Old December 3rd, 2012, 19:34   #61
danielhf
danielhf's Avatar
Fuel Economy: 32/42/49
Just posted another swap for you
http://forums.tdiclub.com/showthread.php?t=370877
04 .:R TDI - Conversion Thread 246 AWHP 343 AWTQ
PD150 w/4motion TDI 02M & LSD, TD Tuning Full Race Tune, GTB2260VK, Darkside stainless tubular exhaust manifold & downpipe, R783 nozzles, Colt Stg. II cam, and lots more...
02 Reflex Silver Golf Variant TDI - TOTALLED!
danielhf is offline   Reply With Quote
Old December 15th, 2012, 16:09   #62
akafred
what i did was take the diagram and start tracing wires removing unnecessary wires labeling all others, once you have that done its really easy to hook up.
also i wasted a few hours before i decided to just cut all the splices on the body side of the harness.. this was a real time saver as you have to redo 90% of these due to unnecessary body stuff.
also why isn't my jeep on this list.. it was quite the success..
akafred is offline   Reply With Quote
Old December 15th, 2012, 17:55   #63
jimbote
jimbote's Avatar
http://www.popular-pics.com/PPImages...resolution.jpg
Old December 15th, 2012, 23:36   #64
archemitis
archemitis's Avatar
funny
archemitis is offline   Reply With Quote
Old December 23rd, 2012, 05:21   #65
G60ING
G60ING's Avatar
Please help me out I'm adding build threads to the list this week. If there are missing builds please post the links up here or PM them to me.
I like to add threads that are fairly close to being finished or ones that have a lot of knowledge in them.
I like to start with the builder's screen name, the major details (car and engine) and then the link. Help in compiling the thread list will be greatly appreciated. It takes hours to do on my own.
So far I think I have finished updating the Corrado and Audi links.
G60ING is offline   Reply With Quote
Old December 23rd, 2012, 07:50   #66
greengeeker
greengeeker's Avatar
Fuel Economy: 42.2/50.0/58.1
greengeeker's ALH Ford Ranger Build : http://forums.tdiclub.com/showthread.php?t=359848
- Nick -
02 Jetta TDI 308k (42.2/50.3/59.4 MPG) // 01 Eurovan 24V (18 MPG) // 00 TDI Ranger (39MPG)
How to Post Pics - How to Search
TDIclub trusted mechanic in Minnesota - PM me
greengeeker is offline   Reply With Quote
Old December 23rd, 2012, 08:03   #67
G60ING
G60ING's Avatar
Its in, perfect format. Thanks
Old December 23rd, 2012, 08:04   #68
G60ING
G60ING's Avatar
Many more additions are out there
Old December 25th, 2012, 08:41   #69
bzeien
bzeien's Avatar
I'm building/converting a MKIV TDI Jetta (PD) into a Smyth Performance G3F; It's in the TDI Conversions forum, but I'm not sure if it qualifies for your list.
A fun build though!
http://forums.tdiclub.com/showthread.php?t=367314
bzeien is offline   Reply With Quote
Old January 14th, 2013, 19:29   #70
Andi-Ina
TDI(s): 1.9TDI BEW
Default Q7 gas to 3.0 tdi?????????????
Has somebody done a conversion like that?
a tdi is approx 20000$ more in canada (both used)
Andi-Ina is offline   Reply With Quote
Old March 8th, 2013, 05:15   #71
G60ING
G60ING's Avatar
3114's samurai swap has been added, I love the work. I'm on the road right now so the link I added is a little crude but I'll clean it up later. If you see any other builds I should add please let me know.
Old May 29th, 2013, 07:04   #72
greentdiconvertible
I just added another one for you. http://forums.tdiclub.com/showthread.php?t=386187
greentdiconvertible is offline   Reply With Quote
Old August 14th, 2013, 00:00   #73
jabcok20
TDI(s): golf mk1
Anybody know link to r5 TDI swap into golf especially golf mk1 or other vw( mk2, mk3, mk4). I think about r5 like AAT AEL and other like from T4.
jabcok20 is offline   Reply With Quote
Old August 14th, 2013, 11:01   #74
Danielg42
Danielg42's Avatar
http://forums.tdiclub.com/showthread.php?t=214626
should be the link to the
Volvo 1966 122S Swap: instead of frankendiesel's minivan http://forums.tdiclub.com/showthread.php?t=210943
Danielg42 is offline   Reply With Quote
Old August 25th, 2013, 06:22   #75
baja_brewer
Took me forever to track this down after I saw it once - maybe you have it linked in the OP but I couldn't find it.
Pin map (pin mapping, pinout) for 68 Pin AHU or 1Z ECU:
1998 Jetta
AHU ECU Pin Out
Pin# Colour Function
1 Brown Ground
2 Black/Green Tachometer Signal to Instrument Cluster
3 Not Used
4 Brown/Yellow Quantity Adjuster Pin 6
5 Brown/Yellow Quantity Adjuster Pin 6
6 Black/blue Coolant Glow Plug Relay Single
7 Gray/Green Modulating Piston G149-2
8 White Engine Speed Sensor G28-2
9 Not Used
10 Not Used
11 Blue Needle Lift Sensor G80-2
12 Gray Needle Lift Sensor G80-1
13 Brown/Red Mass Air Flow Sensor Pin 6
14 Blue/Brown Coolant Temperature Sensor G27-1
15 White/Blue Throttle Position Sensor Pin 1
16 Blue/White Oil Pressure .3 Bar F22
17 White/Red Clutch Switch F36-2
18 Yellow/Red ?
19 Red/Green Mass Air Flow Sensor Pin 1
20 White/Yellow Brake Light Switch F47-1
21 Not Used
22 Not Used
23 Black/Yellow Switched B+ from Relay 109 output
24 Brown Ground
25 Brown/White Exhaust Gas Recirculator Valve N18-2
26 Black/Brown Coolant Glow Plug Relay Dual
27 Not Used
28 Brown/Green Air Conditioning Relay
29 Violet/Black Modulating Piston G149-1
30 Green/White Glow Plug Relay J66 Pin 7
31 Blue/Yellow ?
32 Gray ?
33 Brown/Blue Sensor Ground
34 Blue/Gray Cruise Switch E45-2 Resume
35 Red Cruise Switch E45-3 Set
36 Not Used
37 Green/Gray Air Conditioning On (Signal from AC system)
38 Black Ignition from Key switch
39 Red/Black Alternator Load Signal DF Pin 2
40 Not Used
41 Not Used
42 Black/Violet Power Relay J317 (109)
43 Blue/White Vehicle Speed Signal Cluster Pin 7
44 Black/Red Brake Light
45 Black/Yellow Switched B+ from Relay 109 output
46 Brown Ground
47 Red/Blue Wastegate Control Valve N75-2
48 Blue/Green Glow Plug Light
49 Brown/Yellow Quantity Adjuster Pin 6
50 Yellow/Blue Glow Plug Relay Pin 1
51 Brown/Black Cold Start Injector N108-2
52 White/Green Modulating Piston G149-3
53 White/Black Fuel Cutoff N109
54 Not Used
55 Green/Red Throttle Position Sensor Pin 3
56 Not Used
57 Green/Yellow Throttle Position Sensor Pin 2
58 Not Used
59 Blue/Black ?
60 Yellow/White Malfunction Indicator Light
61 Gray/White On Board Diagnostics Connector Pin 7
62 Green/White Throttle Position Sensor Pin 5
63 Yellow/Black Fuel Temperature Sensor G81-1
64 Blue/Yellow Intake Air Temperature Sensor G81-1
65 Green/Blue Throttle Position Sensor Pin 4
66 Black/White Cruise Switch E45-4 On
67 Not Used
68 Black/Yellow Switched B+ from Relay 109 output
Credit Alchemist, download in word file.
baja_brewer is offline   Reply With Quote
Page generated in 0.20720 seconds with 9 queries
[Output: 128.87 Kb. compressed to 108.06 Kb. by saving 20.81 Kb. (16.15%)]
