Old March 17th, 2006, 20:05   #1
jettanut
Default OBD2 code P1556
What does a Charge Pressure Negative Deviation code (P1556) mean on a 2001 Jetta TDI? Jettanut
jettanut is offline   Reply With Quote
Old March 17th, 2006, 20:43   #2
BudsBug
Did you just replace your MAF or clean you intake? I got one of those when playing the night I got mine a new MAF. I reset it with the Vagcom and it never came back
Y2K Buglet {2000 NB} :-}
BudsBug is offline   Reply With Quote
Old March 18th, 2006, 06:39   #3
jettanut
Default P1556
Yes I did just replace MAF and have gotten this code and reset at least 6 times. Thanks
Old March 18th, 2006, 07:28   #4
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
You need to test your N75... could also be a leaking vacuum line or a stuck turbo actuator...
How many miles on the car??
Do you have access to a Vag-Com ???
Where are you located? Perhaps there's a TDI specialist not too far away...
Yuri.
ymz is offline   Reply With Quote
Old March 21st, 2006, 03:59   #5
jettanut
Default P1556
121,000 miles, just replaced Timing Belt about 119,500. Replaced MAF Sensor about 120,000. I live in southern part of Shenandoah Valley in Virginia just off I-81. Nearest dealers in Roanoke or Staunton Virginia.
P1556 very interm.
Old March 22nd, 2006, 23:09   #6
guidoman
Fuel Economy: 42-45
Default Check your hose connections after the intercooler
I got the same code and it was a clamp that was positioned improperly on the bottom of the intercooler allowing air to leak out!
Look there it won't cost you anything!
Guidoman
guidoman is offline   Reply With Quote
Page generated in 0.12140 seconds with 9 queries
[Output: 65.92 Kb. compressed to 57.03 Kb. by saving 8.88 Kb. (13.48%)]
