Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
Old May 25th, 2006, 23:15   #1
skurf
TDI(s): 06 Golf
Default How often should I change fuel filter?
I've been using B20 - B50 in the winter and B100 since it warmed up and was wondering how often I should change the fuel filter. I have 11k miles so far and have exclusively used biodiesel since I bought the car new.
skurf is offline   Reply With Quote
Old May 26th, 2006, 08:15   #2
ScorpionBoy
pretty sure the interval is 10k
2003 Jetta TDI, Auto
Coolant Migration Mod
Provent CCV Filter
Panzer Plate
Vented
ScorpionBoy is offline   Reply With Quote
Old May 26th, 2006, 08:27   #3
tditom
Fuel Economy: Golf: 54/48/43.5 B4 Passat: 52/48.5/45 B5.5 Passat: 30 mpg mixed
The change interval is every 20k miles. Drain the water separator halfway between each replacement.
-tom
autos: 15 Volvo V60, 08 MB E320 Bluetec
Find your VW part numbers here.
Why I recommend fuel additive.
tditom is offline   Reply With Quote
Old May 26th, 2006, 09:17   #4
skurf
TDI(s): 06 Golf
So is it 10 or 20?
How would I go about doing that?
Old May 26th, 2006, 09:24   #5
tditom
Your maintenance schedule can be found at vw.com. You have to select your model, and then click on "full schedule" at the bottom of the page.
The older fuel filters have a drain valve at the bottom of the filter. I'm not sure about your new Golf. do a search on the A5 forum
Old May 26th, 2006, 09:25   #6
Fortuna Wolf
Fuel Economy: 36 mix
pull the filter up, unscrew the white knob and let drain into a container.
Honestly, its not really necessary. I've never noticed water.
2002 Jetta Sedan ALH-01M: 2 um Cat FF, Wingnut-3 CCV filter, polyurethane fuel lines, 5 brake light mod, Ventectomy, Polysiloxane vacuum tubing, Pioneer DEH-3800MP w/ KFC-1389ie, Panzer Plate, EGT+Boost+Oil Temp Gauges, Boost Valve, KERMA Line Pressure Mod, LED Lighting, HC-12a refrigerant, Optima 75/35 AGM, .187 nozzles, Hawk HPS pads.
Coming Soon: ESP retrofit, Custom Greasecar.
Wish List: Tow Bar, DSG or CVT transmission, or even a 5 speed manual. To hit 42+ mpg
Fortuna Wolf is offline   Reply With Quote
Old May 26th, 2006, 09:28   #7
tditom
I've never seen water either. That doesn't mean it shouldn't be done.
You also need to disconnect the "T" (keep the lines on it tho) on the A4. Not sure about A5 set up.
Old May 26th, 2006, 09:29   #8
4Gman
4Gman's Avatar
TDI(s): 2000 Jetta
Its really easy.
Take out the Fuel filter and twist the little plastic spout on the bottom to let water out.
If you have an A4:
http://pics2.tdiclub.com/video/cincitdi/fuelfilter.html
IF you have an A5:
http://forums.tdiclub.com/showthread...fuel+filter+a5
D
4Gman is offline   Reply With Quote
Old May 26th, 2006, 09:45   #9
RC
RC's Avatar
Drain the filter just to see if you have any H2O.... then go ahead and change it out for good measure. It doesn`t cost much and it is good maintance practice. You might wanna disect the old one just to see what it caught.
Two 96 TDI Passat Wagons, Bypass Filters, Chipped
87 MB 300TD, 97 Ram2500, Kubota Tractor
24 cylinders sipping the sweet sauce of the soy bean
RC is offline   Reply With Quote
Old June 2nd, 2006, 15:58   #10
TXBilll
Why would you change the filter before it clogs? It seems to me the longer you leave the filter in, the better it filters. When you have a loss of power, change the filter. Maintenance schedules make $$$ for service departments.
TXBilll is offline   Reply With Quote
Old June 2nd, 2006, 16:13   #11
compu_85
Gadget Guy
compu_85's Avatar
Because a plugged filter make the injection pump work harder, and that shortens it's life.
-Jason
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old June 3rd, 2006, 06:49   #12
Gothmolly
TDI(s): 2002 Golf
Eh, I change all my filters (except oil) once a year in the spring, on the anniversary of buying the car. For me thats about 13k miles. Get the filter pack from tdiparts, and just be done with it.
Gothmolly is offline   Reply With Quote
Old June 3rd, 2006, 07:19   #13
Dr_Duse
Dr_Duse's Avatar
Default 10k or 20k
VW says 20k but many of the biodiesel folks change it sooner. It will cost you more then the price of a filter if you car stops running on I-35 or Mopac some afternoon.
Doc
2005.5 Jetta TDI Platinum Gray w/DSG
Dr_Duse is offline   Reply With Quote
Old June 3rd, 2006, 13:33   #14
Gothmolly
TDI(s): 2002 Golf
There's no need to change it sooner just because you run Bio. Dirty fuel, bio or not, will mandate more frequent changes. I've run commercial B20 for a year, and not a drop of water or piece of visible crud came out the drain when I swapped filters.
Old June 10th, 2006, 12:43   #15
aberson
Fuel Economy: 44, but need to clean my snow screen
How much are you supposed to let drain?
I drained about 3 ounces out before I decided to stop. Upon examining the bottle, it looked like I had about 2 dropper-drops of water sitting at the bottom, and the rest was just diesel. Am I correct that the drain isn't just for draining water, but will actually drain all the fuel from the filter too?
I didn't have the suction device the video shows, and I didn't want to have tooo much air in my system by draining all the fuel out of my filter. The little air that was introduced seems to have worked out of the system after a few miles.
aberson is offline   Reply With Quote
Page generated in 0.17950 seconds with 9 queries
[Output: 121.49 Kb. compressed to 100.67 Kb. by saving 20.83 Kb. (17.14%)]
