Old May 2nd, 2006, 21:31   #1
Licken2
Default Evry mod : Holy Cow!
Just completed the Evry mod on my 02 Jetta 5-spd. Used a small 1k ohm 15-turn potentiometer from Radio Shack. Super easy to do. Measured the resistance at the point where the engine began to shudder slightly... turns out on my car 470 is the sweet spot. Anything more and the idle is terrible. Moreso than I'd be comfortable driving with. At any rate... I'm IMPRESSED! I lined up against my buddies 03 Jetta Wagon (he just bought it). The other day we were dead even against each other from any speed. With the Evry mod I flat out walked away from him - in a cloud of black smoke! LOL! Tomorrow night we're gonna wire up a switch or some other method of avoiding the CEL..... and he's gonna do the mod to his Jetta as well. Thanks to this forum for the wonderful info!!!
02 Jetta TDI 5spd - Ventectomy, !DRL, !snowscreen, Evry mod, cold cathode trunk lights, 03+ center console, and tinted windows... so far.
Licken2 is offline   Reply With Quote
Old May 2nd, 2006, 22:51   #2
JetPuf
JetPuf's Avatar
Fuel Economy: loswest mpg 32 Towing, average 45, highest 53 hwy
one thing i'd recomend from personal experiance is a boost gauge, and a boost control device. as you're adding more fuel the boost will go up, and spikes will increase.
how do I know? I'm putting in a new head gasket this summer from boost spikes caused by evrymod over fueling.
Turbo gauges can be purhcased for REALLY cheap. there are really nice kits avaliable for the A4's with everything needed for less then 100 dollars.
White '98 NB TDI "Jetpuf" 245k miles Tune, Injectors, Turbo, Peloquin, 02J 6-Speed..
Blue Graphite 2010 JSW TDI CR 35k miles Digifit's, OE dog barrier
Member of The Joneses
JetPuf is offline   Reply With Quote
Old May 2nd, 2006, 23:05   #3
Fortuna Wolf
Fuel Economy: 36 mix
Err, what is this Evry Mod? I just did a forum and google search and couldn't turn up any clear information.
Fortuna Wolf is offline   Reply With Quote
Old May 2nd, 2006, 23:17   #4
killerjetta
It tricks the computer into dumping more fuel into the engine.
http://forums.tdiclub.com/showthread...light=evry+mod
killerjetta is offline   Reply With Quote
Old May 3rd, 2006, 07:47   #5
Licken2
Thanks for the advice. I will probably order a "Dawes Device" very soon. I am going to wire up a switch for this Evry mod... I'll only play with it every once in awhile. Although... never hurts to have your bases covered.
Old May 3rd, 2006, 16:43   #6
Jorgen
Hi.
I´m from Sweden and i´m new here in this forum.
I just want to give you a friendly advice, back off and don´t go so high!
The 90 hp TDI, can take it better than the 110 hp engine.
I´m a manufacturer of lots of different tuning boxes and CPU:s and i have learned it the hard way...
Jorgen is offline   Reply With Quote
Old May 4th, 2006, 06:48   #7
Licken2
Hi Jorgen!
Don't go so high? I'm not sure I understand what you mean. This is the 90hp TDI engine. Maybe that advice wasn't even directed towards me.
In other news, I wired up a micro-switch... mounted it under the dash... and while it's off there is indeed no Check Engine Light. Flip it on while driving and there's a sudden blast of power. Couldn't be happier! My boost valve will be here next week. So til then, not much playing.
I love my TDI!
Old May 4th, 2006, 09:34   #8
JetPuf
JetPuf's Avatar
boost valve. really smart.!
Old May 4th, 2006, 16:24   #9
Jorgen
Originally Posted by Licken2
Hi Jorgen!
We are selling a low cost tuning box that works in a similar way. It is the same adjustment procedure, pull it up on idle until it stutters and then pull back a bit. My experience is that if you drive with an adjustment too close to the "stutter" and "shut off" limit and often drive like you stole it, your pump will eventually bite the dust.
I hope i did properly understand what kind of mod you have done. My english is a bit rusty.
I just wanted to share my experiences...
A Swede who lives in diesel fumes...
Old May 7th, 2006, 10:57   #10
Richard55
Richard55's Avatar
TDI(s): 2000 NB
Fuel Economy: 52 MPG
Can anyone pdf a file that shows how the Evry mod is installed and the parts needed to do so.
Richard55
00 NB tdi of course
Richard55 is offline   Reply With Quote
Old May 7th, 2006, 11:23   #11
ICNTDRV
ICNTDRV's Avatar
I've been interested in making an Evry Mod, but the thought of getting the right parts and putting them together is a little intimidating. A detailed write-up would be nice.
'00 Golf TDI
'97 Passat TDI (FOR SALE)
'05 Passat TDI (sold)
'96 Passat TDI (RIP)
ICNTDRV is online now   Reply With Quote
Old May 8th, 2006, 19:17   #12
Richard55
Richard55's Avatar
TDI(s): 2000 NB
I don't think it would be hard, just need to know where to hook the pot to and how to dial it in. Someone help please
Old May 8th, 2006, 19:45   #13
bam_bam_dip
bam_bam_dip's Avatar
Fuel Economy: 51.3, 700 Club
do a search......this mod has been around for years. With plenty of how-to's.
Want a good read? Me & my Red Rider Against the Squirrels!!
My Father's house is a big, big house.
bam_bam_dip is offline   Reply With Quote
Old May 8th, 2006, 19:45   #14
ChadMC
It helps to have a multimeter. This is what I got from radioshack:
Multimeter:
http://www.radioshack.com/product/in...entPage=search
1k Ohms Potentiometer:
On/Off Switch:
And then some thin wire. I had some laying around. I'm not sure how important exact gauge is.
Here is a horrible diagram i drew in paint, hopefully this will give you an idea of how to wire it with a switch. The switch I used has a light in it, so i had to connect it to a 12V source.
http://img232.imageshack.us/my.php?image=diagram0dx.jpg
ChadMC is offline   Reply With Quote
Old May 8th, 2006, 20:14   #15
JetPuf
JetPuf's Avatar
Why do you have it going to a 12v source?? for a light? a 12v source is not needed with a simple switch setup.
Page generated in 0.13865 seconds with 9 queries
[Output: 122.22 Kb. compressed to 101.18 Kb. by saving 21.04 Kb. (17.22%)]
