Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
User Name
Password
VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta/Golf (99.5-2004) & New Beetle. Both VE and PD engines are covered here.
Thread Tools Search this Thread
Old December 12th, 2005, 19:33   #1
whitedog
TDI Scholar
Default How to add back-up lights to your 04+
Ok, so I was at a GTG this past weekend and they were talking about a "five brake light mod". Well, it was so easy and cheap ( I love those words) that I decided to do it.
Then I found out that you can't do that on an 04+. The bottom strip on the tail light assembly is clear all the way across. So I thought I would just make it a "Four back-up light mod". Install the bulb and just put the wire on different terminals. No big deal, except that I found the following
There is no hole there for the bulb.
I decided to go ahead and do it anyway, I'd just have to make a hole there.
For those that haven't removed the tail light assembly, there are three nuts to remove. Two that are easy to unscrew, and a third that you will probably drop. It takes an 8MM wrench for the nuts, but that bottom, outer one is tough. Maybe I'll have better luck when I do the other side. They are not very tight since they are pulling on plastic and once you break them loose, they screw off very easily. After a quarter turn, they spin right off, but if they don't, try pushing in on the light assembly. The two outer studs have rubber cushions on them, but the single one on the inner side doesn't have one on it, so don't worry that you lost it. I'm thinking about doing a little trimming of the inner trunk liner to make it easier to R&R the bulb holder thing, since it's kind of a pain finagling to get it out.
This is what I started with:
After some time with the mighty $6.99 rotary tool kit from Harbour Freight, I ended up with this:
Sweet. I'm on a roll now. The rest is simple. I stol... Acquired and relocated some wire connectors from work along with some wire and made two jumpers like so:
They are four inches long (Seven in guy-speak) but it could have been a half inch shorter. It was installed like so:
The connector sockets have two pins and you can use either one of them.
The result?
I tried it out in the driveway and I can definitly see better when I back up. I think that it's worth it.
Old December 12th, 2005, 20:17   #2
Keli_OR
Nicely done!
And if some big truck is sitting on your bumper at a stoplight, putting it into reverse will really get their attention!
What does Bailey think?
-Keli
What I am is what I am are you what you are or what?
Silver '01 Jetta-155K miles.
5 light brake mod,ventectomy,Old Navy CCV,CAT 2 micron fuel filter,tdiclub plate holder,smoked Hella e-codes,splashguards,Bilstein TCs, 'Gator chip,stubby antenna, engine cover mod, Evolution Atlas skidplate,monster mats.
Silver '98 New Beetle- 165K miles.
Evolution Atlas skidplate, 'Gator chip, subtle tdi badging on rear hatch.
Keli_OR is offline   Reply With Quote
Old December 12th, 2005, 20:23   #3
whitedog
TDI Scholar
Ugh... notice the bumper? That's just from coming home yesterday.
Old December 12th, 2005, 22:04   #4
compu_85
Gadget Guy
compu_85's Avatar
Nicely done!
Jettafock found this red sleeve to slip over the bulb so he could do the 5 light mod on his 04.
Hmm... I'm guessing that spot on your rear bumper isn't the only non muddy spot on a silver car?
-J
99.5 Jetta TDI. 36 MPG. 246,000 miles. Now with power memory seats & Monsoon audio
1992 Jetta ECOdiesel. 150k miles. Bad headgasket... under repair.
1991 Jetta ECOdiesel. 420k+ miles. 40 MPG. Sold to VeeDubTDI
1991 Mercedes 350SDL 205,000 miles, 55,000 on engine. 23 MPG. Hidden away for the winter.
compu_85 is online now   Reply With Quote
Old December 13th, 2005, 01:26   #5
DPM
Are you gonna fit a relay to save the reversing lamp switch from burning out?
DPM is offline   Reply With Quote
Old December 13th, 2005, 15:45   #6
Fyrman
Fyrman's Avatar
Send a message via MSN to Fyrman
Nice alternative to the 5 light mod. Hasn't been much action in the how-to thread lately, nice to see a new post!
Thanx!
I accidentally got drunk this morning... Didn't see it coming.
Fyrman is offline   Reply With Quote
Old December 13th, 2005, 15:49   #7
dieseldorf
top post dawg
dieseldorf's Avatar
Thumbs up Ahhh-hmmm....whitey, look what Poppy is
getting for Xmas.
dieseldorf is online now   Reply With Quote
Old December 13th, 2005, 17:54   #8
whitedog
TDI Scholar
Thumbs up Thanks for the heads-up
Something that I kept thinking about was the fuse, but I hadn't thought of the switch.
I'm going to gamble and run with it as is. If there is a problem I will attack it then, but until something happens I'll just keep my fingers crossed. Thanks for the heads-up.
Old December 13th, 2005, 17:57   #9
whitedog
TDI Scholar
From what I'm seeing, almost all of the red cinders are ending up on the back end of the car. Probably wouldn't look too bad on a blue car, except for the rubbed off parts. I remember red Oklahoma mud on my old Blue truck looked pretty good.
Old December 14th, 2005, 05:42   #10
fitzski
fitzski's Avatar
That's a great idea! I too was "disappointed" that I couldn't join the 5BL mod crew, but now we can start our own club! Nyah nyah!!
Fuse #7 is the back-up lights. It's 10 amps, and is shared with the "speedometer vehicle speed sensor". A Sylvania 7506 (P21W) bulb, as one example, is rated at 1.75A, so you're going from 3.5A on two bulbs, to 7A with four bulbs. That leaves 3A for the VSS on the 10A fuse when backing up - is that enough?
2004 Jetta TDI-PD [galactic blue, black & tan, 5sp]
2003 Passat W8 Variant [pacific blue, tan leather, 6sp]
2004 Jetta TDI-PD [spice red, black leather, 5sp] (RIP)
fitzski is online now   Reply With Quote
Old December 14th, 2005, 23:15   #11
compu_85
Gadget Guy
compu_85's Avatar
Couldn't hurt to cary extra fuses with you.
Are you shure that's all that's on that fuse? When I was wiering up my 5 light mod the 1st time, I accidently connected the jumper to the reverse light. Pressing the brake made the cluster and comptuer turn on! I guess it fed current back through the speed sensor to the load reduction relay or something.
-J
Old December 18th, 2005, 21:07   #12
whitedog
TDI Scholar
Bump and grind here.
Old August 4th, 2006, 19:47   #13
compu_85
Gadget Guy
compu_85's Avatar
Bump for this great idea!
I just did this on my car, and the difference between the ealry A4 tails and the 04 tails is noticeable, then adding these extra lights makes a huge difference. The fog portions cast a very tall beam, the reverse lights cast a wide beam.
-Jason
Old August 5th, 2006, 00:34   #14
nicklockard
Torque Dorque
nicklockard's Avatar
Smile
Compu85, I like your addition of the 04 tails to your 99.5. It really updates the look a lot..in fact, given Tim's great mod, I now want to join his cult: I'm going to find a set of '04 tails and do the Whitedog mod too
Great mod Tim.
NIST applet
Tire Rack Review of Energy Saving Tires
My favorite charities:
EnviroFit| Modest Needs
nicklockard is offline   Reply With Quote
Search this Thread:
Advanced Search
vB code is On
Powered by vBulletin Version 3.5.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.10255 seconds with 10 queries
[Output: 98.25 Kb. compressed to 91.41 Kb. by saving 6.84 Kb. (6.96%)]
