Old November 15th, 2005, 18:21   #1
autumn
Default what is the grinding noise on my 96 passat?
My 96 passat is making a grinding/humming noise in the front end that gets louder when I go faster and does not stop when I shift gears. I've been reading through some of this forum and some posts have indicated it might be a CV joint, but a mechanic told me transmission. If it is a CV joint, does anyone have an idea of how much it costs to fix it? Any help would be greatly appreciated!
autumn is offline   Reply With Quote
Old November 16th, 2005, 10:21   #2
redmondjp
Fuel Economy: 41 mpg avg
Could be a bad front wheel bearing too, as these are a known failure item on VWs. It's really hard to diagnose problems like this over the internet. You should find a forum member in your area and have them look at it sooner rather than later!
Diesel shoud never cost more than unleaded gas - ever!
'96 Passat Sedan 197K - target 'run' date--December '08
'81 Rabbit LS D 130K - sold
'82 Datsun 720 diesel pickup 86K - sold
redmondjp is offline   Reply With Quote
Old November 16th, 2005, 11:55   #3
MTjake
TDI(s): 3
Fuel Economy: very good
Bearings or CV joint likely. Look to see if the CV joint boot is in good or bad condition, especially the right one.
My kneejerk thought is that you should stay well away from the mechanic that suggested it was the transmission.
How many miles on your B4?
1996 B4V.
T4b MV with AHU and 3 pedals
2010 JSW 6M, solid roof
Some tools available for free use, here (but it's an uncovered, unheated, gravel driveway)
MTjake is offline   Reply With Quote
Old November 18th, 2005, 06:57   #4
John Beyer
If it gets louder when you load one side of the car by just turning the wheel a bit, like changing lanes, then it's probably a wheel bearing. A CV joint makes more of a clatter than a groan/hum and happens on a sharper turn.
'98 Jetta TDI/GT,175k
'98 Jetta TDI,330k
'96 Passat TDI Wgn,348k
'03 Jetta TDI,246k
'96 Jetta Gas,115k (Auto to Man Conv)
John Beyer is offline   Reply With Quote
Old November 19th, 2005, 03:56   #5
Toronto_Vento
Toronto_Vento's Avatar
Fuel Economy: 50/48/44
I'd also say it's a bearing. These are common things to go on VWs, unfortunately.
-- John K
Wingnut's HOW TO's thread
"The commuting system is so badly broken that it will take decades just to bring it up to a level where it is merely malfunctioning." - Globe Drive
Toronto_Vento is offline   Reply With Quote
Old November 21st, 2005, 07:18   #6
saabguru
I concur with the wheel bearing idea. My A3 has 171K miles, and I have replaced all of them at least once.
saabguru
Aviation Mechanic, edge dweller, Equities Investor,
URL="http:truesynthetic.com"
49cc 2 stroke Daelim Motor Scooter
1996 Hyundai Avante, 1995 Peugeot 505S
saabguru is offline   Reply With Quote
Old November 21st, 2005, 07:30   #7
saabguru
Oh, BTW, replace the (front) hub, too. Mine was $12 from autohausaz. It makes no sense, just do it, trust me. Voice of experience.
saabguru
Old November 22nd, 2005, 16:27   #8
juli0s
Fuel Economy: 48/45/40
wheel bearing
My MK3
juli0s is offline   Reply With Quote
Old November 22nd, 2005, 21:11   #9
Greenhorn
I'm with saabguru. Just bought a 97 Jetta tdi w 125k miles--had same symptoms. If it's a bearing Autohausaz.com is the way to go! 2 front bearing kits and hubs cost $75 total w/ free shipping. I priced these out at the dealer at $90 per bearing and--get this--$160 per hub! I was not set up to do it myself, so another $200 at a trusted local VW shop had me back on the road. (my hearing returned shortly thereafter). hope this helps
Greenhorn is offline   Reply With Quote
Page generated in 0.13633 seconds with 9 queries
[Output: 84.65 Kb. compressed to 71.65 Kb. by saving 13.00 Kb. (15.36%)]
