Old September 6th, 2005, 20:39   #1
Mark_J
Default glow plug for coolant heating
There are supposed to be 3 glow plugs for coolant heating. I have searched in the repair manuals and haven't found anything relating to the location of these. I have a 1997 Passat and if someone knows where they are located I'd be very grateful.
Thanks,
Mark
Mark_J is offline   Reply With Quote
Old September 6th, 2005, 21:00   #2
whitedog
Just to the rear of the valve cover you can see the three connectors going down to them.
Old September 6th, 2005, 21:06   #3
rdkern
Fuel Economy: A4 = wife drives it, don't know
Default Re: glow plug for coolant heating
Looks like an A4 to me. I can't find anything in my Bentleys concerning the "coolant gps". I haven't seen anything in my engine compartment either. I'm also curious.
rdkern is offline   Reply With Quote
Old September 6th, 2005, 21:09   #4
whitedog
A4, B3, C9, D432... I dunno. That's where they are located on other cars. Good luck.
Old September 6th, 2005, 21:35   #5
compu_85
Gadget Guy
compu_85's Avatar
I remember the A3/B4 guys had posted about them... but I can't find any pics of them on the pics server
-J
Old September 7th, 2005, 16:40   #6
BKmetz
Administrator
BKmetz's Avatar
Fuel Economy: 50 MPG
The coolant glow plugs on the A3/B4 TDIs are in an aluminum manifold on the back of the head facing the firewall. This is the same area as the A4 TDIs. They are hard to see because the intercooler plumbing is in the way.
The relay and fusible link for the coolant glow plugs are on the firewall next to the N-75 solenoid switchover valve. There is a clear plastic cover over the fusible link.
BKmetz is offline   Reply With Quote
Old September 8th, 2005, 12:28   #7
TDIBill
Fuel Economy: 55, 45, 40
The coolant glow plugs are on the driver's end of the head just below the vacum pump location on an A4 motor.
TDIBill
TDIBill is offline   Reply With Quote
Old September 8th, 2005, 13:19   #8
cattlerepairman
cattlerepairman's Avatar
Fuel Economy: 8.4 l/100 km at 60/40 hwy/city
TDIBill
...IF you happen to have manual transmission. The automatics do not have coolant glow plugs.
cattlerepairman is offline   Reply With Quote
Old September 8th, 2005, 18:42   #9
Joe_Meehan
Joe_Meehan's Avatar
Fuel Economy: mid-upper 40's city upper 50's - low 60's Highway
Nice Photo. I am looking for the engine coolant temp sensor that might trigger a CEL code P0118 for Circuit High Input. It appears to be one of the two (of three) devices with plugs on them that are shown just below and to the left of #4 attached to the engine where the heater and radiator hoses attach. Is that correct, and if correct do you know which one.
Both of the ones toward the camera have checked out OK based on resistance readings at two different temperatures. Do you know if these three devices are not connected with a four prong connector in later cars (mine is a 2002 NB)?
Thanks anyone???
Joe_Meehan is offline   Reply With Quote
Old September 8th, 2005, 19:18   #10
whitedog
those three are the coolant glowplugs. the temp sensor may be in that same housing, just pointed to the rear of the car.
Old September 14th, 2005, 21:06   #11
Mark_J
Found them on the drivers side of the head, clustered aroung where a coolant hose goes into the side of the head.
Tbanks every one,
Mark
Old September 14th, 2005, 21:48   #12
compu_85
Gadget Guy
compu_85's Avatar
Are your coolant plugs bad? Do these things actually wear out?
-J
Old September 15th, 2005, 10:19   #13
jasonTDI
jasonTDI's Avatar
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
-J
Yes the do wear out but it's real uncommon. I have replaced ONE single plug in a couple of years on all the TDI's I see.
jasonTDI is offline   Reply With Quote
Old September 19th, 2005, 20:49   #14
Mark_J
Found that they wern't bad. I removed the wires and cleaned the contacts and terminals, this seemed to fix my engine code issue.
Page generated in 0.16656 seconds with 9 queries
[Output: 111.33 Kb. compressed to 92.42 Kb. by saving 18.91 Kb. (16.99%)]
