donvieira
Instead of tapping into the intercooler plastic tube can you use the DG racepipe nipple to run the line to or is it too far away from the intercooler? Thanks, Don
Pressure is created by the restriction of flow. The turbo is providing the flow, the combustion chamber/intake valves are providing the biggest restriction. Therefore to catch the spike first, you want to pick it up as close to the restriction as possible - the intake manifold. The pressure wave then travels back through the intercooler tubing, then the intercooler, then finally at the outlet of the turbo. All the time this pressure wave is traveling from the cylinder back to the turbo (milliseconds), the turbo is putting out more flow than it was before you stomped on the throttle (at ~the same pressure), however it is going in to compressing the air in the intake, plumbing, intercooler and raising it's pressure. If you put pressure sensors at various places in the intake tract between the turbo outlet and the combustion chamber and had a fast data acq system or an oscilliscope you would see what I described above (along with the rebounding waves of decreasing amplitude back and forth between the turbo and combustion chamber after the first wave).bencarr23 said:thats where i would put the guage. it would tell you what is going into your engine . i would put the boostvalve as close to the turbo as pos. the quicker it gets the pressure to lower the spike the better
That makes sense. Would that then confirm car_54's assertion above?Fix_Until_Broke said:Pressure is created by the restriction of flow. The turbo is providing the flow, the combustion chamber/intake valves are providing the biggest restriction. Therefore to catch the spike first, you want to pick it up as close to the restriction as possible - the intake manifold. The pressure wave then travels back through the intercooler tubing, then the intercooler, then finally at the outlet of the turbo. All the time this pressure wave is traveling from the cylinder back to the turbo (milliseconds), the turbo is putting out more flow than it was before you stomped on the throttle (at ~the same pressure), however it is going in to compressing the air in the intake, plumbing, intercooler and raising it's pressure. If you put pressure sensors at various places in the intake tract between the turbo outlet and the combustion chamber and had a fast data acq system or an oscilliscope you would see what I described above (along with the rebounding waves of decreasing amplitude back and forth between the turbo and combustion chamber after the first wave).
Clear as mud?
