Old February 2nd, 2006, 19:50   #1
grattanboy
Fuel Economy: 98 52mpg 02 51 03 49mpg
Default fuel shut of valve (n109)
On my way home from work when I noticed that I lacked a little power driving down the highway. Got home and put the Vag com on and got a
01237 Fuel shut -off valve (n109) 04-00 mechanical malfunction. What should I do first, I notice today that when I started me car it reved up then back down to idle. thanks Mike
98 jetta
grattanboy is offline   Reply With Quote
Old February 3rd, 2006, 07:31   #2
jck66
jck66's Avatar
It might just be the gasket that has become dislodged. This is a fairly well documented issue with the A3 Jetta TDI. Some poking around on the forums should give you more detail. Or maybe some kind Jetta-driving soul will chime in.
jck66 is offline   Reply With Quote
Old February 4th, 2006, 06:39   #3
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
fuel shutoff o-ring has probably fallen out of place. Happened twice on my 98 and I've only got 94k miles on it.
Easy to fix, a little hard to get at.
You need to remove all the injector lines.
The fuel cutoff solenoid is directly above where the injector lines go into the pump, can't miss it as it has a single wire going to it.
Need a crowesfoot wrench or be very skilled with channel locks to unscrew the valve.
Once you pull it out, you'll see the o-ring has probably slid down the shaft and won't allow the FCV to function properly.
carefully without loosing the o-ring push it back up the shaft to be snug with the base of the FCV.
Reassemble everything and you're back in business.
I can do it in about 15 min, but I've also done it more than once!
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old February 5th, 2006, 03:39   #4
Toronto_Vento
Toronto_Vento's Avatar
Fuel Economy: 50/48/44
I just took mine out to check on the o-ring. I didn't have to take any of the injector lines off, but it shure would have helped. It's an 8mm nut at the top, and I think a 24 mm for the actual N109. I didn't have a 24mm at work (long story), so I tried a 15/16th wrench. If possible, use the correct size wrench, but gently using the 15/16th loosened the thing, and got it tightened up.
-- John K
Wingnut's HOW TO's thread
"The commuting system is so badly broken that it will take decades just to bring it up to a level where it is merely malfunctioning." - Globe Drive
Toronto_Vento is offline   Reply With Quote
Old February 5th, 2006, 05:18   #5
dave333
waaaaay, way cool info....
this kind of readily available, intimate knowledge of our cars and motors is one of the main reasons I bought mine...
dave333 is offline   Reply With Quote
Old February 6th, 2006, 18:05   #6
grattanboy
Default fuel shut off
Thanks for the info. My o-ring was in the right place when I pulled my valve Saturday. I made sure everything was clean when I put it back together. I still had the same problem of little power over 2000 rpm. Tapped on the valve and took it for another drive and the car was back to normal. I orderd another valve thinking the other one was sticking or dirty. thanks for the help.
Old February 6th, 2006, 18:20   #7
paramedick
paramedick's Avatar
Curiousity question.
Could this account for a 1Z that "hiccups (occasional miss)" at only cold idle? New behavior for the B4 for the last week or so.
Thanks, Bruce
Old February 7th, 2006, 09:55   #8
Toronto_Vento
Bruce, technically, if the N109 doesn't open or close properly, it could mean that the fuel isn't being thrown into the engine at the right quantities. This check is one of those things which will take you 10-15 min tops to take a look at. Might be worth it just to see. If the o-ring is in place, and tapping it doesn't change anything, then it's obviously not the source of your issue. I pulled mine apart, as I said, because when the car is cold, and the temperature is below freezing, I can get a bit of an RPM spike when starting (something like to 1500-1600 RPM). The o-ring was lined up, and everything seemed to be fine on my N109, so obviously this is coming from something else.
-- John K
Old February 12th, 2006, 10:11   #9
MattBissell
Drivbiwire is suggesting that this solenoid may be the route of my low power issues which I have been fighting for over a year, he says that I should replace it, anyone know where I can buy one? 1stvwparts.com brings it up but won't give a price or put it in the cart? Can't find on TDIparts.com or Impex. HELP!
Matt
1996 Passat E-codes, fogs, Neuspeed sway & strut bars, CAT filter SOLD
2003 GMC Sierra Duramax/Allison FOR SALE
2012 Golf TDI 4D, DSG, Shark Blue
MattBissell is offline   Reply With Quote
Old February 13th, 2006, 07:55   #10
grattanboy
Default fuel Shut off
I found one for my A3 at www.worldimpex.com/index.html for $89.00. I ended up buying one at the dealership for the same price. Comes complete with spring and plunger. IMPEX SKU # 177697
Old February 13th, 2006, 15:46   #11
danix
danix's Avatar
No one has asked me for one before.
Part number appears to be 028130135F, and the number for the seal is 068130139. Both items appear to be dealer only, but I will make a call in the AM.
danix is offline   Reply With Quote
Old February 13th, 2006, 19:09   #12
MattBissell
Thanks for the part number Dan, Auburn VW has them for $66.61, don't know if I'll buy one or try the o-ring first?
Old February 14th, 2006, 12:03   #13
jck66
jck66's Avatar
I'm interested to hear if paramedick has any follow up to this as previously only Jetta owners have reported this problem. I can't imagine that the parts are that different between 1Z and AHU.
Old February 14th, 2006, 15:23   #14
paramedick
paramedick's Avatar
Haven't had time to follow up on it. AND, my tools are split between two houses right now. Guess where the big metric tools are?
Old February 15th, 2006, 11:04   #15
jck66
jck66's Avatar
Um, the house where your car and butt aren't?
Page generated in 0.17383 seconds with 9 queries
[Output: 120.85 Kb. compressed to 99.87 Kb. by saving 20.99 Kb. (17.36%)]
