Old June 7th, 2006, 16:42   #1
stink bug
Fuel Economy: 38 to42 (Cuz of racks)
Default catalytic converter cleaning?
Hello again, I heard a while back that catalytic converters start to get clogged up after about 50,000 miles and it hurts the engine. I also heard that they can be cleaned by using some kind of citrus solvent.
True or False?????
Thanx, the stinker
stink bug is offline   Reply With Quote
Old June 7th, 2006, 20:02   #2
40X40
Experienced
Fuel Economy: TBD, new data forthcoming
Never heard of cleaning a cat....
Whoever you heard that from should go to the bottom of the
trusted list untill you have more info.
(way to the bottom!)
Bill
www.IHMSA.ORGhttp://www.youtube.com:80/watch?v=Xtsxt7xgbpc
If you omit pertinent info from your question, you cannot reasonably expect a good answer.//Not affiliated with any vendors except as a customer.// Wise people lurk more.// I'm not a guru.// 'I got actual real friends in the real world'-T'sTDI/ If you were the only entry, there wasn't a race.// Grammar and spelling really are important, but I don't claim to be good at it.// Typical drivers can't.
40X40 is offline   Reply With Quote
Old June 7th, 2006, 21:03   #3
whitedog
It's not how you clean the cat, it's how you cook it.
Some people "clean" their converters with a drill. Not an EPA santioned process, so ignore that sentence.
Winters come, and winters go.,
Summers come, and summers go.
Old June 7th, 2006, 21:21   #4
Drivbiwire
Zehntes Jahr der Veteran
Retard the injection timing to the bottom of the graph. Drive with the engine set that way for about a week while taking a few spirited drives of at least 30 minutes. This will heat the cat and burn off any built up carbon.
CAUTION: Do not set the timing BELOW the bottom of the red-line in VAG-Com, I personally have seen melted turbine wheels as a result of too retarded timing (nearly at the bottom of the timing chart is the range the damage occured).
I do agree that this is needed from time to time. You can tell the cat is cleaned out when you smell the "water-ized" scent from the exhaust.
DB
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old June 7th, 2006, 21:44   #5
wny_pat
Fuel Economy: 48 mpg
I learn something new here every day!!!
'02 Jetta TDI GLS. Bosio Sprint 520. Hella E-Codes. HiddenHitch and rear suspension air bags. Evolution Skid Plate.
wny_pat is offline   Reply With Quote
Old June 7th, 2006, 23:28   #6
Fortuna Wolf
Fuel Economy: 36 mix
drivbi, will this also heat up the turbo and cook carbon off of the vanes? Or is this not recommended for cleaning the turbo?
2002 Jetta Sedan ALH-01M: 2 um Cat FF, Wingnut-3 CCV filter, polyurethane fuel lines, 5 brake light mod, Ventectomy, Polysiloxane vacuum tubing, Pioneer DEH-3800MP w/ KFC-1389ie, Panzer Plate, EGT+Boost+Oil Temp Gauges, Boost Valve, KERMA Line Pressure Mod, LED Lighting, HC-12a refrigerant, Optima 75/35 AGM, .187 nozzles, Hawk HPS pads.
Coming Soon: ESP retrofit, Custom Greasecar.
Wish List: Tow Bar, DSG or CVT transmission, or even a 5 speed manual. To hit 42+ mpg
Fortuna Wolf is offline   Reply With Quote
Old June 8th, 2006, 04:56   #7
LurkerMike
LurkerMike's Avatar
Fuel Economy: -Whitey: 38-40 mpg Hwy @ 80 mph / -Red 46 mpg Hwy @ 80 mph
Check out the comments in this other thread where I was told that the stock cat never clogs up?
http://forums.tdiclub.com/showthread.php?t=139697
LurkerMike is offline   Reply With Quote
Old June 8th, 2006, 06:08   #8
whitedog
I must have missed that post that says the cat never clogs up. I'm interested in reading that post.
Old June 8th, 2006, 07:50   #9
Drivbiwire
Once the VNT vanes are jammed solid, thats it it will have to be torn down and de-carboned as well as remove the rust and scaling. Heating may burn off the carbon the guide vanes but will do little to unjam the mechanisms.
DB
Old June 8th, 2006, 10:56   #10
stink bug
If it does start to restrict emissions, could this be why inside my cab smells like diesel sometimes. Or is that normal for a bug with 50,000. I mean maybe this is a different subject all together. But all the bug's I test drove That had approximatly that much milage smelled funny inside. I guess that should maybe have been the post topic, as thats what I'm trying to find out.
stinky
Old June 8th, 2006, 11:57   #11
weedeater
Fuel Economy: 54/43/38
If it smells like raw diesel fuel, you have a fuel leak somewhere, most likely those little hoses between each injector.
If it smells like exhaust, then my guess would be the cabin 'exhaust' vents in the rear quarter panels. They get stuck open with age.
FWIW, a lot of cars I've been in start to smell funny after a while. Usually it's the half-eaten cheeseburger under the seat that is the culprit.
It may seem like I am doing nothing, but on a cellular level I'm really quite busy.
The game of Bridge is like Sex: You need either a good partner or a good hand.
You're either part of the solution or you're part of the precipitate.
weedeater is offline   Reply With Quote
Old February 10th, 2008, 08:42   #12
ahibbert
TDI(s): 2001 Jetta
Default cleaned-up catalysts
Now scientists from the Institute of Catalysis and Petrochemistry in Madrid, Spain, have found that a dilute solution of citric acid can wash out the catalyst killers without damaging the platinum. When tested on a simulated stream of exhaust gases, the cleaned-up catalysts were as good as new, the team reports online in Environmental Science and Technology.
ahibbert is offline   Reply With Quote
Page generated in 0.14043 seconds with 9 queries
[Output: 102.93 Kb. compressed to 86.19 Kb. by saving 16.75 Kb. (16.27%)]
