Old October 26th, 2005, 20:37   #1
fields
Default Engine starts and then stops running
I have a 2002 2 liter (gas) engine. When I try to start it, it starts and immediately stops running. What is wrong, and can I do anything myself.
richard
fields is offline   Reply With Quote
Old October 26th, 2005, 21:15   #2
tdi_allan
Default Re: Engine starts and then stops running
Immobilizer kicking in maybe? Do you see a flashing key light on the instrument cluster? Might need to recode the keys, but I have had this happen intermittently on my TDI and it went away after using one of the other 2 keys. Something to try, anyway...
tdi_allan is offline   Reply With Quote
Old October 29th, 2005, 19:41   #3
MiksTDI
MiksTDI's Avatar
Fuel Economy: 41
I had it happen when I swapped computers. Never tried the key to the guys car that the computer came from. Something to think about.
MiksTDI is offline   Reply With Quote
Old November 2nd, 2005, 12:08   #4
TedK
Fuel Economy: Not as good as I'd like
Matt,
I am having this same problem. The dealer is telling me that you can't swap computers, becuase the ECU is hard-coded to work only with one VIN. Is this true? How did you swap computers if this is the case? I'm so confused.
Ted
TedK is offline   Reply With Quote
Old November 2nd, 2005, 12:28   #5
Birdman
Fuel Economy: 55 summer 50 winter
GO to www.ross-tech.com there are instructions on how to do it. the dealer is full of >>>>>>>>>t
Birdman is offline   Reply With Quote
Old November 2nd, 2005, 20:31   #6
MiksTDI
MiksTDI's Avatar
Fuel Economy: 41
Birdman has it Immobilizer Information Page
Just scrol down and read up on immo2 and 3.
Page generated in 0.13139 seconds with 9 queries
[Output: 67.98 Kb. compressed to 59.15 Kb. by saving 8.83 Kb. (12.99%)]
