Old January 25th, 2007, 10:33   #16
PharoahTDI
PharoahTDI's Avatar
TDI(s): None
Sorry I stated my question wrong. I have taken them out but what bulbs to I need to replace them with? Is the one you used from RS the same?
Past TDI's: 1997 Passat Wagon, 2000 Golf, 2004 Jetta Wagon, 2006 Jetta Sedan
Current: 2015 Golf TSI
Now with VCDS
PharoahTDI is offline   Reply With Quote
Old January 25th, 2007, 11:18   #17
Ray_G
Ray_G's Avatar
TDI(s): 98 Jetta TDI
Well, I don't have a radio in front of me, but the ones in the bayonets are just a plug in bulb I believe. The ones for the LCD backlight are soldered in, so they would be different. I think my local NAPA guy carries those.
Ray
06 E320 CDI Benz
98 Jetta TDI 94 F250 Powerstroke 76 911s
Ultimate cup holder for B4's Dimensions for A3/B4 and A4 timing belt tools Injection pump head how-to
Ray_G is offline   Reply With Quote
Old June 9th, 2007, 18:15   #18
Greaseburger
Greaseburger's Avatar
Fuel Economy: Best of 53.8
Can different color bulbs be substituted? I would like to go blue
99.5 Jetta, RC3,Veg .216, Omi,Bilstein Tc sport 2 1/2''Exh no cat,no muff,Longbeach,Euroswitch,fogs front&RearDepo HL
Greaseburger is offline   Reply With Quote
Old June 9th, 2007, 18:42   #19
Ray_G
Ray_G's Avatar
The bulbs slide into a little silicone jacket that is green, that is what gives it the color. I guess if you could find them in blue you could get blue lights. Good luck with that one though.
Ray
06 E320 CDI Benz
Old June 15th, 2007, 08:37   #20
Diesel_Aggie
Anyone ever had the "copper pad" that the bulbs attach to disappear when removing the old ones? The left bulb went on great but the copper area the right bulb attaches to seems to have vaporized or melted away. I guess there is no way to fix this other than repalcing the board? Any idea what went wrong and ways to prevent it next time? Anyone have a spare board for a tape deck unit? Thanks!
Diesel_Aggie is offline   Reply With Quote
Old June 15th, 2007, 16:10   #21
Ray_G
Ray_G's Avatar
I have one spare light board with new bulbs installed. If you will send me a PM with your email I will send a picture of it to you in the AM.
Ray
06 E320 CDI Benz
Old June 11th, 2008, 11:54   #22
MikeB4
Fuel Economy: 48/42/38
Default Bayonet Socket Lights
Does anybody have a source for those bulbs with the twist-on bayonet sockets? Who makes the radio, anyway?
Thanks!
Michael
97 Passat TDI Sedan
MikeB4 is offline   Reply With Quote
Old June 11th, 2008, 20:23   #23
BKmetz
Administrator, Member #10
BKmetz's Avatar
Fuel Economy: 50 MPG
Matsush!ta/Panasonic made the radios.
Brian, 2015 Passat SE TDI 6MT
Kathy, 2014 Passat SE 2.5
Chris, 2015 Passat SEL TDI
If ANYONE receives a PM/email from a TDIClub member shilling anything and they are NOT a registered vendor, please forward the PM/emails to me. To report spam, trolling, or any problem post, click the report post icon. (The icon in the actual problem post, not the one in my sig. The idiots know who they are... )
BKmetz is offline   Reply With Quote
Old June 21st, 2009, 21:46   #24
deathunger
deathunger's Avatar
im with mike. i wanna find the bulbs, but blue
96 windsor blue passat TDI 450,000 km still going MINE
96 red passat 145,000 TDI (moms, i think its replaced cluster haha, runs like shiza)
96 white diesel transporater dads
deathunger is offline   Reply With Quote
Old November 28th, 2009, 16:22   #25
idleofwight
idleofwight's Avatar
Will this fix the screen on the radio or is it only for the buttons?
96' B4V - Upsolute, straight pipe
idleofwight is offline   Reply With Quote
Old December 25th, 2009, 05:19   #26
Lug_Nut
Pre-Forum Veteran Member
Lug_Nut's Avatar
Fuel Economy: 116 mpg(e), 36 mpg gas, 100 mpg combined
The two bulbs singled out in this how-to are the two for the digital display.
All the others, those mounted vertically, are for button illumination.
I finally got around to replacing the bulbs on the radio mentioned in post #13. Really easy with instructions. Thirty minutes is about right.
I replaced them with a pair of the smaller bulbs used for button illumination as I personally feel the display is too bright for night use.
Svante Arrhenius 1896
Old January 4th, 2010, 18:02   #27
RC
RC's Avatar
Gotta get around to doing this as the right side is dark, but surely will do the other while it's apart.
Two 96 TDI Passat Wagons, Bypass Filters, Chipped
87 MB 300TD, 97 Ram2500, Kubota Tractor
24 cylinders sipping the sweet sauce of the soy bean
RC is offline   Reply With Quote
Old January 6th, 2010, 18:14   #28
Lug_Nut
Lug_Nut's Avatar
The lower intensity bulbs are nearly perfect for me....at night.
Twilight and dusk could use just a touch more illumination, but otherwise, it's 'more better' than it was with the full-bright lamps.
Old July 30th, 2011, 20:17   #29
keebler64
Ray
If you've ever taken apart a MK1 or mK2 CE1/CE2 gauge cluster, the High Beam indicator light uses a blue cap that can be swapped in place. But I found it doesn't work well unless you can match the rest of the lights. The other option would be to swap in LEDs, but you'd either have to wire in a voltage regulator and some resistors to pull the voltage down to 3v or get some appropriate 12v LEDs with inline resistors wired in. (I actually can't remember what the voltage was at the bulbs.)
I'm going to be pulling mine out tonight and will throw it on my power supply/work bench.
keebler64 is offline   Reply With Quote
Old July 30th, 2011, 23:53   #30
keebler64
Well, just measured it and it's 9vdc. I'm all out of the incandescent bulbs, so I'm going to try to pop in some 3.3vdc green leds (only others I have are super white). I'll post the result.
That being said, if you wanted to change them all to LEDs you can, something cooler would be to wire in RGB leds hooked up to a separate MCU controlling the colors via PWM. But realistically, its extremely impractical and wouldn't match the rest of your interior. (that is unless you wired every light in the car to the same MCU. Also possible, but time consuming/insane.)
Also, if you were so inclined and you REALLY wanted a blue/red/whatever color. You can take apart the LCD assembly and replace the white diffuser screen with the color of your choosing/color it with a sharpie.
Page generated in 0.17869 seconds with 9 queries
[Output: 124.42 Kb. compressed to 102.77 Kb. by saving 21.64 Kb. (17.40%)]
