Growler said:
what I think you want happening is you want Manifold (boost) pressure on both sides of the diaphram to keep them equal.
Exactly. Then the spring, which is on the vacuum side of the diaphram, will always hold the valve closed under all boost levels.
Growler said:
altho, the tear in the diaphram might already provide this. what is happening is the oil from the CCV is forcing itself thru the diaphram under boost, causing the slobbering we are seeing.
No! The oil is not coming through the diaphram. The oil is leaking from the inside of the manifold, around the valve stem, and into the atmospheric side of the valve, then out the vent hole. The diaphram seals this side from the vacuum chamber on the top of the valve. I'm not saying that the diaphram can't leak, but it's not a factor in this particular situation being discussed.
Growler said:
if we do as you say and put a nipple into the manifold where the vent hole is, and another into the pressure side and connect them via a vacuum type line,
where there is supposed to be vacuum to open the EGR port, there will be boost pressure, I am not sure what that will do to the N2xx valve (not the N75) having the vent hole open to atmosphere I think prevents this problem, however having the vent on the underside is allowing the slobbering...
You don't have to add a second nipple to the pressure side (I think you meant to say vacuum side--the EGR valve does use vacuum to operate)--use the one that's already there. My instructions are assuming that the ('cough, ahem') valve will be disconnected from its control solenoid and non-functional (hose from control solenoid plugged, or connected to the epsilonian device
). The only way that the valve can remain operational is if the atmospheric side of the valve remains at (or slightly below) atmospheric pressure. But if the valve stem seal is leaking, this will then allow a boost pressure leak (size/amount of leak undetermined). Hmmm, what to do, what to do?
Growler said:
I am wondering if maybe we leave the system the way it is with the vacuum line hooked up, and the diaphragm torn (assuming the diaphragm is between the manifold part and the vent part...) wherever it is torn open. What I want to do is plug the existing vent hole (JBWeld) and open a new one on the top of the manifold with a drill bit. it will provide as place for the boost pressure to escape like the existing system does, AND allow for the collection of a little bit of oil until it fills the pot to the level of the tear (wherever that may be).
I would not do this--what you are describing is creating a boost leak--you don't want pressure to leak out of your intake manifold at all.
Growler said:
basically I am banking on the chance that the tear is not at the very top of the diaphragm and the oil level will never reach the top vent hole to slobber out.
does this make sense to anyone else?
Like I said earlier, I don't believe that a torn or leaking diaphram has anything to do with the oil leak. I originally jumped into the discussion because of the possibility that plugging the vent hole could cause the EGR valve to open under high boost levels (which is not desirable).
