Old December 17th, 2005, 18:07   #1
pete_ski
Default Crash Sensor Side Airbag
I have a 2002 Jetta VR6 with 7200 miles, yes thats not a typo,its the wifes car. It just went out of warrany on 10/29/05. Guess what.... the airbag fault came on just the other day. I found a member of the TDI club
the vag-com. Ran the test this morning. Here are the results
Saturday, 17 December 2005, 08:22:22VAG-COM Version:
Release 504.-DControl Module Part Number: 6Q0 909 605F
Component and/or Version: 04 AIRBAG VW6 0202 0004
Software Coding: 12340 Work Shop Code: WSC 000661
Fault Found:01222 - Crash Sensor Side Airbag;
Passenger Side (G180) 37-00 - Faulty
Anyone....Bueller......Bueller
pete_ski is offline   Reply With Quote
Old December 17th, 2005, 21:00   #2
MOGolf
MOGolf's Avatar
Try locating the connector for it, unplug, and replug. Then clear the code. If it comes back, you'll have to have it professionally tended to.
MOGolf is offline   Reply With Quote
Old December 17th, 2005, 21:19   #3
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 56.3/44/41
Also, be aware, that if the airbag light is on, the whole system is probably deactivated.
Have you tried clearing the code allready?
-J
Present:
2012 Passat SE TDI DSG. 24,000 miles. Factory Alarm & LED tails 38/48 MPG.
99.5 Jetta "GLX" TDI. 289,000 miles. Half way there!!! Power Memory Seats, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 222,222 miles, 70,000 on engine. 18/27 MPG.
Past:
1988 Audi 5000S, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
Old December 18th, 2005, 07:29   #4
penclnck
penclnck's Avatar
Fuel Economy: 49.8/46/36
-J
That is the great unknown.... I've never been able to get a solid answer from anyone at VW about that...
At any rate, sounds like the side impact sensor is crapped out for whatever reasons. It isn't all that hard to replace, it is located under the front end of the passenger seat, you will need to pull the carpet up some so you can snake your arm under there with a 10mm tool to remove the old sensor and install the new sensor. A little awk-a-ward but do-a-bull. Don't know about the cost of the sensor though.
I have my doubts the DTC would clear since it isn't listed as sporatic, but it never hurts to try.
Pencilneck blah blah blah
OEM wheel database... see it before the lawyers do!
Terminal Release Tools
OEM butt connectors
In-Car Video Camera Mounting Kit
2004 TDI PD wagon VNT-17, 3 BAR, stage 3 clutch kit, flash by Kerma
penclnck is offline   Reply With Quote
Old December 18th, 2005, 09:35   #5
pete_ski
Yes I did try to clear the code..did not work....Which connector is it? there are three......I have Power seats and heated seats. I called VWOA
and complained...They said to take to the stealer. If I have to unplug it
do I disconnect the battery? for how long? Also if I do replace it with a good one will the light go away? Thanks all for the input.
Old December 18th, 2005, 10:13   #6
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Compu_85>>if the airbag light is on, the whole system is probably deactivated.<<
Penclnck>>I've never been able to get a solid answer from anyone at VW about that<<
Wingnut and I were just talking about that last night... (BTW: Thanks for adjusting my timing!!!) I suspect that for liability reasons, unless there's a total airbag system shutdown (controller meltdown, electrical problems), they would not disable the entire airbag system because one part of it may be not functioning...
Yes, it would be nice to get a concrete answer from VW, but possibly for liability reasons, again, they won't confirm or deny anything...
Yuri.
ymz is offline   Reply With Quote
Old December 18th, 2005, 10:25   #7
MOGolf
MOGolf's Avatar
What does air bag module measuring block group 005 block 2 have for a value? And group 009 block 2?
Old December 18th, 2005, 16:28   #8
Sebastian
Block 008 Field 2 would be interesting too...
http://www.ross-tech.com/vag-com/dow...09-605-VW5.lbl
Sebastian
Sebastian is offline   Reply With Quote
Old December 18th, 2005, 18:06   #9
compu_85
Gadget Guy
compu_85's Avatar
Looking at that label file, it looks like turning off a spcific air bag is as simple as adapting the right block. Am I reading that correctly?
-J
Old December 18th, 2005, 18:09   #10
Sebastian
It also says:
Note: Refer to Service Manual!
Most of them will state that additionally a hardware change is necessary, e.g. putting a resistor in.
Sebastian
Old December 18th, 2005, 20:21   #11
compu_85
Gadget Guy
compu_85's Avatar
Okeedokee.
Old December 23rd, 2005, 14:50   #12
pete_ski
Well here's what happened, Called VWOA they said considering the low miles and it was only out of warranty for two months thay fixed crash sensor no cost to me. Maybe there still hope for VW? Thanks for all the input. Looks like I'm going to be looking for a Bently's manual and Vag-com cable.
thanks
Old December 23rd, 2005, 16:12   #13
DickSilver
If anybody wants to disconnect an airbag (instead of getting punched in the upper extremities hard enough to break your neck) just unplug the airbag connector and plug in a small resistor. The value per experimenting on my 2004 Passat TDI needs to be between 1.8 and 2.2 ohms. The resistor's leads should be cut as short as practical, and then it should be snugged up to the connector with a bit of electrical tape.
It is useless getting angry at your car: don't let nuthin' whup you that can't talk....
B5.5V TDI, chainless, Rocketchip 2, No EGR, 170K
2012 Golf 2.5, 4 door
DickSilver is offline   Reply With Quote
Page generated in 0.17105 seconds with 9 queries
[Output: 108.61 Kb. compressed to 90.36 Kb. by saving 18.25 Kb. (16.80%)]
