Ok here are some picts
Alright finally got around to doing some pictures, this is no wingnut how to but hope it helps.
I first started with a raw piece of 36" x 36" and put my old skid plate next to it to determine where some of the bends will be, looks like I did a total of about 10 bends or so give or take.
So I started off with a square piece and did my rough bends and made it as close as I could, then layed my old skid plate on top and traced out the shape and took it to the band saw. Then took it to the belt sander and sanded it down to size as needed. One thing I would recomend is that if you decide to mount it like I did and I took two coupleing nuts and welded them to the frame, make your skid plate a little bit longer so that you can weld the nuts on the flat part of the frame, mine ended up being a bit short and so i made a couple plates to weld the nuts onto. Or probably the best way to do the rear to mounts is the riv nuts and bolts you can purchase from the dealer.
Here and a few pictures of the final product as i didn't tink do do a step by step photo of each till after it was all done.
Also in these pictures you can see I had it installed for a bit but my suspension is waay to soft and all the speed bumps hit, guess that's what ya get for lowing the car and with 209k kms on it the suspension seen better days.
As you can see the top two holes here is where I mentioned should be a little longer to accomadate a flat surface on the frame to weld the coupling nuts on.
This is taken from the lowest point of the skidplate as you can see just under 2"
I also fabricated 3 clips where the OEM one slides into the front valence for support. These are 1.5" x 3" with a joggle in the middle to slide where to OEM ones do.
It sits in there fine but after some thinking I will see about adding some supports like the DG and EVO skidplates have for more support, mind you I think that if there is an impact big enough to dent the 0.100" material I may have more to worry about than the skidplate but nothing wrong with being safe than sorry.
The first two I made with a friend and it took us about an hour and a half maybe two and a half to bend and cut the material. This being the third one took about the same amount of time plus the paint shop time to make it all nice and shiney blue. Plus maybe about a half hour or so of final tweaking at a fellow tdi club members place running back and forth from under the car and his press to make a perfect fit.
Hope this helps a bit.
