Old May 31st, 2006, 21:19   #1
IowaJetta
TDI(s): 2001 Jetta
Default Can I pull my engine out of the top without the tranny?
I have a 2001 Jetta with a bad engine and all the manuals say drop the engine and tranny together out of the bottom of the car. I would like to pull the engine only out of the top of the car can this be done?
IowaJetta is offline   Reply With Quote
Old May 31st, 2006, 21:41   #2
Drivbiwire
Zehntes Jahr der Veteran
Yes they drop out the bottom of the car not the top.
It requires the removal of 6 bolts, disconnecting the wiring harness and fuel lines, shift linkage, A/C, exhaust and cooling lines. You can have the engine ready to drop in about 1 hour total. The time you would waste trying to pull the motor out the top is simply not worth the hassle.
DB
Specializing in Injectors for CRI, CR, PD, VE, IDI VW, Audi, MB, SEAT and Skoda Diesel engines.
Offical Importer, Distributor and Installer for Fratelli Bosio, S.R.L. North America
Quotes and Pricing for TDI Injectors
Old May 31st, 2006, 23:30   #3
Chemboy
Could you:
  1. Unbolt the transmission from the engine
  2. Remove the front end (bumper...)
  3. Pull the engine forward
--Andy
Chemboy is offline   Reply With Quote
Old May 31st, 2006, 23:47   #4
Matthew_S
Matthew_S's Avatar
Fuel Economy: 41-46
Originally Posted by Chemboy
Could you:
--Andy
There may not be enough room on the 5 speed cars to separate the engine and trans in the car. On a auto you probably could but like Drivbiwire said, it's way too much work. Why make harder than it has to be?
Matthew_S is offline   Reply With Quote
Old June 1st, 2006, 10:27   #5
Chemboy
Ok, then why not remove the engine AND transmission through the front? This MUST be easier than installing a car lift in the garage!
IowaJetta, go search for this on www.vwvortex.com. People over there do engine swaps all the time.
--Andy
Old June 1st, 2006, 11:20   #6
Drivbiwire
Yes that's another way. Taking the front off the car is not that much work and you could pull the motor straight out.
When VW builds the car the engine/transmission are lifted up into the car. This makes it easier to automate the process by installing a complete assembly.
DB
Old June 1st, 2006, 11:49   #7
pepper10
Fuel Economy: 46 Avg
So how then do you change the clutch? Drop the engine and tranny out? Don't think so. There is plenty of room to remove the tranny alone from the bottom. With the tranny out, it should be fairly easy to take the engine out from the top/front.
It's a Diesel thing...ladida
pepper10 is offline   Reply With Quote
Old June 1st, 2006, 12:04   #8
Drivbiwire
Trust me there is not enough room...
You can pull the engine out the top IF you take everything apart in the engine bay...The time it takes to do this is easily saved by either dropping the whole engine/transmission or sliding it out the front of the car.
You can do 3 engne swaps in the time it takes to pull one motor out the top of the engine bay.
DB
Old June 2nd, 2006, 09:27   #9
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
TDI(s): None
I don't know whether you guys have the ground clearance to do this, but the Mk1 and Mk2 people do sometimes drop the engine and tranny, and then jack the car up, and drag the engine and tranny out from under the car.
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is offline   Reply With Quote
Page generated in 0.17592 seconds with 9 queries
[Output: 87.91 Kb. compressed to 74.70 Kb. by saving 13.21 Kb. (15.02%)]
