| TDI Fuel Economy Discussions about increasing the fuel economy of your TDI engine. Non TDI related postings will be moved or removed. |
November 25th, 2005, 07:34
#1
Fuel Economy: 65/62/60 mpg US
Driving for better mpg
Expectation.
The professional driver achieved 63mpUSg while driving the EPA cycle. This figure is then downgraded by 22% to allow for real life road conditions and less than professional drivers. The published figure according to the EPA is 49mpUSg.
Drive your own road.
Drive responsibly, share the road.
Drive purposefully, at your own speed.
Select your route to avoid stop streets, slow roads, and fast highways.
Opt to drive on roads with good road surfaces.
Opt to drive at a time of day that avoids “rush hour” or traffic build ups.
Know what the speed limit is, and drive appropriately.
Do not drive in “the pack”.
Do not hinder other road users, let them pass.
Do not let other road users intimidate you.
Do not let another road user tailgate you, drive the speed limit.
Do not tailgate, use the 2 second rule.
Gears.
Use 5th gear whenever you can. Use the highest gear possible at all times.
Don’t be afraid to change gear. Get used to it. Change up, change down. The best time to change gear, is the first time you think about it.
At 40mph the engine uses 20% less fuel in 5th than in 4th to produce the 6 hp needed to keep the car moving on a flat road. But, that is getting close to the lugging condition, so be prepared to change gears should it be necessary. In fact the engine uses 20% more fuel to produce the same HP at any speed in 4th than in 5th. Clearly 5th gear is the best gear for mpg’s.
Brakes.
A good way to convert fuel into heat and dust. Avoid using them. Adjust the speed of the car using your right foot only. This means you have to read the road ahead, and drive smoothly. Use the brakes only: at the end of your journey; at stop streets; at red lights; for policemen; pedestrians; and idiots; Avoid all other uses of the brake pedal.
Excessive use of the brakes costs you in fuel, in brake pads, in rotors, and in time to get these items replaced.
Cruise control.
Use the cruise, it does a pretty good job, except when driving downhill. Get used to using the cruise control as part of your driving technique, applying it when appropriate.
Right foot.
The TDI engine’s fuel efficiency, (converting the BTUs in the fuel into HP at the wheels) varies from a high of 45% to a low of 12%. The 45% occurs with a heavy right foot, the 12% occurs with a light right foot.
At 1750 rpm the range is 45% to 15%. At 3500 rpm the range is 36% to 12%.
Therefore: use a heavy right foot at low rpm, whenever you can.
To get better mpg’s you need to use the engines best fuel efficiency. The TDI is fuel efficient when you use a heavy right foot. It is fuel inefficient when using a light right foot.
Use the “some or none” technique, ie a heavy right foot or no right foot. - Drive with purpose. Romp up hill, and coast down hill.
RPM.
Keep the RPM down. But, be careful to not lug the engine, which might occur below 1300 rpm.
Lugging is a condition where the power required is more than the power available from the engine. Typically in a gasser this is stated as “keep the revs above 2000” Most 2litre gassers have 30hp available at 2000 rpm. The TDI has 30hp available at 1300rpm. Therefore the equivalent statement for the TDI is “keep the revs above 1300 rpm” to avoid lugging.
When slowing down keep the car in 5th until the rpm’s are less than 1000 rpm, then change down, as this will minimize the engine braking effects. When driving on a flat road, with only the driver in the car it will pull in 5th from 1100 rpm without lugging, and on a downhill even at lower rpm. Get to know your cars capability in this rpm range.
But, don’t forget to exercise the car from time to time through the whole rev range. Say once a week, when accelerating on a highway on ramp, hold second gear and stomp on the go faster pedal and let the rpm go through to the top. It blows out a whole bunch of crud, and keeps the engine sweet. The engine responds well to a touch of variety.
By the way, the 90HP TDI can produce 20HP at 1000 rpm, 30HP at 1300, 41HP at 1500, 56HP at 1900, 71HP at 2500, 82HP at 3000, 87HP at 3500.
Cold Start.
Observing the mpgs I return when I make 1 journey of 200 miles, vs 10 journeys of 20 miles, indicates to me that there is a cold start penalty equivalent to 3 miles. I think this cold start process takes place over the first 10 miles. The temp gauge shows the engine coolant is up to temp in 2-5 miles, but, I am of the opinion that this process is not complete at that point, there’s more too it. For the first 10 miles of a journey the TDI engine (not just the coolant) has to get to operating temperature, as does the gearbox, wheel bearings, tires, brakes, etc etc. It takes +/- 10miles, regardless of conditions, or how you drive. The only thing that can be done is to reduce the losses, ie keep them closer to 20% rather than 30% (2milesworth rather than 3milesworth). In other words drive careful during the first 10 miles. Do not blast off from a cold start, or you will experience a cold start penalty that is larger.
The glow plugs operate to help warm up the car, but only if you keep the rpm below 2200. If you exceed 2400rpm the glow plugs shut off. So keep it below 2200 rpm til the temp guage is off the bottom three marks.
I have wondered about the TDI heater or Zerostart device that keeps warm water in the radiator, and how this might help to reduce the Cold Start Penalty.
Driving off.
Get in the car, fasten seat belt, start the engine, and drive off.
Do not let the engine idle, to “warm up”. The engine warms up quicker when its under load, and the mpg’s benefit because you are using the fuel to go somewhere. The lube oil in the engine is up to pressure and distributed throughout the engine in the first 5 seconds or less.
Getting up to speed.
5th gear is the economy gear. Your goal is to get into 5th gear as fast as is reasonably possible. Use first gear to get the car rolling. Within 4 cars lengths you should have gone through 1st, and 2nd, and have engaged 3rd. Do as much of your driving as you can in 5th. You will be changing gear below 2000 rpm. So flip your way through those gears in the 1300-2000 rpm range. Target to get into 5th at 40mph and 1350rpm on a flat road. Higher rpm of course on an uphill, lower on a downhill.
Sometimes you’ll need to pull away harder, do it pedal to the metal in the highest gear possible.
Speed.
The optimal speed, on a flat road, is somewhere around 40mph. (+/- 1300 rpm in 5th) The higher the speed the more effort it takes to move the air out of the way. (As airspeed doubles, the force of the wind quadruples, any yachtsman will tell you that.) The optimal speed is not 30mph because of the engine’s lousy fuel efficiency at real low rpm.
However this “optimal speed” is often not possible because it is too fast (legally) for an urban road speed limit, and too slow (sensibly) for a highway.
Travel at a speed fast enough to allow the continual use of 5th gear, and as slow as road conditions permit. Be careful, do not hinder other road users.
Tailgating a big truck can give significant reductions in wind resistance but is really not sensible. Keep your distance, observe the 2 second rule, you will get some drafting effect at 60 mph and faster. Less than 50mph, its just not worth it, anyway.
As a rule of thumb these numbers are very possible:
40mph = 80mpUSgallon
50mph = 70mpUSgallon
60mph = 60mpUSgallon
70mph = 50mpUSgallon
80mph = 40mpUSgallon
Slowing down.
Don’t use the brakes. The brakes are very good at stopping the vehicle, and in converting fuel into heat and dust. Avoid using them for slowing down.
Over-run is the method of choice. It is the safest. At low speeds the engine braking effect is minimal. In some locales coasting and freewheeling are illegal.
Over-run is where the car is in gear, no right foot, no brake, the car is traveling along subject to engine braking effects. The engine consumes no fuel.
Coasting is where the car is not in gear, the engine idling, the car is traveling along the road without any engine braking effects, but the engine is consuming fuel to keep it idling.
Free-wheeling, is where the car is not in gear, engine is off. How do you steer? As there is no power steering. And how long will the brakes remain effective for? Not a good idea.
Coasting is of use under certain conditions (>50mph). The amount of fuel used (0.5 litre an hour) may be less than the engine braking effect. It depends on the road conditions. If in doubt use over-run.
When using over-run allow the rpm to drop to 1000 before changing down, as this will minimize the engine braking effect.
Stopped.
Turn the engine off if you think you are going to stand still for more than 10 seconds. No use burning fuel to go nowhere. Restarting the engine uses as much fuel as “10 seconds” worth of idling.
Driving Uphill.
This is where you can operate the engine close to its most efficient, take advantage of it.
Do not take a run at an uphill. Allow the car to slow a little, get into the slow lane, and drive up the hill at a speed such that you can maintain 5th gear, with a heavy right foot.
Example: Taking an 8% uphill at 50 mph will give good results, it will be marginally better mpg’s to take it at 40mph, but at 60mph there is a distinct drop off as you are moving out of the fuel efficiency curve.
This engine is most efficient when asked to make lotsa hp. The more hp, the more efficient, use a heavy right foot, and slowing down allows for a heavier right foot.
Just don’t overdo it and get into a lugging situation. Lugging, and changing down is not good.
Driving Downhill.
Driving the car gently down a hill is a very inefficient use of the engine. This engine converts fuel to power most inefficiently when asked to make a couple of hp only. The difference can be as much as 3 times as much fuel consumed to produce a HP. (Ie 15% efficiency instead of 45% efficiency)
Do not use the cruise when going downhill.
Let the car over-run. Do not use the right foot to maintain speed going down a gentle slope. If the hill is not steep enough for the car to maintain speed, let it slow down, (or knock it out of gear so it will maintain speed – careful, maybe illegal). Do not maintain a light right foot to keep the speed up.
Go into a downhill, adjust the cars speed (faster or slower) so that it can go down the hill with no right foot, and no braking required, and at the bottom of the downhill come out at your desired speed.
Coasting in gear is always preferable for mpg’s when your speed is below 45mph. Above 50mph it may be preferable for mpg’s to coast out of gear (engine is idling, consuming fuel) assuming that you can handle the extra speed without using the brakes. And, assuming its not illegal to coast out of gear in your area. The engine idling consumes, say 0.5 litre per hour, that’s enough fuel for 2.5HP. Above 50mph the engine’s braking effect is more than that. If the road conditions, and traffic are such that you can coast out of gear, then coasting can show a better MPG at speeds above 50 mph. If in doubt over-run, (coast in gear). Then you wont have burnt the fuel just to idle the engine while coasting, that is in case you have to use the brakes.
2 second rule.
Don’t tailgate. Use the 2 second rule. When the vehicle in front of you passes some mark, count; One crocodile, Two crocodile, and then you should pass the same mark. It’s a simple rule to check yourself when driving in traffic, and especially at higher speeds, that you are maintaining a reasonable distance between yourself and the vehicle in front.
In some places people may argue that if they leave a “2 second” gap others will cut–in. That’s got nothing to do with your driving, do not get lured into driving in some one else’s style. Decide on, and stick with, your own driving habit. Can you drive an alternate route, or at a different time of day? Do not drive in the pack, drive your own road.
My numbers? 80,000 miles at an average of 59.5 mpUSg, in my 2002 VW Golf 2 door TDI.
From Jan 15 2002 to 16 November 2005.
P.s. The intake has not clogged, he turbo has not surged, and the car is running real sweet, and strong.
Have fun.
November 25th, 2005, 08:36
#2
Wow, thanks, gdr,
That should have a special flag on it or something.
I am a little uncomfortable with flooring it below 2000 rpm, it could damage the turbo? (Coincidentally, that's where max efficiency is, pretty close.)
Ernie Rogers
November 25th, 2005, 10:21
#3
Banned
Fuel Economy: 44,51, 59.08 mpg
Interesting info, I'd say. Ernie, didn't we talk about this recently last week?
November 25th, 2005, 11:41
#4
I adopted rather similar driving methods, and got well below 30mpg in my 05 Golf GLS auto. I went to a very light right-foot, and the first tank like that was 34mpg.
Seems to contradict what you are saying. Perhaps this is due to the automatic transmission?...
87 Porsche 951
05 Golf GLS TDI
November 25th, 2005, 12:27
#5
Zehntes Jahr der Veteran Vendor
[quote]You will be changing gear below 2000 rpm. So flip your way through those gears in the 1300-2000 rpm range. [/qoute]
Follow that advice and you will do one of two things:
Blow your turbo to kingdom come if you live at high elevations or Completely soot lock your VNT mechanism and kill compression from lack of clean combustion and boost pressures to cycle your compression rings...seen it done TOO many times by people trying to drive for maximum fuel economy!
If you want to lug a motor around driving that way, buy a non-turbo gasser and lug it since you can't hurt anything.
TDI's MUST HAVE BOOST pressure to cycel the VNT, heat up that Catylitic converter and cook the carbon out of the rest of the motor.
Low rpms translate into VERY low fuel pressures, low oil flow under the pistons, low compression pressures which are MANDATORY to keep the rings floating in the lands and sealing properly.
Shifting below 2,000 rpm also places the TDI engines directly at the "Surge Line" for the VNT turbo's compressor, meaning you are causing the engine to run at peak boost pressures that can cause a complete failure of the turbo.
Follow this advice and you will permamntly damage your motor...DON'T DO IT!
Drive your car the way it was intended, keep in mind these engines were designed for driving on the Autobahn NOT for lugging around town in some attempt to get 90mpg...For that they sell a diesel called the "SDI" which does not have a turbo and can be lugged as suggested above.
DB
*Check out our new Hot-Swap program, no downtime and injectors are shipped to you ready for install with the nozzle of your choice! *Insist on Genuine Bosio nozzles, All of our nozzles come with Bosio issued Authentication ID#'s traceable directly back to the factory.
November 25th, 2005, 12:34
#6
Yes it CAN produce that power but it can also produce 30 hp at 2,500 rpm...You are confusing the fact that this engine is NOT a gasser and does not subscribe to stiochiometric fuel ratios. Fuel ratios are dependent on load. The TDI fuel consumbtion graph shows that maximum fuel economy for a TDI occurs at a range of 1800-2100 rpm. In that range fuel economy remains nearly the same. Driving at those rpms places you at or around speeds of 55-60 mph.
My advice is to accelerate rapidly and once up to speed keep the engine at an rpm that places you as close to 2,000 rpm as possible. This puts the engine in it's most efficient fuel consumption range and keeps the engine operating at an rpm that it was designed for.
DB
November 25th, 2005, 12:59
#7
Gadget Guy
I have to disagree with your millage numbers. I drive 80 or quicker on the freeway, and get 45 mpgs with biodiesel!
-J
November 25th, 2005, 13:22
#8
Have fun.
Have you ever (or lately) removed the EGR to actually check the intake?
And how do you know the turbo has never surged? Do you have a boost gauge?
November 26th, 2005, 03:27
#9
Driving that way more than likely his turbo is jammed up and won't make full boost pressure.
Also cars run this way suffer from lower compression thus lower efficiency in terms of directly effecting fuel economy.
DB
November 26th, 2005, 06:16
#10
Fuel Economy: 70.1/ 51/ 38
Just to rain on everyone else's parade, I think gdr703's advice is RIGHT ON!
1992 Mazda MX-6 (totaled by senile Honda driver!)
1997 Passat TDI
1999 Mercedes Benz E300 Turbodiesel
2005 Passat PD TDI
November 26th, 2005, 07:03
#11
TDI Lifer
Fuel Economy: Old Passat 40 Mercedes 20
LOL.....SOS huh Jack???
I can't wait until you slam the vanes of the Turbo on the Passat......
Then I will buy it for 5000 that's the 05 Passat Jack!!
Keep driving them like a grand mom ma..........
2010 Jetta Sportwagen Salsa Red/Titan Black
1996 Passat TDI Pearl Red
1996 Passat TDI Storm Grey
1984 Mercedes 300D Blue/Green
November 26th, 2005, 09:54
#12
Oil Wanker
Driving for absolute best MPG (no matter the effects), yes. Driving for engine health, no.
I get 2 to 3 MPG less now that I drive "like I stole it" compared to when I'd baby it. Big whoop. The car is noticably quicker, and if exercising the engine will keep it running good, I'll keep doing it.
You'll have to save an aweful lot of fuel to defray the cost of an intake cleaning, clean/replace the turbo, and fix low engine compression.
November 26th, 2005, 22:14
#13
Thanks, guys, for the great wisdom.
I think it's time for me to blow out my engine, been babying it the last few days. 95% of the time I drive like a grandma (good mileage) and the remainder I drive like a suburbanite late to work.
Now at 107k miles, never cleaned anything, but changing filters and timing belt. I hope to keep it going that way. (Got 69 mpg last trip to Fresno, this Wednesday.)
Thanks again, I really depend on the lessons I get here.
Ernie Rogers
November 27th, 2005, 13:16
#14
That is correct.
It is also correct that it will use 15% more fuel at 2500.
November 27th, 2005, 13:18
#15
Recently a mechanic changed the timing belt, and water pump etc.
His observation, is that its all fine.
Refer to the thread: "Some myths about surge..."
From that thread I understand that it would be known if it ever did surge.
