Old June 14th, 2006, 10:15   #1
JJtwin
Default Sharan, reset "Service Now" indicator
I own a 2004 VW Sharan TDI tiptronic.
I have read other posts explaining how to reset de "Service Now" indication on the MFD.
Since I saw there are many procedures using cluster knobs (without VGA-Com tool) , I am not sure which one applies to my VW Sharan.
Thanks in advance.
JJ
JJtwin is offline   Reply With Quote
Old June 14th, 2006, 11:20   #2
tongsli
Thread can be found here
Instructions on how to re-set with the cluster can be found here:
RC 3.1,DG pipes,Bosio PP764, Forge SMIC,R32 airbox,FSI/OilLevelSensor,150PDTIP&MAF&Intake Manifold, Bilstein TCs,TT brakes,280mm rears,A3 strut bar,ESP,Folding Mirrors,Aero wipers,Headlight Washers,PDC,Bora Trunk switch,VR6 muffler,4-motion valance, OEM Skid Plate &HIDs,Custom Tails, Zender Spoiler,WE Power,heated Seats,RNS2,MFSW,Anti-dazzle mirror,FIS,IRU,DWA,2nd OBDII,OEM Auto Window,P3 vent gauge, Webasto Thermotop C heater
tongsli is offline   Reply With Quote
Old June 14th, 2006, 11:26   #3
tongsli
Put the key in the OFF position.
Push and hold the tripmeter button (the one on the right by the speedometer). While holding the button, turn the key to the ON position, but don't start the car.
The display will say "service" (stock) or "SERVICE NOW" (MFI) depending on your cluster.
Release the tripmeter button. Then turn the clock button (on the left by the tach) to the right one click.
This will reset whatever service interval has been displayed, and your display will then go back to normal.
Switch off the ignition.
Page generated in 0.13111 seconds with 9 queries
[Output: 54.95 Kb. compressed to 49.36 Kb. by saving 5.59 Kb. (10.17%)]
