dieseldorf
Mobil 1 ESP Formula M 5W-40 - Emission System Protection
check this out. Mobil is releasing a 5W40 version of the oil released a year ago in Europe that is a 5W-30 viscosity.
5W-30 product:
I don't see any ratings apart from the newest MBz spec 229.51 (for DPF cars).
Oh, I see a typo below....it says 5W-30 and 5W-40
Advanced Performance Synthetic Engine Oil
Product Description
Mobil 1 ESP Formula M 5W-40 is an advanced performance synthetic engine oil designed to provide exceptional cleaning power, wear protection and overall performance. Mobil 1 ESP Formula M 5W-40 is engineered to help prolong the life and maintain the efficiency of Car Emission Reduction Systems in both diesel and gasoline powered automobiles that require an oil that is approved against Daimler Chrysler's MB 229.51 specification.
Features and Benefits
Mobil 1 ESP Formula M 5W-40 is made with a proprietary blend of high performance components formulated to be fully compatible with the latest Diesel Particulate Filters (DPF's) and Gasoline Catalytic Converters (CAT's). Mobil 1 ESP Formula M 5W-40 has been designed to deliver outstanding performance and protection in conjunction with improved fuel economy. Key features and benefits include:
Features
Advantages and Potential Benefits
Low Ash Content Helps to reduce particulate build up in Diesel Particulate Filters
Low Sulphur and Phosphorous content Helps to reduce poisoning of Gasoline Catalytic Converters
Active cleaning agents Reduces deposits and sludge build-up to enable long and clean engine life
Outstanding thermal and oxidation stability Reduces oil ageing allowing extended drain interval protection
Low oil consumption Less hydrocarbon pollution
Enhanced frictional properties Greater fuel economy
Excellent low temperature capabilities Quick cold weather starting and ultra fast protection
Extended engine and electrical system life
Applications
Mobil 1 ESP Formula M 5W-40 is approved against Daimler Chrysler MB 229.51.
It is not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
Specifications and Approvals
Mobil 1 ESP Formula M 5W-30 has the following builder approvals:
Typical Properties
SAE Grade 5W-40
Viscosity, ASTM D 445
cSt @ 40ºC 81.1
cSt @ 100ºC 13.35
Viscosity Index, ASTM D 2270 167
Sulphated Ash, wt%, ASTM D 874 0.63
HTHS Viscosity, mPa•s @ 150ºC, ASTM D4683 3,8
Pour Point, ºC, ASTM D 97 -39
Flash Point, ºC, ASTM D 92 236
Density @ 15ºC, kg/l, ASTM D 4052 0.85
Health and Safety
Based on available information, this product is not expected to produce adverse effects on health when used for the applications referred to above and the recommendations provided in the Material Safety Data Sheet (MSDS) are followed. MSDS's are available upon request through your sales contact office, or via the Internet. This product should not be used for purposes other than the applications referred to above. If disposing of used product, take care to protect the environment.
The Mobil logotype, the Pegasus design and "Mobil 1" are trademarks of Exxon Mobil Corporation, or one of its subsidiaries.
4-2006
3225 Gallows Road
Fairfax, VA 22037
1-800-Mobil25 (662-4525)
Due to continual product research and development, the information contained herein is subject to change without notification.
Typical Properties may vary slightly. This product data sheet is based on global product data sheets for use with products purchased in the U.S.
© 2001 Exxon Mobil Corporation. All rights reserved.
5W-30 product:
Product Description
Features
Applications
Typical Properties
SAE Grade 5W-40
cSt @ 40ºC 81.1
cSt @ 100ºC 13.35
Health and Safety
4-2006
3225 Gallows Road
Fairfax, VA 22037
