| Other TDI/Diesel Picture Gallery Do you have a TDI or Diesel not listed above? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle. |
December 15th, 2005, 14:42
#1
ToofTek Inventor
1985 Mk2 Jetta NA Diesel - will be mine 2005-12-17 :D
Edit: This car is now totalled.  See here: http://forums.tdiclub.com/showthread...81#post1376181
52 horsepower (at 4800 RPMs), 71.5 foot/pounds of torque (at 2000 RPMs) of diesel soot fury (actually, except on startup, I haven't seen it smoke...)
I'm picking it up SATURDAY!
Two other pics in the album: http://my.opera.com/bhtooefr/albums/show.dml?id=22244
1992 mazda miata | sprint booster delete, eats cones for breakfast, lunch, and dinner
1986 volkswagen golf diesel | bucket o' parts, pees in my driveway | parting out now, buy some parts!
i'd rather you be honest with me than try to be nice to me
December 15th, 2005, 16:08
#2
Congratulations!
--Ben
December 15th, 2005, 16:46
#3
Its about freakin time you got yourself a diesel.
2004 Jetta TDI 17/22, RC3, 3bar, 2.5 DP no cat with magnaflow muffler after DP to 2.5 straight pipe, 17" Monte Carlo wheels, Eibach Pro-Kit Springs, Koni Yellow's, 337 front/rear brakes, GLI brushed alum. interior trim.
http://www.cardomain.com/ride/788097 2009 TDIFest Peoples Choice Winner
December 16th, 2005, 07:36
#4
ToofTek Inventor
And, tomorrow, I'm getting it...
I've gotta get the TB changed, then fix the odometer, and then it's modding time.
First, a ventectomy. I might be the first to attempt an A2 ventectomy, however...
Second, make sure that it says "JETTA DIESEL", not just "JETTA" on the back - I found a "DIESEL" badge in the same font as the A2 "JETTA" badge on eBay
December 16th, 2005, 09:17
#5
Banned
No need for a ventectomy on a NA... nothing to clog. If you have oil blowby, you need to re-ring the pistons, easy to do... drop the oil pan, 2 bolts per connecting rod, number the rods/pistons, re-ring, put each one back in the hole it came out of.
How to check if rings are bad? hard to start when cold, blue smoke.... Or you can take the car for a drive to warm it up, leave the motor running, and carefully remove the oil cap.... If you have massive amounts of smoke inside while running that blows out the oil cap hole when you remove it, You've got blowby, could be you've got bad bores or need to re-ring. These motors will got 400k miles easy, usually need reringing at 200k, 300k and every 100k from there until you decide to bore them out. Lower bearings last forever in these 1.6 NA's.
For more power to the wheels, disconnect the power steering belt. These things are not safe on highways or interstates where the majority of traffic drives over 65 or 70.... You can not safely accelerate up to speed to merge with traffic.
Makle sure you check the tensioner after 1000 miles after doing your timing belt.
If you need to be cool, just get a K&N sticker for your air cleaner box, forget about the K&N aircleaner itself, they wreck motors by passing too much dirt and you will get zero increase in performance with them, sitck with the paper elements.
Do a new stock Mann air, oil and fuel filter, and run a good CI-4 rated oil like Rotella T or Delo 400 petro based oil, and please dont crash it!!!!!
That means that if you are a Newbie driver, pay attention to your driving and not the music channel, your cell phone, or your passengers goofing off next to you, or the soda you just dumped in the passenger seat from the drive through at Mickey D's.
See you soon in the Economy section in the Monthly MPG contests.... You should see 42 in winter around town, 46 in summer, and if you are really good with driving techiniques and do a flatland freeway trip at 60mph in summer with no stops, you might see 52 or 53 mpg.
Stick to stock sized tires and rims... anything wider or larger will kill you on acceleration rates.
This thing is a classic, Mods are to be strongly discouraged. You can redo the odo if you can search and find a new plastic drive gear for the cluster somewhere and install it. Plastic gets brittle and cracks, odo then no longer works.... Easy fix.
December 16th, 2005, 09:23
#6
ToofTek Inventor
What power steering belt? This one has no such thing.
Also, by "ventectomy", I mean -ectomizing the FUEL TANK vent. So I can get 15.6 gallons in without pushing in the little button, instead of 14.0.
There was some white smoke when starting, but once it was started (just had to give it some pedal until it was going), no smoke at all. And, the cold start handle that I've read should be pulled above 15*F was not pulled - that should help the smoke.
December 17th, 2005, 10:53
#7
Banned
My mistake... I'm not certain if by 1985 power steering was even an available option. It was on A2's by 89 through 91. I don't even know if you just had a straight vent tube with no valve at the fill up neck, venectomys I think started later than 1985???? Certainly not an option on either my 81 A1 or my 83 Audi5000TD.
How far are you driving that 1 gallon is going to make a difference for you that a venectomy is an important mod?
White smoke is normal at start up in 20F or colder weather... it is incomplete combustion of fuel in the swirl chambers on an IDI motor.
Getting good fuel with Cetane additive is very important for you in northern climates if you want your car to start. Timing belts stretch and make it hard to start also. Thats another way of knowing you need a timing belt, because your injector pump timing gets retarded and they become stubborn to start and your idle speed will be lower due to the retarded timing.
Start up procedure:
No need to gas it intitially when it's cold, you'll just wet the swirlchambers with excess fuel. Listen carefully to when the engine starts to pop on a cylinder or two, then gently give it a little go pedal until all the cyinders start firing. You may even have to cycle the ignition key twice to get the glow plugs hot enough to get it to pop.
Keeping your car in a heated garage will make it much easier to start in cold weather in the mornings, don't know if Dad will let you do that. Sure helps a diesel engine alot more than it does a gasser though.
Remember, this is a diesel, not a gas car... You drive a diesel for torque, a gasser for HP.... they are on completely opposite ends of the rpm range. Since you don't have a tachometer, pay attention to your upshift arrow on the dash. Use it wisely and short shift the motor. Gently accelerate in cold weather until you water temp comes up to full temperature, which might take 5 to 7 minutes in the winter on really cold days. Idling the motor will not warm it up, drive it gently to get things working. Diesels in winter are cold blooded and efficient, so get used to wearing your jacket, gloves and tuk until the heater starts working while you are driving.
What state are you in? Nortern tier state?
December 17th, 2005, 11:19
#8
ToofTek Inventor
I'm in Ohio.
We don't even have a garage that has room for a car, and where I'll end up moving to won't have *ANY* garage at all.
I suspect that the shift light isn't hooked into the alternator, so I'll have to do that, or use the recommended shift points on the speedometer (however, there's no recommended shift point to exit 4th gear...)
I put fuel in today, and there was DEFINITELY a vent button in there. I only put $10 in, though - didn't bother filling it because the odo's busted (we definitely didn't need a full tank, and mileage numbers are wildly inaccurate without an odo).
And, the ventectomy thing was just so that I could try to join the 700 mile club - that's unlikely without venting (don't want to run it dry, after all, especially considering it's a VE). (I guess I could vent manually for one 700 mile club entry, but...)
My manual mentions something along the lines of "Power Steering*" with the * being defined as "* where applicable" (translation: it's an option, and mine doesn't have it).
December 17th, 2005, 17:20
#9
ToofTek Inventor
OK, so I was wrong about the color...
Checked the color sticker, it said LA8V instead of LA7V. So, I checked. Quartz Grey Metallic, not Polar Silver Metallic.
December 17th, 2005, 18:31
#10
Nice ride! I wouldn't worry about removing the vent, as you can easily push the little nipple with the fuel filler nozzle and get an extra 3/4 gallon or so in there...there isn't as much of a difference on the older ones as on the newer ones.
MOGolf has inquired about the correct tools, you may want to check out eBay actually as I have seen the dial indicator sets on there every once in a while for very cheap.
Your '85 may have solid lifters, if so you'll want to check the valve lash (easy to do, but to adjust you'll need a shim assortment and the nifty little valve depresser tool).
Sucks that it doesn't have power steering, makes them much nicer to drive...but yours will be much easier to work on. The power steering always seems to be in the way under the hood on the A2.
I'd plan on checking all the stuff I listed in another thread, and if you do a timing belt plan on replacing the 3 front seals, int. shaft retainer o-ring, and water pump (possibly the pump housing as well, which is easy but time consuming).
Don't worry about cold starts, so long as the engine is healthy, glowplugs are good, battery is good, starter is good, and not too thick of oil (I run synthetic 5w40 year round in mine) it'll start right up. None of my diesels have ever failed to start even in single digit weather after sitting out over night. They are slow to warm up, however. And if your HVAC case's blend doors' foam is coming off as many do your heat won't work as well as it could.
I'd also get some G11 (blue) coolant. It'll save the car from the common radiator and heater core woes so many A2s have had over the years...except my '91 which has never had any green coolant in it at all!
December 17th, 2005, 18:47
#11
ToofTek Inventor
Hmm... so THAT could be why it was kinda lukewarm when it was finally warmed up...
I'll go dig up that thread, too, and just go through and make sure on everything.
I'm going to order a Bentley soon, this *(#@ piece of *#$( Haynes gasser manual that the guy threw in for free is totally useless. Totally. Heck, it'd still be totally useless if I had an 85 Jetta GASSER!
December 17th, 2005, 20:07
#12
Banned
Like I said, Jacket, Gloves and Took, Hoser! Listen to Oilhammer, his recommendations are spot on with my experiences with my old A1 Jetta Coupe.
Be smart, go through everything he said, get the Rotella T Synth 5w-40 and factory Mann oil filters. Change the oil immeidately, sounds like the last guy wasnt' aware of the special needs of a diesel, let alone timing belts.
Treat here right and she'll be very reliable. I've been restoring an 82 Audi 4000 Diesel this past month, same 1.6L motor layed out conventional, easy to work on and get at the timing belt on it. But down on mpg, you lose more with the tranny /drive shafts at a 90... about 45mpg is my best in it, maybe a little heavier too.
These things are very easy to work on.
December 17th, 2005, 20:28
#13
ToofTek Inventor
Hmm... the OM was suggesting a CC or CD-rated 15w40 or 15w50 oil for my climate, but then again, this was 1985...
We use Shell Rotella T non-synth, IIRC 15w40, in our Chevy diesel. Running the same oil in both would be advantageous. So, what's your opinion of just running that?
There's a bottle of whatever was used in the last change, I think it was Delo 400, didn't check the viscosity, in the car. I can check tomorrow...
December 17th, 2005, 21:37
#14
Gadget Guy
The high quality oils of today did not exist 21 years ago. Heck, you could probably extend the drain interval to like 7500 miles, right guys?
-J
December 17th, 2005, 22:56
#15
Torque Dorque
Congrats!
Turbo, turbo, turbo
Mod mod mod mod
J/K. Enjoy that Jetta
| Thread Tools |
Search this Thread |
