Old May 7th, 2006, 11:18   #1
DubbedDiesel
Default B4 TDI...where's the starter motor located?
Does anybody know where the starter motor on a '97 TDI Passat is located?? Anybody have a re & re procedure?? Thanks!
DubbedDiesel is offline   Reply With Quote
Old May 7th, 2006, 14:22   #2
lrpavlo
Default Under the battery
There is a 10mm bolt holding a plastic connector of wires on above it....Then you need a deepwell 13mm to get the bolt out that actually holds starter to the housing.
Be sure to support the motor as one of the bolts goes into the motor mount.
I had my starter rebuilt.
09 JSW Platinum/art/DSG/tint/Panzer/Curt hitch/body moldings/flaps/ Used to own!!
96 Passat B4V /99.5 Golf GL 205 + lift /00 Golf GL auto + lift /00 Golf GLS auto chipped + lift /02 Beetle auto 2" lift + chip + .205 / 01 Golf GLS 5sp lifted
lrpavlo is offline   Reply With Quote
Old May 7th, 2006, 15:14   #3
DubbedDiesel
Thanks for the reply! Just a quick question then....is the starter from an auto VR6 interchangeable with a 5spd TDI car?
Old May 7th, 2006, 22:18   #4
lrpavlo
Sorry....can't help ya with that one...maybe someone with ETKA?
Old May 8th, 2006, 11:01   #5
Beowulf
Beowulf's Avatar
Fuel Economy: 59.9/50.3/35.7 (3.93/4.68/6.59)
There are a number of starter assemblies for the 96 Passat:
1,>02A 911 023 F,BOSCH,>>3A-T-100000,ABA
2,>02A 911 023 A,BOSCH,>>3A-T-100000,AUTOMATIC: ABA
3,>02A 911 023 N,BOSCH,,AAA
4,>068 911 023 T,BOSCH,,AUTOMATIC: AAA,AAZ,1Z
6,>02A 911 023 J,BOSCH,3A-R-152916>>3A-T-100000,AAZ,1Z
7,>02A 911 024 ,BOSCH,3A-T-100001>>,AAZ,1Z,AHU
8,>02A 911 023 T,BOSCH,3A-T-100001>>,ABA
9,>020 911 023 N,BOSCH,3A-T-100001>>,AUTOMATIC: ABA
It wasn't clear to mewhether they are interchangable. There are some parts of the assembly specific to each start version, but they all share the same solenoid switch (#7 in the illustration). I don't know if that helps, but I don't know enough about starters to be more specific in my screenshots.
Ich bin der Anschlagpuffer.
Beowulf is offline   Reply With Quote
Page generated in 0.12519 seconds with 9 queries
[Output: 63.51 Kb. compressed to 55.72 Kb. by saving 7.79 Kb. (12.26%)]
