TDI 4 RD
So I thought I'd play around with my new VAG-COM this morning, and I ran a scan for fault codes. To my dismay, the engine module came back with a fault code:
013112 - Control Circuit for Glow Plug Controller 1: Electrical Malfunction
P3338-000 - - - - Intermittent
Is this something to be concerned about? In general, do VW dealers get upset if you tell them you did a scan on VAG-COM and found a fault?
(I also got an "implausible signal" code from my window regulator switch on the rear passenger and driver's side. I'm not particularly worried about this).
Sometimes ignorance is bliss.
Thanks very much.
Thanks very much.
