Go Back   TDIClub Forums > VW TDI Discussion Areas > Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc)
Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) Discussions about alternative fuels for use in our TDI's. This includes biodiesel WVO (Waste Vegetable Oil), SVO (Straight Vegetable Oil), BTL (Biomass to Liquid), GTL (Gas to Liquids) etc. Please note the Fuel Disclaimer.
View Poll Results: Should this thread remain stickied?
yes 6 60.00%
No 4 40.00%
Voters: 10. You may not vote on this poll
Old May 4th, 2006, 19:36   #16
Btravelen
http://biodiesel.org/buyingbiodiesel...lfuelingsites/
Isn't this a pretty thorough listing of biodiesel sources?
'05 Stonehenge gray TDI Passat Wagon, Leather with wood. Splash guards, 3M Clear bra, Reverse sensors, Spoiler, Rear sunshade, etc..
What's a chain?
'05 Ford Excursion Limited, 6.0L PSD, Air Lifts, Bilsteins, High idle mod.
Btravelen is offline   Reply With Quote
Old May 4th, 2006, 21:42   #17
TwinTDI
Tennessee -(my return -ey and the -ey that is after the letter J is bro-en) Citgo at 5th St and Main St in Nashville has biodiesel. I'll find out what grade it is and post from wor- where my -eyboard isn't screwed up.
TwinTDI is offline   Reply With Quote
Old May 5th, 2006, 05:44   #18
jwlionking
jwlionking's Avatar
Fuel Economy: 46/42/38 27000 miles
Yes it is however its not updated entirely and at least on here, we can update them as we see them.
2002 Jetta GLS TDI 5 spd manual 306,000 miles - RIP
2012 Jetta TDI 6 spd manual
TDI Trusted Mechanics
Drivbiwire's Break-in Rules
jwlionking is offline   Reply With Quote
Old May 5th, 2006, 06:04   #19
05TDIPDHappy
Fuel Economy: 53.5/52.5/45.6
Washington State:
Olympia WA
Acme Fuel 505 Lilly Road NE Olympia, WA 98506, Christopher Allen, 360-943-1133, B20 and B100, CFN Cardlock Site.
There are more, one in Fife somewhere and more in the Seattle area but I don't frequent them, I just know they exist.
Cheers
05 Golf TDI PD Indigo Blue
05TDIPDHappy is offline   Reply With Quote
Old May 5th, 2006, 06:27   #20
TwinDiesel
Citgo [B20]
500 Main St.
Nashville, TN 37206
Located at the intersection of Main St. and 5th St.
(This post brought to you by the letter K and the Return key.)
His - '06 Jetta TDI, black, Pkg 1, 5MT, 17" Visions, OEM spoiler
Hers - '06 Jetta TDI, spice red, Pkg 1, DSG
Soot happens
TwinDiesel is offline   Reply With Quote
Old May 6th, 2006, 09:04   #21
lmoretti
Default No!
Nope-
No site I've found so far is consistant or complete.
There is a US Gov site (http://www.eere.energy.gov/afdc/) that gives partially overlapping data. I've also seen another list somewhere, but don't remember where. None of them have matched even 90%, each having 2-10 stations not listed on the other. Currently that's my biggest problem- finding out where I CAN buy it.
I know of several not listed in WI-
Flood Oil, Eden WI any blend (seperate B100 tank)
Cenex Co-op, Broadway Ave, Madison WI ( B5 & USLD B5, Unmanned station)
Prairie Fire Biofuels (http://www.prairiefirebiofuels.org/) Madison WI (B100, Saturday only for now)
2006 Jetta TDI- TOTALED BY FLOOD
Thread- http://forums.tdiclub.com/showthread.php?t=146559
New 2006 Jetta TDI 5sp Manual Pkg1
lmoretti is offline   Reply With Quote
Old May 6th, 2006, 19:30   #22
Blue_Ridge_BioFuels
North Carolina
For example, we (Blue Ridge Biofuels) keep B99.9 and B20 available in Asheville, NC. (Gas-Up, 405 Haywood Rd., Asheville, NC 28806)
It actually does not take that long for NBB to create a listing, but they have never updated ours.
BRB
Originally Posted by lmoretti
Nope-
Blue_Ridge_BioFuels is offline   Reply With Quote
Old May 6th, 2006, 22:09   #23
Matt-98AHU
Matt-98AHU's Avatar
Two Ann Arbor, Michigan area Meijer's gas stations carry "Biodiesel." Labeled plainly as just that. When they initially offered it, they put information right on the pump that it was B20. Now it just says "Biodiesel" with no other information. It could be B100 for all I know (in all likely hood it's not. But there's no info).
All the online sources I find state Meijer's is using B20... No word on anything different yet. I've run several tanks of their "biodiesel" with no negative effects.
Meijer Fueling Station
3145 Ann Arbor Saline
Ann Arbor, MI 48103
This is the one I normally go to:
Meijer Fueling Stations
3995 Carpenter Rd.
Ypsilanti, MI 48197
Of note: I rarely see the Ann Arbor-Saline road store. I always goto the one on Carpenter as it's in between work and home. The biodiesel is always priced exactly the same as their normal "premium diesel."
Matt-98AHU is offline   Reply With Quote
Old May 7th, 2006, 18:50   #24
dhdavids
Default Houston Biodiesel
Houston Biodiesel
2970 Farrell Rd
Houston, TX 77073
GPS: N 29° 59.664 W 095° 22.390
http://www.houstonbiodiesel.com/
Just got my 2006 Jetta TDI, which now has 500 miles on it. Just added my first B5 mix. It seems to run quite well.
Houston Biodiesel sells B100 and B99. So you're gonna have to mix it yourself, if you want to run B5, or B20, or more.
dhdavids is offline   Reply With Quote
Old May 9th, 2006, 17:53   #25
Varkias
Varkias's Avatar
TDI(s): '02 Golf TDI
Fuel Economy: 46 MPG
Default Greenfield, MA
There is a station here in Greenfield, MA right on rt. 2A It's a shell, and they have B20 for $2.92/g. They just opened, don't have an address listing that I could find yet.
BBS, OMI, RC3 ASV, PP520, Smoke.
W h y s p a r k w h e n y o u c a n G l o w.
Varkias is offline   Reply With Quote
Old May 13th, 2006, 10:16   #26
edfcmc
TDI(s): 2000, 5 spd
Las Vegas, NV
Haycock Petroleum
b20 (need account with them and cardlock key)
B20 at automated card pump station:
300 W. Bonanza - A Street & Washington behind Valley Foods
Las Vegas, NV
Haycock Offices to acquire cardlock key
715 W. Bonanza Road
Las Vegas, NV 89106
702.382.1620
www.haycockpetroleum.com
edfcmc is offline   Reply With Quote
Old May 13th, 2006, 10:28   #27
eb2143
eb2143's Avatar
Fuel Economy: Lifetime average ~ 50 mpg
Don't Forget for Vermont:
Fleming's Shell Exit 1, I-91 Brattleboro, VT (.2 mi from exit)
2001 Jetta TDI 5mt 234,000mi, 46/50/58 mpg
Bosio Sprint 520s, Koni FSDs, VW HD Springs, 10mm spacer, Audi TT LCA bushings, 034 motorsports strut mounts, E-code lights, Audi TT "short"-shifter, IDparts rear sway bar, DG Panzer plate, Caterpillar 2µm fuel filter, Frostheater, GLI Recaros, GTI 3-spoke steering wheel, Audi S3 shifter, R-line stainless pedals
eb2143 is offline   Reply With Quote
Old May 15th, 2006, 07:45   #28
MrErlo
MrErlo's Avatar
Fuel Economy: lifetime 45.52, best 61.18
Omaha, Nebraska
Sapp Bros
I-80 144th St exit
Pump 1 and 1a
Nebraska Iowa Supply Company
3441 South 66th Street, just north of 66th and Grover
NOTE: only supplies in 100 gals or more storage tanks
they will blend to any B% you'd like
402-393-8350
2003 Golf 4dr, 120k
Omaha Biofuels Coop
VNT17, 11mm, G60/VR6, FM-100, side mount heater, FrostHeater
MrErlo is offline   Reply With Quote
Old May 15th, 2006, 08:05   #29
bheaston
B20 in Belgrade, Montana
Pacific Pride
163 Thunder Road
Belgrade, MT 59714
South from Belgrade I-90 Interchange
~200 yards south of Flying J Truck Stop
west side of Jackrabbit Lane
03 Jetta GLS TDI, 5sp, RC2, Sprint 520s
bheaston is offline   Reply With Quote
Old May 16th, 2006, 06:45   #30
scurvy
Good Ol' Boy
scurvy's Avatar
TDI(s): 2006 Golf
Fuel Economy: ☭☠
More Illinois locations:
Palatine Oil:
JR Fuels at 1100 N Ellis St. Bensenville IL 60106 - has B11 at pump #11
The road ranger station you list uses Palatine Oil Co's B11.
Al Warren Oil Co:
23150 E Eames, Channahon IL 60410
scurvy
You are entitled to your own opinion but not your own facts.
[SIZE=1mk4 front wheel bearing replacement | scurvy winter front | 2006 Golf TDI | 2012 Mazda 5 6MT | VCDS in Chicago, IL USA[/SIZE]
scurvy is offline   Reply With Quote
Premium Diesel Locations by State pyankura Fuels & Lubricants 25 March 26th, 2009 08:09
Diesel locations, prices in N.A Jetta_Pilot Ontario 3 July 13th, 2008 19:01
Locations for Methanol, NaOH or KOH, By State Schwrtz27 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 11 June 4th, 2008 12:03
biodiesel locations sailor55 Alternative Diesel Fuels (Biodiesel, WVO, SVO, BTL, GTL etc) 1 August 21st, 2002 07:32
Are radar detectors legal in your State/Province? Sacha General VW Discussion 23 July 20th, 2001 13:14
Page generated in 0.17957 seconds with 11 queries
[Output: 132.99 Kb. compressed to 111.21 Kb. by saving 21.78 Kb. (16.38%)]
