Old April 4th, 2011, 18:32   #31
justinoconnor
justinoconnor's Avatar
Hmm...
I know I'm not gonna be able to afford it right now, but do you know of any companies that sell entire TDI conversion packages?
New or quality used parts - with the engine, turbo, transmission, etc.. essentially everything needed to convert a 2.0L gas mk3 to a 1.9L TDI.
I live in Connecticut, but I have no problem hopping in the car, and driving a couple thousand miles for a good deal.
From the looks of it - if I want an mk3 specific build, I'm gonna need to save up - cuz even totaled TDI Jetta's are selling for at least 2 grand, and new TDI engines are unjustifiably expensive.
If you know of, or come across any really inexpensive kits/packages - please share!
Realistically, I can't drop much more than $500 at the min. - might be able to up that to a few grand over the next year, and in 2 or 3 yrs - I'll be an Engineer, and buy whatever I want - but, what will VW churn out by then?!...maybe a new R32, with a Touareg TDI, matched to a 6 speed manual...mmm, Lol
justinoconnor is offline   Reply With Quote
Old April 5th, 2011, 12:07   #32
G60ING
G60ING's Avatar
Nobody offers a crate turn key swap in the watercooled world with the exception of www.eurospecsport.com for vanagons. The easiest and best solution would be for you to buy a mk3 Jetta TDi and call it a day. Then swap the drivetrain to the car you want or swap your interior, suspension and wheels to the tdi jetta.
As you said when you graduate you will probably just want something else because lets face it the mk3 jetta is not getting any younger or cooler looking.
G60ING is offline   Reply With Quote
Old April 19th, 2011, 14:47   #33
G60ING
G60ING's Avatar
post your links and I'll add them as time permits. I want this thread to remain current but I need your help. Please make certain your swap has details and some progression from the concept stage before posting.
Please don't hesitate to let me know if something needs to be edited.
Old June 16th, 2011, 14:26   #34
Vinyl_Addict
Vinyl_Addict's Avatar
TDI(s): 00 Jetta
Fuel Economy: 0ooo
curious if a ahu a3 tdi and trans can be swapped into a 90 fox wagon? i have a full 98 donor car but realize the fox is a longitudinal setup and the jetta is transverse. I saw a few threads but people seem to be trying it with diesels that are already longitudinal.
oo Jetta 270K
Vinyl_Addict is offline   Reply With Quote
Old June 16th, 2011, 19:59   #35
cumminsfromthecold
cumminsfromthecold's Avatar
Fuel Economy: TDIYota 28-30, always on B20-B99.9, R32 terrible, blue B4 TBD
Default TDI into a Fox
Vinyl_Addict, you look like Powdered Toast Man.
I'm also curious about the Fox TDI conversion potential...
'84 Toyota truck 1Z TDI build thread, Frankentuned.
Previously: 1997 B4 Passat TDI (1Z) 5-spd (burgundy), 1999.5 Jetta TDI sedan (ALH) 5-spd, 2001 Passat W8 Sedan (01V), 2001 Jetta wagon TDI (ALH) 5-spd, 2000 Passault rallye wagon 4Motion (01V) (2.8l).
cumminsfromthecold is offline   Reply With Quote
Old June 16th, 2011, 21:22   #36
GTiTDi
Macht Schnell! Vendor
GTiTDi's Avatar
Location: 3 Spruce st Wareham, gateway to Cape Cod Massachusetts
Default Fox TDI hurdles
I helped a coworker of mine do an A3 ABA swap into a Fox, and there are definitely some hurdles but as it has a counterflow head at least you won't have to modify the hood. One thing you will definitely need to do is figure out if the accessory drive would clear the radiator, IIRC the stock set up does not fit. IIRC I don't think there is clearance for the serpentine drive. Also the stock oil filter stand will not clear the Fox clutch cable bracket, We used one from a B5 1.8T (AEB engine).
All in all anything can be done, just depends on how much work you want to do and how much money you have to play with!
91 GTI CJAA (was 1Z powered) (2012 TDIfest Radical class winner) CTN+(eurotuning 6th) fully deleted, 3" SS downpipe and side pipe running standalone using the Tischspiegel
MK2 GTI build
schnellsnailFB
schnellvw.com
GTiTDi is offline   Reply With Quote
Old June 16th, 2011, 21:27   #37
GTiTDi
GTiTDi's Avatar
Originally Posted by justinoconnor View Post
Hmm...
you should PM my buddy Burpod about his 98 Jetta TDI, he wants to do an A2 tdi swap with an 88 GLI and knows he needs a B4 donor to have an easy time...maybe you guys could figure something out...only kicker is the Jetta is actually in decent shape considering most are rotted to oblivion
MK2 GTI build
schnellsnailFB
schnellvw.com
Old June 17th, 2011, 21:13   #38
G60ING
G60ING's Avatar
This thread is what issues come into play with a TD diesel Fox:
http://forums.vwvortex.com/showthrea...ghlight=diesel
Old September 11th, 2011, 11:38   #39
G60ING
G60ING's Avatar
Added more swaps, if you don't see your build please PM me and I'll be happy to add it
Old September 28th, 2011, 11:35   #40
candela
candela's Avatar
Fuel Economy: 23mpg / 36mpg
wow.... this is beautifully organized! great job
'04 tacoma doublecabTRD
'76 porsche912E
candela is offline   Reply With Quote
Old November 3rd, 2011, 18:56   #41
TDIJ
TDI(s): AHU Wrangler
Default AHU Jeep Wrangler YJ
This is a link to my build thread for my current project. I am putting a AHU out of a 98 Jetta in my 93 Jeep Wrangler YJ.
http://www.pirate4x4.com/forum/showthread.php?t=1015140
TDIJ is offline   Reply With Quote
Old November 7th, 2011, 18:23   #42
G60ING
G60ING's Avatar
Updated with a new section for Jeeps
Old December 24th, 2011, 09:46   #43
the_mad_rabbit
Fuel Economy: 40-ish with a leaky as hell IP
Cool thread- just found out about this. I did an early TD AAZ swap about 2.5 years ago. Was easy cake- hardest part was to source a MKII TD fuel pickup for the tank- I didn't want to spend $200 on a new one
Use an inline rotary fuel pump from EMPI ($70 or so) and call it a day. The exhaust bolts right up. Started on friday morning, fired up by 5pm the same day, drove the car home on saturday- replaced the power steering rack while I was in there too... hence the additional day :laugh:
http://forums.vwvortex.com/showthrea...t-my-new-motor.
-AJ
the_mad_rabbit is offline   Reply With Quote
Old December 25th, 2011, 12:49   #44
G60ING
G60ING's Avatar
I've already got you covered
Originally Posted by G60ING View Post
People are always asking for info on swapping TDI motors..................
Corrado Swaps:
DieselGeek's Corrado TDI FS thread: http://forums.tdiclub.com/showthread.php?p=589058 pictures of Dieselgeek's Swap can be seen on ????
Purple Tom's UK Corrado 1Z Swap: http://forums.tdiclub.com/showthread.php?t=287475
n0ftInc's 1Z GT1749VA VNT Build: http://forums.tdiclub.com/showthread.php?t=303523
My mk4 ALH corrado swap: http://forums.vwvortex.com/zerothread?id=2303271
My Mk3 AHU Corrado TDI Swap: http://forums.vwvortex.com/zerothread?id=3280013
AFN Corrado TDI: http://forums.vwvortex.com/zerothread?id=1105053
Corrado with a PD swap: http://forums.tdiclub.com/showthread.php?t=255563
Corrado Diesel: http://forums.vwvortex.com/zerothread?id=4301790
Corrado TD: http://forums.vwvortex.com/zerothread?id=4462532
Mikkijane's TDI Corrado Build: http://forums.vwvortex.com/zerothread?id=3539286
Canadian VR6 Corrado to Mk3 AHU: http://www.customobsessions.com/modules.php?name=Forums&file=viewtopic&t=17946&pos tdays=0&postorder=asc&start=210
13mmwrench's mid engine Corrado longitudinal with an ALH run on an AHU wiring and ECU: http://forums.tdiclub.com/showthread.php?t=280711
-AJ
Old December 28th, 2011, 16:00   #45
the_mad_rabbit
Oops - its an early pre 93 AAZ btw
Cheers!
AJ
Page generated in 0.16974 seconds with 9 queries
[Output: 133.53 Kb. compressed to 112.27 Kb. by saving 21.27 Kb. (15.93%)]
