Old November 20th, 2005, 11:34   #1
Ghia
Default Audi A6 2.5TDi (AAT code) 1996 5 Cyl Diagnostic wiring..
Hi,
I've recently fitted an Audi 2.5TDi 1996 AAT code 5 cyl engine to my Crewcab Syncro. It runs ok but the glow plug light it flashing away at me (I know its the ECU telling me something is wrong).
Dispite my best efforts to strip out the loom to just what I needed, I managed to loose the Diagnostic wire from the ECU. The car had OBD1, I think that the Black plug just needs a feed and earth, and that the White plug has a Green/Red wire from the Immobiliser unit but I don't know where the other wire (white, or white and ... ) goes to.
Does anyone have access to a wiring diagram for this year or could anyone tell me what pin number from the ECU the diagnostic wire is correct?
MG
Ghia is offline   Reply With Quote
Old November 20th, 2005, 16:28   #2
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
Glow plug light flashing is usually a brake sensor issue, IIRC.
Try turning cruise control on, and if it doesn't work, it's the brake sensor.
1999.5 golf tdi | 5 speeds | 2 doors | crank windows | candy white | rc3 | t502 | 11mm | fsd
emit more NOx (in VOC-limited areas), save the planet | reverse polish notation good is
The really cool ToofTek made "Emperor's Clothes" injector fork risers only worked until someone pointed out that there wasn't any thing there.
bhtooefr is online now   Reply With Quote
Old November 20th, 2005, 17:26   #3
AntonUK
Ill check on my Audi for ya mate tomorow....on my audi any brake sensor issues light up the ABS light. Iv seen it happen.
Anton
My A2 AHF Project...
AntonUK is offline   Reply With Quote
Old November 20th, 2005, 17:28   #4
AntonUK
Anton
Old November 20th, 2005, 17:53   #5
compu_85
Gadget Guy
compu_85's Avatar
Fuel Economy: 56.3/44/41
BHT,
A blinking glow plug light can mean many things. What it is telling you is that the ECU is having problems communicateing with something. For example, the brake light switch, the fule temp sensor, etc.
-J
Present:
2012 Passat SE TDI DSG. 24,000 miles. Factory Alarm & LED tails 38/48 MPG.
99.5 Jetta "GLX" TDI. 289,000 miles. Half way there!!! Power Memory Seats, BV39 Turbo, RCIII 36/47 MPG.
1991 Mercedes 350SDL 222,222 miles, 70,000 on engine. 18/27 MPG.
Past:
1988 Audi 5000S, 1992 Jetta ECOdiesel, 1991 Jetta ECOdiesel.
compu_85 is online now   Reply With Quote
Old November 20th, 2005, 18:41   #6
bhtooefr
ToofTek Inventor
bhtooefr's Avatar
Again, I *did* say IIRC.
Thanks for the information, tho - I'll remember that for future reference...
Page generated in 0.11435 seconds with 9 queries
[Output: 72.91 Kb. compressed to 63.42 Kb. by saving 9.48 Kb. (13.00%)]
