| Upgrades (non TDI Engine related) The place of handling, lighting and other upgrades that do not relate to the performance or economy of the TDI engine. In other words upgrades to your TDI that don't fit into TDI Fuel Economy & TDI Engine Enhancements.Please note the Performance Disclaimer |
December 27th, 2005, 15:36
#16
Gadget Guy
Bumping this thread... BECAUSE THE CLUSTER IS INSTALLED
First off, thanks to ele28 for the programming, and penclnck for his excellent cluster disassembly 'step by step'.
Swapping the faces was easy, and I think I have the needles aligned correctly. If not, I'll just crack the cluster again tomorrow.
First off, if you've had coolant migration and the harness was repaired, this is what will be behind your cluster:
Now, after the Passat's guts were transplanted into the TDI cluster:
Note that the idle is correct on the face, even though it's still listed as 880 RPM in vag-com  The brake wear light is on because that feature is not installed on my car.
Now doing a TEST with the odometer adaptation:
And after coding it back to NA specs:
I'm gunna wait till the next G2G to wire up the switch because I'm not 100% comfortable taking the airbag / steering wheel out. (hmm, maybe we need an emergency G2G  )
Just goes to show how insane us TDI people really are...
-Jason
January 4th, 2006, 21:13
#17
to the
RC 3.1,DG pipes, Forge SMIC,R32 airbox,FSI/Oil Level Sensor,OMI,Standheizung,Bilstein TCs,TT brakes,A3 strut bar,Neuspeed stress bar,VW Racing Bushings,ESP,Folding Mirrors,Aero wipers,Headlight Washers,PDC,Bora Trunk switch,VR6 muffler,4-motion valance, OEM Skid Plate,HIDs,Custom Rear Tails, Zender Spoiler,WE Power Seats,RNS2,DSP speakers,Euro CCM & Door locks,MFSW,Anti-dazzle mirror/Rain Sensor,FIS,IRU,DWA,2nd OBDII,OEM Auto Window
January 4th, 2006, 21:21
#18
Gadget Guy
Update on the ASR led (kinda x posted from the other thread)
US 99.5 Clusters do have the asr warning light installed. The light is turned off by ground. But, the wire connected to this pin is hard wired to a ground, not to the ABS pump. Connecting the pin to the correct pin on the pump makes the light function properly.
The Passat cluster seemes to be backwards... The light was turned on by ground, and now that it is connected properly (tested with the old cluster) the light is always off... except when the car is started cold, the light illuminates very dim briefly.
I'm gunna talk with ele28 to see if this can be fixed. I have yet to install the stalk... maybee I could wire up a temp button to cycle the functions? You connect the pins to ground to signal the switch, right Lito?
-J
January 4th, 2006, 21:44
#19
I don't know. I just connected it to the stalk. You'll have to look at the wiring diagrams but that may not tell you if the wires are + and -
Just install the stalk!
January 4th, 2006, 21:48
#20
Gadget Guy
But that means I have to pull the steering wheel... and the airbag... and I'm really not comfortable doing that unsupervised.
Well... how hard is it? You need some special bit for the bolt that holds the steering wheel on, right?
-J
January 4th, 2006, 22:30
#21
Yes, you'll need a large Torx drive for the steering wheel. I think Metalnerd sells them. Check his site for the bit.
Just disconnect the battery when you take the airbag off. I think I have pictures (in my folder on the picture server) of the steering wheel and how you need to insert a short screw driver into the access hole.
When you re-install everything, just make sure the key is in the ignition and turned one click before you connect the ground strap of the battery.
That's all.
April 22nd, 2006, 21:51
#22
Gadget Guy
OK. Got this installed today... finally. My steering wheel seems to have modling problems... getting the airbag off is a major pain.
On top of that, the MFA does not work properly. Instant MPGs always reports 5, not matter what. Avg MPGs reports 15.x after resetting, then after a moment drops quickly to 3.6.
Also, the speedometer disagrees with the MPH display... 10mph speedo = 10mph MFA. 35MPH speedo = 33 MFA 60MPH speedo = 54MFA. 80 speedo = 70 MFA. 2000 RPM should be 58 MPH, right? That's what shows in the speedo, but the MFA reads 54mph. I'm gunna do some more checking with vag-com to see how off that is... Probably monday.
Hopefully ele28 can resolve this software issue.... or perhaps some euro software in my ECU would help
-Jason
April 24th, 2006, 14:28
#23
MPG.... Maybe it's reporting ltr/100km? 3.6 is pretty impressive though... 5 is already low enough.
April 24th, 2006, 15:18
#24
Gadget Guy
No.. it's not working properly... the instant mpgs is ALWAYS 5. Stopped, going along the road, WOT, whatever.
April 26th, 2006, 17:08
#25
Gadget Guy
Grounded the temp sensor better fixed that issue. But I've noticed another one:
When you do an output test, after the needles sweep, shouldn't the speedo come back to 100 KPH? And the Tach to 3k RPMs?
Also, I tried without success to code it for the fixed interval. The digit for that function in the later clusters serves as the number of cylinders... it only takes 4 or 6. BUT, if I hold in the trip reset button while turning on the ignition on, service comes up in the odometer, and by pressing it again, the display cycles between insp and oil! Clicking the clock knob turns the display to dashes... doesn't seem to work (probably because it's not coded properly, eh!)
-Jason
April 26th, 2006, 17:48
#26
What is the coding you've set? 07240?
Service intervals:
on this cluster isn't it channel 10 for distance in steps of 1000 km for oil service, channel 11 for inspection in steps of 1000 km, and channel 12 for inspection in steps of 10 days? (typically set to 00015, 00030, and 00037 respectively)
April 26th, 2006, 18:28
#27
Gadget Guy
My codeing is 06242 (99.5's don't have brake pad wear sensors)
I'll check those channels...
-J
April 26th, 2006, 18:37
#28
That vintage Passat cluster rightmost digit had 2 = gas, 0 = diesel.
April 26th, 2006, 18:45
#29
Gadget Guy
Oh hmm..... Interesting. Howard Cooper must have coded my previous cluster wrong when they replaced it, because that's what I borrowed the code from.
-J
April 26th, 2006, 18:57
#30
Golf/Jetta/Bora used that position for distance impulse.
