Old September 13th, 2005, 18:00   #31
TornadoRed
TornadoRed's Avatar
Default Re: Hard to start when hot
This needs pictures.
Login to http://pics.tdiclub.com/ and upload your photos there.
Then link to those photos [image]link[/image]
If possible, do not post mega-sized photos.
Old September 13th, 2005, 18:28   #32
Hamman
Hamman's Avatar
Thanks, TornadoRed. These may be in the wrong order!
[image]http://pics.tdiclub.com/showphoto.php?photo=20914&password=&sort=1 &cat=500&page=1[/image]
[image]http://pics.tdiclub.com/showphoto.php?photo=20916&password=&sort=1 &cat=500&page=1[/image]
[image]http://pics.tdiclub.com/showphoto.php?photo=20915&password=&sort=1 &cat=500&page=1[/image] [image]http://pics.tdiclub.com/showphoto.php?photo=20914&password=&sort=1 &cat=500&page=1[/image]
Hamman is offline   Reply With Quote
Old September 13th, 2005, 18:28   #33
Hamman
Hamman's Avatar
What Now?
Old September 13th, 2005, 18:41   #34
TornadoRed
TornadoRed's Avatar
Old September 13th, 2005, 18:58   #35
Hamman
Hamman's Avatar
Jerry,
Thanks for your help!
Dave
Old September 14th, 2005, 20:34   #36
mjbach
TDI(s): 99.5 Golf
Fuel Economy: 45-50
Thanks (Dave and Jerry) for posting such nice photos and very complete instructions. My husband has already started on the project and I will post with results.
mjbach is offline   Reply With Quote
Old September 17th, 2005, 01:36   #37
wpeets
Fuel Economy: 38/39
Thanks for the help & pictures. I picked up 10,000 ohms resistors at Radio Shack they came in a packet of five for 99 cents. I installed one as shown and no more CEL I have been looking at that light for a couple of years and really got use to it. Now I feel like something is missing. Engine fires up immediatly and always has since the switch was installed. Saves a lot of wear and tear on the starter.
wpeets is offline   Reply With Quote
Old September 18th, 2005, 17:26   #38
mjbach
TDI(s): 99.5 Golf
Fuel Economy: 45-50
Mod is done and so far everything is great. Thanks again.
Old October 1st, 2005, 19:15   #39
kingeeyore
TDI(s): 1999
Hi all...thanks a lot for this work-around. I totally agree with the fix, its just not worth it to keep fiddling with this darn hot start problem.
Just one question....is anyone positive it is the #3 connector? The only reason I question this is because of the photos above look like the sitch/resistor is going to the #2 connector. And, Hamman's description (upper right side of connector from drives perspective) would correspond to connector #2.
I could be totally missing something here so some re-assurance would be nice.
Thanks.
kingeeyore is offline   Reply With Quote
Old August 23rd, 2007, 06:36   #40
Hamman
Hamman's Avatar
bumping
Old September 18th, 2007, 15:25   #41
ducatipaso
Airhead Butcher
Fuel Economy: 50 / 42 / 29
I am seriously going to have to consider this mod. My starting issues are driving me crazy.
03 330cic : 87 Paso 750 : 82 R80 : 82 caddy : 71 914
ducatipaso is offline   Reply With Quote
Old October 15th, 2007, 08:53   #42
Pic
TDI(s): 99.5
I'm also having this problem, but the cause seems to be diffrent.
The tests revealed only .5 volts going to my glow plugs, instead of the required 12v. They traced it back, for whatever reason, there is 12 v going into the computer, but coming out to the relay, which in turn sends voltage to the glow plug, only .5 v comes out of the computer.
So, going to see a diesel guru tonight, in hopes he can figure out the problem.
Pic is offline   Reply With Quote
Old October 15th, 2007, 11:23   #43
LNXGUY
LNXGUY's Avatar
I doubt the glowplugs have anything to do with it, the car would be well above 40degree', the glowplugs wouldn't even cycle.
Bill
LNXGUY is offline   Reply With Quote
Old October 15th, 2007, 15:58   #44
ducatipaso
Airhead Butcher
I replaced my glow harness, my plugs and even adapted so they run longer. Starts *somewhat* easier, but not always.
It's also kinda random. Sometimes it's fine sometimes it not.
I'm starting to think some form of IP seal or siphon activity happening.
Old October 16th, 2007, 05:39   #45
LNXGUY
LNXGUY's Avatar
Ducati: I hope you know this, but the 99.5 cars are plagued with hotstart problems because of the code within the ECU. There is nothing that is going to fix it. A fresh battery and good starter will help, but you'll never get rid of the problem....
The only way I have found to get rid of this, was with a Rocketchip upgrade. Jeff starts out with the Euro code, which doesn't contain this problem. Something to do with 8bit start code, compared to 16bit in the Euro (I dunno, Jeff could explain better )
Bill
Page generated in 0.17317 seconds with 9 queries
[Output: 119.18 Kb. compressed to 98.57 Kb. by saving 20.62 Kb. (17.30%)]
