Old July 26th, 2000, 05:55   #1
SkyPup
Guest
Default More TDI Fuel Injector Information
My previous post on the VW 1.9L ALH TDI Engine Fuel Injection Equipment:
VE pump Type Bosch VE VP 37
Plunger dia. 10mm
Lift cam c1000 = 1.2 m/s
Pre-lift 0 mm
Cutoff cross-section 2 x 4 mm
Constant-pressure valve 60 bar /dia. 0.7 mm
Injector - Dual spring version, minimum dead volume
Lift I : 0.06 mm
Lift II : 0.25 mm
Nozzle P-type, VCO-nozzle
Hole dia. 5 x 0.21 mm
Pressure stage 4 x 2.2 mm
Opening pressure
PI :l80bar
II : 330 bar
Delivery angle 150
Length of hole 1.0 mm
Data from the 5-Cylinder 75kW VW T4 TDI Engine:
Bosch VE VP 37 Fuel Injection Pump
Injectors - Bosch P442
Data from the 5-Cylinder 111kW T4 TDI Engine
Injectors - P764
Injector - Dual Spring version, minimum dead volume
Lift I : 0.06mm
Lift II : 0.25mm
Hole dia. 5 X 0.216 mm
Opening Pressure
PI : 220bar
PII : 300bar
Christi, it appears that the T4 5-Cylinder 111kW TDI engine has the exact same Bosch VE VP 37 Fuel Injection Pump as our 1.9L TDI's do. The nozzles also match our 1.9 TDI's exactly too. The new upgraded high output fuel injectors on that motor are the "BOSCH P764" units. Does your European parts database have any information on these "High Output" Bosch fuel injectors? They would be a simple upgrade to any TDI 1.9L 4-cylinder produced since 1990, since they all utilize the Bosch VE VP 37.
I also have a list of all the Mercedes, BMW, Citroen, Renault, Fiat, Alfa, etc. 4-cylinder European diesel engines that also utilize the Bosch VE VP 37 Fuel Injection Pump.
If you could get ahold of these 111 kW T4 fuel injectors, I would be happy to purchase some!
Old July 26th, 2000, 07:04   #2
SkyPup
Guest
Default Re: More TDI Fuel Injector Information
Here is why I think this simple larger injector bolt-on may work very well with no changes at all to the ECU, especially if the new injectors are only a little bigger than standard.
With the MAF telling the ECU what mixtures are being run in most conditions and with the ECU capable of self-learning, a good long drive may be all that it takes for the ECU to compensate for the new injectors' flow rate. Over-rich mixtures run for a short time won't do any damage, and the ease and cost-efficiency of this approach leaves everything else behind.
The most likely requirement for these larger injectors would be that the output of the major load sensor (MAF & MAP) will need to be changed. If the ECU thinks that there is less load than there really is, it will reduce the pulse width (opening time) of the injectors. This reduced pulse width, coupled with the bigger injectors, means that the right amount of fuel can then flow.
In other words, if the ECU thinks that only enough fuel for 50hp is needed while a demand for 70 is actually required, it will pulse the injectors to provide 50hp of fuel. However, with the bigger injectors in place, enough fuel flow for 70hp will actually be injected! So, making the computer sense a lower engine load than is actually occurring will straighten-up the microprocessor and make the higher fuel quantity levels flow. Remember that in out TDI engines, power is directly proportional to fuel quantitiy!
Old July 26th, 2000, 07:29   #3
SkyPup
Guest
Read about the upgrade of the 75Kw engine to the 111kW engine here, look at the BOSCH VE VP 37 Fuel Injection Pump table with the list of the changes made to increase the fuel quantity to accomodate the increased power output!
http://<br /> <a href="http://trans...FVW-T4.htm</a>
Old July 26th, 2000, 08:23   #4
GoFaster
Moderator at Large
With all due respect, the injection pump that we have is a positive-displacement device. The quantity of fuel behind the cutoff sleeve is the quantity that gets injected regardless of the injector.
The injection may occur at a different *pressure* but the *volume* of injected fuel won't change, the way I see it. According to the specs, the only difference appears to be higher initial opening pressure and lower secondary opening pressure, the difference between 0.21mm and 0.216mm holes (a) is very slight and (b) could be due to someone cutting off the last digit when typing...
Brian P.
'96 Passat TDI
Old July 26th, 2000, 08:31   #5
SkyPup
Guest
Brian, I believe that at all time the VE37 is supplying an over abundance of fuel to the injector. The injector only uses what it fills up with, the rest is returned to the pump and then the tank. These other TDIs produce more kW per cylinder with the exact same pump, the turbo is upgraded for more airflow and pressure, the intercooler is increased in volume to handle that, and the injectors are increased in fuel quantity delivery rate (volume delivered per unit of time) to flow more fuel since the other upgrades are worthless without more fuel.
I believe the pump can easily handle more injector flow with larger injectors.
You are right though, in the the 5-hole nozzles are the same size, so therefore maybe more flow is impossible without more pressure. But, it certainly is worthy of a more complete investigation. From what I understand, replacement injectors sets only cost about $150, so could be a very worthy investment if it works as I imagine it could.
Old July 26th, 2000, 10:18   #6
SkyPup
Guest
[This message has been edited by SkyPup (edited July 27, 2000).]
Old July 26th, 2000, 10:39   #7
GoFaster
Moderator at Large
That's a cool animation ... of a GDI (gasoline direct injection) engine! NEAT!!
I suspect that the injection pumps with different part numbers have a different shape to the cam that moves the plunger back and forth, they might have a longer maximum effective stroke (or inject a greater amount of fuel over the same number of crankshaft degrees of rotation) as a result, but this is purely speculation ...
Brian
Old July 27th, 2000, 02:20   #8
christi
christi's Avatar
SkyPup, I will check the part numbers later on, I promise.
It might be a day or two..
1996 Passat Tdi estate (wagon (variant))
See my Peugeot / Passat site
christi is offline   Reply With Quote
Old July 27th, 2000, 05:07   #9
SkyPup
Guest
Thanks Christi, it sure takes alot of time to try to learn anything about these engines over here on this side of the Atlantic, I really appreciate your assistance. Now if I only had a password to the BOSCH TDI database with all this information so I could log on and print it all out!!!
This Site has the VW TDI CD-ROM containing everything and anything we wish to know and yearn to learn, somehow somwone has got to send me a copy!!!!!
http://www.boschservice.com/
Old July 27th, 2000, 05:16   #10
SkyPup
Guest
CD-D: Your information foundation for diesel assemblies and replacement parts.
Demand for ever-higher levels of metering precision is reflected in increasing complicated diesel injection systems. The levels of technical expertise needed to repair and service these systems are rising at the same time. CD-D from Bosch provides precise information for professionals, extending from data on individual spares to exploded illustrations showing diesel equipment assemblies. This CD also contains the ESI installation program, so operations that focus on diesel service can use it without loading CD-A.
CD-D: Comprehensive component coverage with exploded drawings
CD-D from Bosch lets you keep accurate tabs on the right replacement parts for Bosch diesel assemblies. Exploded drawings are often vital for identifying spares. This CD provides them - a simple click calls up clear and concise displays with assembly group assignments and a comprehensive listing of spare parts (with over 35,000 entries) along with order numbers. Extensive comparisons let you identify diesel assemblies based on their components.
Old July 27th, 2000, 05:18   #11
SkyPup
Guest
WHERE THE HELLO CAN I GET THIS CD?????????
CD-W: The diesel specialist's test spec. program.
CD-W from Bosch gives you test specifications for approximately 7,000 in-line pump combinations, with 10-digit Bosch order numbers, along with roughly 500 distributor-type pumps. This comprehensive service tool compliments CD-D (basic information for diesel assemblies) while also relying on it as its operating platform. To profit from CD-W's full range of features you will need Windows '95 and a 586 processor (e.g., Pentium).
CD-W: Test specifications and more for diesel assemblies
With CD-W you get the display you need at the click of a mouse. The on-screen data include portrayal and assessment of the test results, comparing them with specifications and also highlighting out-of-tolerance results in red. The program can also process test data by calculating averages and scatter ranges where required. All data are clearly correlated to facilitate comparisons, while deviations and tolerance violations are specially marked. When presented to your customers this test protocol will document your firm's high level of technical and professional competence in the area of diesel ancillaries.
Old July 27th, 2000, 09:25   #12
SkyPup
Guest
Christi, I was able to get this data off the German Robert Bosch site. It is for a GOLFIV model 1.9L TDI engine, one is the 90HP ALH exactly as what we have here in the US, and the other is for the 110HP AHF as what you have in Europe. You will note, there ARE different parts numbers for the injectors and springs! You will also note the Bosch VE VP 37 Fuel Injection Pump is IDENTICAL ! The only difference is the manual tranny pump uses a 10mm plunger whilst the auto tranny has an 11 mm.
Please check this info out on your end and see if this is what you conclude. If so, I can purchase a set of 110HP injector overseas and install them on my US spec TDI !
VW (VOLKSWAGEN) Golf IV 1.90 Liter 66KW (90HP); Limousine; Motor: ALH
Nozzle-and-holder assembly (2 springs) 0432193732
Nozzle change not possible in nozzle-holder assembly with needle motion sensor
Nozzle-and-holder assembly (2 springs) w. NBF 0432193734
Distributor-type fuel-lnJ pump WE 4/10 E 2075 R 700) 0460404977 For vehicles with manually shifted transmission
Distributor-type fuel-inj pump (VE4/1 1 E2075R712-1) 0460414989 For vehicles with automatic transmission
VW (VOLKSWAGEN) Golf IV 1.90 Liter 81 KW (110HP); Limousine; Motor AHF
Nozzle-and-holder assembly (2 springs) w. NBF 0432193744
Nozzle-and-holder assembly (2 springs) 0432193746 Nozzle change not possible in nozzleholder assembly with needle motion sensor
Old July 27th, 2000, 15:16   #13
Electron Man
Skypup,
If I'm not mistaken, the AHF (110HP) motor has 20:1 compression, while the ALH (90HP) motor has 19.5:1 compression.
Probably won't make much difference though; I'd suspect that less than 10% of the additional 20HP and ??lbft of torque could be attributed to the higher compression.
Source: wetterauer.de
Keep up the R&D!
[This message has been edited by Electron Man (edited July 27, 2000).]
Electron Man is offline   Reply With Quote
Old July 28th, 2000, 00:07   #14
diesel des
Election Man, I believe the 90 and 110 are both the came CR of 19.5:1. I think its a mistake on the web site. A higher output turbo diesel generaly has a LOWER CR. Eg the VW race tdi ran 18.5:1. My tweeked TDI now has a CR of 18.7:1.
Skypup, to sum up, what exactly do you thing the diffrence in the injectors are? Is it that the higher output versions have a lower injection pressure? I suppose this would be one of the reasons that they are dirtier engines. They do hace the same holes though?
Going by the info you gave, it may be possable to convert 3 of the 90 injectors to 110 with a diffrent nozzle and spring, but you need to buy a number 3 injecter due to the lift sensor.
I can give you a contact for the 110 injectors. It is the same place i got my injectors and parts car. Email me if interested.
[This message has been edited by diesel des (edited July 28, 2000).]
diesel des is offline   Reply With Quote
Old July 28th, 2000, 09:41   #15
SkyPup
Guest
Diesel Des, it appears that the only difference is the shim thickness for the springs to increase injection quantity, the opening pressure does not appear to have anything to do with fuel quantity and is mostly for emissions purposes. To date, this is the only reasonable theory left, however it does seem to hit a dead end as there is absolutely NO WAY you can change out three injectors and leave the #3 signal injector alone, it would unbalance the engine.
One thing is apparent to me however, the 90HP ALH & 110HP AHF both have the same displacement, same fuel injection pump, same turbocharger, and same MAF sensor. IMHO, only the ECU fuel maps and injector shiims are different. I should be able to add 20HP with a set of these injectors.
I'll talk to you next week via email after I do some more research and hear back from Christi about what he thinks. I'll also check into the turbo questions you asked too.
Page generated in 0.17888 seconds with 9 queries
[Output: 113.95 Kb. compressed to 94.67 Kb. by saving 19.28 Kb. (16.92%)]
