Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
Old March 24th, 2009, 21:29   #16
KALaBenne
Fuel Economy: 35.2 MPG
Thanks mogolf, If I had read my own post I would have seen it's 8mm, instead I answered without looking. Sorry
Keith
'04 B5.5V GLS TDI 170K Urban Grey Metallic / Anthracite Leather / Tinted
Delete - dealer, vent, chime, DRLs, Ceramic GP's, BS CHAIN
Add - auto unlock, sebring stubby, sunglass holder, M1 5W-40 ESP Formula M
KALaBenne is offline   Reply With Quote
Old March 25th, 2009, 07:43   #17
TomB
Fuel Economy: 36/30/28
The memory just aint what it used to be. I know that feeling all too well.
2002 Jetta GLS TDI - Sold.
2005 Passat GLS TDI - Graphite Blue/Anthracite.
2005 Passat GLS TDI - Stonehedge/Anthracite.
2007 Jeep Grand Cherokee 3.0L Diesel
TomB is offline   Reply With Quote
Old March 25th, 2009, 15:57   #18
Sprocket
Sprockette's hubby
Sprocket's Avatar
On the PD's you can just cycle the key to the "on" position once or twice with an empty fuel filter. No need to use a mighty vac or pella on our cars.
2005 VW Passat GLS 2.0 TDI Sedan Silverstone Grey w/Anthracite Leather, UPGRADED BALANCE SHAFT MODULE 2/5/09 by Oilhammer, PhatNoise w/160g DMS cartridge, Splash Guards, RochetChip Stage II, Boost Valve, Column Pod w/ VDO 30 PSI Boost Gauge, Evolution Thor Skid Plate, FrostHeater, Cat fuel filter, Euro headlight switch
1996 B4V Storm Grey, 17/22, RC3, PP520's, .681 5th gear, Ecodes W/leveling motors & Euro switch, fog lights, Bilstein TC's, Cat FF, Whitbread 2.5" DP, exhaust, & FMIC
Sprocket is online now   Reply With Quote
Old March 26th, 2009, 06:04   #19
mparker326
YMMV with the key cycling trick. When I did my latest FF change on the passat, I didn't prefill the filter and cycled the key 10 or so times. It fired right up and I drove it about a mile from my house. At a stop sign, the engine died. It wouldn't restart no matter how much cycling I did. I went home and got my Pela and was able to pull fuel through the filter and it still didn't start. I removed the "T" and noticed the filter wasn't nearly as full as when I replaced it. I filled it up with a funnel and it took a little bit of fuel to get it as full as I found it. After that, it started right up and 5000 miles later hasn't given me any trouble.
I don't think cycling the key pulled all the air out of the filter. It is easier just to prefill by installing the filter and using a small funnel and filling it through the "T".
2002 Golf GLS TDI
mparker326 is offline   Reply With Quote
Old March 26th, 2009, 06:06   #20
Sprocket
Sprockette's hubby
Sprocket's Avatar
That's weird. I've changed my fuel filter 3 times and it's worked each time.
Old March 26th, 2009, 14:42   #21
T_D_I_POWER
T_D_I_POWER's Avatar
Fuel Economy: Variable
2004PassatTDI,
I hope I get this on time, before you install the fuel filter in the engine compartment. It's a very good professional practice to fill the fuel filter with fresh Diesel fuel (or gasoline for gas engines). This is done simply, so when you start the engine you won't pump air but Diesel fuel to the injectors. Moving parts in the injectors are lubricated by Diesel fuel not air.
You can simply do this by placing the fuel filter on the bench vise as shown on pic.1.
Pic.1
Insert a funnel (not shown) in the fuel filter "T" hole, and fill filter with fresh Diesel fuel to the bottom of the neck as shown pic.2
Pic.2
If it's too late, do procedure 2 in the engine compartment.
1st in TDIClub
This also a good professional practice when you do oil & filter changes. By filling the oil filter housing & filter with fresh oil, when the engine starts, it will be pumping fresh oil to the hydraulic lifters not air.
I hope this will help,
Cheers,
T_D_I_POWER is offline   Reply With Quote
Old March 26th, 2009, 15:50   #22
KALaBenne
Originally Posted by T_D_I_POWER
2004PassatTDI,
Uh, you realize the origional post was about 3 1/2 years ago. Maybe you knew that and I missed the scarcasm font you were using.
Anyway, also don't forget to remove the little plastic caps before you fill. (guess how I know)
+1 on filling the filter out of the engine compartment. (yes, same reason)
Keith
Old March 26th, 2009, 17:47   #23
abctdi
Each key turn provides only an ounce or 2 before the lift pump shuts off, ask me how I know...
88 Fox variant gasser - long gone
98 Jetta TDI 1.9 - sold...
05 Passat GLS 2.0 PD, stock hp/trq, UnChained, Steel GPs
I'm not as green as I am cheap...
y2k F250SC4x4 PSD 444 cid, 333hp, 667trq
69 Mach 1 Mustang 377 cid, 420hp, 440 trq
abctdi is offline   Reply With Quote
Old March 26th, 2009, 18:01   #24
whitedog
TDI Scholar
TDI(s): 2004 Jetta
Fuel Economy: 42
Then your pump is on the way out.
Old March 26th, 2009, 20:00   #25
2004PassatTDI
2004PassatTDI's Avatar
TDI(s): 2004 Passat
I have found that the easiest way to prime the filter is to use the Pela once the fuel supply hose is connected. I tried the key thing the last FF change. Never again.
901.4 MAX Miles on 1 Tank. Eibach suspension, Neuspeed RSB, RC2, www.speedhut.com boost gauge. Zender Rear Lip Spoiler, Balance Shaft upgrade, CAT back, Hot air delete.
2004PassatTDI is offline   Reply With Quote
Old March 26th, 2009, 20:08   #26
T_D_I_POWER
Thanks KALaBenne. I guess it helps to read.
Btw, from the bench vice I would put a cap that fits over the fuel filter "T" to keep any debris out, and I don't usually remove the caps until I'm ready to reinstall the hoses.
Cheers,
Old March 26th, 2009, 20:35   #27
KALaBenne
Cheers,
I had a little trouble filling the filter with the caps in place because the air couldn't get out, thankfully, it was not in the engine bay when it happened.
One of these days, I'm gonna get me some of them cool hose pliers that mogolf uses in the video.
Keith
Old March 27th, 2009, 08:34   #28
abctdi
Thanks for asking how I know. It's controlled by the ECU somehow...my pump is fine. I had to use it to pump out the couple gallons of unleaded that someone put in the tank by mistake. It required jumping the fuse and worked great...this was a couple of years ago and was documented in this subforum.
Old March 27th, 2009, 08:48   #29
whitedog
TDI Scholar
TDI(s): 2004 Jetta
Fuel Economy: 42
According to testing by DanG, he found that with each cycle of the key, he would get 50-100 CC of fuel from the pump.
Old March 27th, 2009, 09:14   #30
abctdi
I think this supports my statement...you don't get continous flow.
50cc=1.7oz
Thanks for proving my point!
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.12009 seconds with 9 queries
[Output: 124.24 Kb. compressed to 102.70 Kb. by saving 21.54 Kb. (17.34%)]
