Drivbiwire said:
Flat spot in power is usually a symptom of a plugged intake. Power drops off around 2800 and power returns around 3,200 this is a plugged intake.
A dying MAF causes power to drop off around 2800 but the power never returns...
DB
In my experience (and I have a lot with MAFs), it is very hard to say exactly how the MAF will fail. Some are intermittent, some die suddenly, others gradually fade so that you don't realize the MAF was bad until you swap it.
Best diagnosis: VAGcom. Compare specified MAF to actual MAF readings. If you graph them, they should track very similarly.
Quickest diagnosis (if you have a new or known good one): swap it out and see if it helps.
You can also try unplugging it. If it's totally dead, it will help, but if it's intermitted or dying, it may not prove anything.
Dealers are fond of pointing to clogged intakes for everything but unless the intake is absolutely plugged up, it will not have as much of an effect on power as a bad MAF.
There are at least two spare parts I carry in each of my TDIs. One is a new MAF, the other is a new relay 109. If I don't need them, I know that I will come across someone who will
