Old January 7th, 2006, 20:54   #1
sb765t
Fuel Economy: 40 mpg avg
Default rear trunk latch wont latch
so...
a couple weeks ago, i opened the trunk with the key fob, and it won't latch. luckily, it stays closed by itself, and looks latched...but...it'd be really nice to have a working trunk again.
anyone have any suggestions for this one?
thanks,
Evan
Raleigh, NC
'01 Jetta, TDI, 113k
Evan Purser
sb765t is offline   Reply With Quote
Old January 8th, 2006, 12:48   #2
emile
Fuel Economy: 41.2mpg us
i had this issue on my '05 golf. the sensor in the trunk latch was faulty. it would mechanically latch but the sensor would not trigger the lock. i had it replaced under warranty.
'05 golf gls tdi (pd) 5-speed reflex silver
emile is offline   Reply With Quote
Old January 12th, 2006, 18:07   #3
rixtory
Fuel Economy: 51/47/44
Same issue in my 02 golf. Replaced under warranty but took over a week to get the part from Germany.
rixtory is offline   Reply With Quote
Old January 15th, 2006, 14:46   #4
mjghh
Default Spring
There is an internal or should I say "infernal "spring in the latch assy that can be knocked off by the plastic cover that envelopes that assy. I had to remove the plastic that had broken off and reinstalled the spring with a set of angled needlenose....delicate operation but saved a bunch of money and time.
mjghh is offline   Reply With Quote
Old January 16th, 2006, 11:15   #5
Radman
Mine failed because of a leaking wiper/washer motor that corroded the connections. Common on Golfs and Wagons.
2012 Passat TDI DSG
2014 Touareg TDI
Radman is offline   Reply With Quote
Old March 18th, 2006, 13:54   #6
Dante Casali
Fuel Economy: 51.2/45/34---from Pike's Peak
My latch also does not latch anymore. I can close the trunk, but it gives me a 'door ajar' light on the dash and the horn does not sound when I lock with the keyless entry fob.
It did this on occasion before when it was very cold, but now its stopped completely.
If I open the hatch, I can rotate the 'locking hook' on the hatch release with my fingers until it is in the 'closed' position and the alarm then 'locks' and the horn beeps its 'locked' signal. ...but the trunk locking hook does not stay in the closed position. It returns to the open position.
The Hella brand trunk release motor seems to be working fine, and its still attached to the trunk lid, its arms appear to be moving the pieces they are attached to.
I have read about the 'spring fix' where you either repair the broken spring or replace it with something else like a rubber band. I keep a fair amount of tools in my car and I would hate for someone to take them so I need to fix this correctly.
Any suggestions?
Keep on Dubbin'!
02 Golf GLS TDI 5 speed.
Dante Casali is offline   Reply With Quote
Old March 18th, 2006, 15:38   #7
Dante Casali
Fixed!
I removed the trunk latch using my 12 point torx bits and removed the plastic cover. After cleaning all the junk outta it with some PB Blaster, I put dielectric grease in the 3 pin sensor and a bunch of white litheim (sp?) grease in the lock mechanism.
Im guessing that the latch couldnt rotate enough to lock properly.
Keep on Dubbin'!
Old May 5th, 2006, 09:48   #8
dieselron
Default trunk latch won't latch
Originally Posted by Dante Casali
Fixed!
can anyone be more specific on removing lock to clean and lube?
dieselron is offline   Reply With Quote
Old May 6th, 2006, 07:09   #9
weasel
Deactivated Member Account
TDI(s): None.
Most likely it will be the srping inside. Remove the latch from the car and look inside the mechanism. There are pics around here somewhere to show what it looks like but when its in your hands, the problem is really apparent.
weasel is offline   Reply With Quote
Old October 4th, 2006, 18:06   #10
Mr_Moe
TDI(s): .
Mine just went today, when I was driving home from the dealership...
2001
Mr_Moe is offline   Reply With Quote
Old October 29th, 2006, 14:26   #11
cynapsesystems
TDI(s): None
Smile Trunk latch spring fix.
Just wanted to thank weasel for the trunk latch tip. My 2001.5 Passat (non-diesel.... not available back then, waiting for common rail technology now), trunk latch failed but I was able to:
  1. remove the upholstery from the inside of the trunk (by carefully prying around the edges),
  2. remove the latch from the trunk lid using a 10mm socket wrench on the two nuts. Had to pry a little at the trunk metal to get the socket in here.
  3. removed the black plastic surround on the latch that peels back and unfolds around the latch,
  4. and finally see aforementioned weasel's spring languishing.
  5. I then used a darning needle to hook the spring back on to the latch.
  6. reassemble, check, hey presto. I've been saved a bunch of hassle and cash.
Thanks again!
cynapsesystems is offline   Reply With Quote
Old November 2nd, 2006, 11:09   #12
Mr_Moe
TDI(s): .
Thanks again!
That's how I fixed mine.
The most time consuming part is removing and installing the upholstery.
Old November 2nd, 2006, 11:35   #13
weasel
TDI(s): None.
Yay !! I am finally good for something. Now send me a beer ....
Old November 16th, 2006, 20:11   #14
phishfood
phishfood's Avatar
Thanks, my trunk latch just stopped working tonight and tomorrow I'll this!
phishfood is offline   Reply With Quote
Old July 9th, 2010, 13:46   #15
grg144
Thanks again!
Same problem on 2003 Jetta GL sedan. Same fix except for:
  1. remove the upholstery from the inside of the trunk (by removing the phillips-head screws),
  2. <same>
  3. <same>, then remove the white insert with the two studs on it to which the black plastic was attached (to do this, you may have to detach the electical cable, the wire cable, and the metal rod with the black plastic fitting)
  4. <all the rest is the same, but I used a wooden barbecue skewer instead of the darning needle>
Whole thing took 30 minutes, including several trips back in the house for tools I should have thought to bring.
Many thanks, all, for saving me lotsa $$$!!!
Gary Grossman
in the VA Piedmont
2003 GL Jetta TDI Sedan
2004 GLS Jetta TDI Wagon
grg144 is offline   Reply With Quote
Page generated in 0.15432 seconds with 9 queries
[Output: 118.31 Kb. compressed to 97.92 Kb. by saving 20.40 Kb. (17.24%)]
