fine. Dealer forgot to turn them on. Is there any way to get the mirrors to work in conjunction with the seats?
Jeff Whip is offline   Reply With Quote
Old August 18th, 2006, 11:49   #13
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
All the newer Volkswagens, even my '04 Passat, come from the factory in "sleep mode". The CAN is dormant, as are many other functions, and they need to be turned on. This is done primarily to prevent battery drainage until the car is sold and [presumably] in daily use.
The VAG-COM will allow you to put the car back to sleep, which is something I would recommend if you know the car is not going to be driven for over a month or so.
The seat controller has adaptive learning, just like most anything else on the car, and once it is awake, it needs to know where the ends of its positions are. Otherwise the memory will not work. The auto up/down functions on the windows, sunroof, and even some other things need to be enabled during PDI too. This is common, most manufacturers are like this, it isn't just Volkswagen. Just so happens that many techs are too lazy or too dumb to go through the PDI procedure and be sure and get everything working the way it is supposed to. And also, the salesperson is supposed to go over all of those features at delivery, to triple check to make sure everything is working as designed.
Some other things that sometimes do not get checked: spare tire pressure (all 5 tires are overinflated and need to be adjusted, the spare often gets skipped), proper test drive (for Volkswagen I think it is 2 miles), moveable headlight initialization and aim check, washer fluid top-off, DTC memory check/purge, damage to undercarriage (from sloppy transports), and making sure the radio station presets are at least set to some stations and working normally.
oilhammer
www.cardocautomotive.com
Old August 18th, 2006, 19:30   #14
Tim Birney
Tim Birney's Avatar
TDI(s): 05.5 TDI
It relates to "Read the Owner's Manual"
05.5 MKV TDI,Euro Tails, Rear Fog, Aspherical Mirrors-04.5 PASSAT TDI, Aspherical Mirrors
Tim Birney is offline   Reply With Quote
Old August 19th, 2006, 04:37   #15
tkbalt
tkbalt's Avatar
Thanks - just picked up our Jetta this week and could not figure out why this did not function. Saved me a call to the dealer - thanks
Black 2011 Golf TDI - DSG
Opera Red / Black leather 2013 Passat SEL TDI - DSG
tkbalt is offline   Reply With Quote
Page generated in 0.14202 seconds with 9 queries
[Output: 121.75 Kb. compressed to 100.08 Kb. by saving 21.68 Kb. (17.81%)]
