Old November 9th, 2006, 06:42   #61
jollyGreenGiant
jollyGreenGiant's Avatar
Actually they put out OK light the problem really occurs when one leaves them on. They get all melty and the glass goes klink...
jollyGreenGiant is offline   Reply With Quote
Old November 9th, 2006, 18:19   #62
Warthog
TDI(s): see Bio
Fuel Economy: VW:49-53 depends on car, 40-0n the B5
"emiata" is a Chinese after-market parts supplier. They represent themselves as making a lot of replacement parts...quality unknown.
Warthog is offline   Reply With Quote
Old November 9th, 2006, 18:35   #63
Ray_G
Ray_G's Avatar
TDI(s): 98 Jetta TDI
I believe also ebayer Prothe. Has the same pump for the same price there.
06 E320 CDI Benz
98 Jetta TDI 94 F250 Powerstroke 76 911s
Ultimate cup holder for B4's Dimensions for A3/B4 and A4 timing belt tools Injection pump head how-to
Ray_G is offline   Reply With Quote
Old November 14th, 2006, 11:11   #64
rallymerkur
TDI(s): 96 Passat
Originally Posted by runonbeer
That ain't no hex head boy!
required tool
try a search for "pump leak fix" or the like. its been done and documented before.
So is there anything else special about that bolt, other then the head? Could someone just slot the head, remove the bolt and replace it with something conventional?
rallymerkur is offline   Reply With Quote
Old November 15th, 2006, 11:07   #65
Warthog
TDI(s): see Bio
That HAS been done. It was mentioned in another post about leaky diesel fuel pump repait. They used a Dremel tool and cut a lot that a screwdriver would fit into tightly. Tightly, since the screws are pretty tight and you don't want to bugger the head when you try to undo it.
Bosch only did this to keep us out of the pump. Old pumps don't have this screw with special head.
Old November 15th, 2006, 11:48   #66
Ray_G
Ray_G's Avatar
I have also seen something about just driving a 1/4 inch socket on it with a hammer. I have the special tool, so don't know the size socket to use.
Ray
06 E320 CDI Benz
Old December 6th, 2006, 22:34   #67
mjanney
Thanks for the help, I replaced both seals, very easy to do with the instructions in this thread. The hammer mod was a bit tricky for me, because every time I tightened the bolts (clockwise motion pushed pump toward passenger side), the IP number would drop, so I set it high around 8 then tightened and ended up between 4 and 5, just where I wanted to be.
mjanney is offline   Reply With Quote
Old December 6th, 2006, 22:35   #68
mjanney
Sorry I meant clockwise pushed pump toward driver side and reduced the IQ number
Old December 19th, 2006, 13:23   #69
rallymerkur
TDI(s): 96 Passat
Ray
Figured it out (I measured the three flat sides of the bolt head), it's a 7mm 1/4" drive socket with three sides rounded. I went to the pawn shop and bought several 7mm sockets for trial and error and used a flexable shaft grinder with a small stone to modify three sides of the socket. Got it right the first time and fits like OEM. I'll have to post pictures. Total cost was $.50 and 3 minutes of my time.
Old December 30th, 2006, 18:13   #70
lupin..the..3rd
lupin..the..3rd's Avatar
Yay! Just replaced the middle and upper seal in my IP today. Installed a new fuel temp sensor while I was in there too. Replaced all the copper crush washers too using the Bosch kit.
First time I sealed it back up, vag-com was reporting bizzaro iq amounts. hopping around between 0.2 and 1.2. Engine ran rough and sputtery. I took off the top half of the pump again, looked around, all looked good, so I put it back together. Started it again and had a smooth idle with iq of 1.8. hurray! so a few whacks of the mallet and I was up at 3.4. Perfect. Tightened everything down, went for a test drive, and measured again. 3.6 at NOT. Doesn't get much better than that!
I used the metalnerd IP socket, a Panasonic Toughbook running latest VAG-COM version and Hex-Com cable, and a complete ip reseal kit from bosch.
lupin..the..3rd is offline   Reply With Quote
Old January 3rd, 2007, 20:52   #71
Howler
Hey folks. my leaky pump is about to be replaced with a 100K mile used one from L and T enterprizes. I am also replacing the 3-way coolant hose, and will be ordering injectors. I have VAGcom, cam plate, locking pin and regular tools. After this is done, I will probably be selling my leaky pump for a rebuild.
Can you recommend any other helpful tools or parts I might need? Looks like I need a gear puller and some other Harbor Freight tools.
2010 Touareg TDI 3L
Howler is offline   Reply With Quote
Old January 4th, 2007, 06:33   #72
jollyGreenGiant
24mm and 7mm ( i think ) wrench for the fuel stop solenoid, floor jack or top-side engine support ( assuming this is for an A4 engine, not needed for the B4 ). Gear puller not needed for the B4 either ( you can use a drift from behind ), just the A4 and the Metalnerd one is really the absolute best one for this. Other than that just a good set of hand tools. Oh, a Mityvac or equivalent too.
For the injectors, if they're really stubborn you might need an injector puller available from Metalnerd.
Sent you an IM about that old pump...
This is just like
Old January 5th, 2007, 06:22   #73
marvins_dad
Fuel Economy: 38
At 72k it appears that I have a failed middle seal.
Read through this and a couple other threads as well as a few How-To's, ordered the kit and the tool....
The only thing I am concerned about is the Hammer mod...not so much the hammer mod and direction and such, but the Vag-Com portion of it.
Are there any screen shots anywhere that show what I am supposed to be looking at?
I entered 08Engine...then 000 and it gives me the 7 boxes...am I supposed to be looking at box#4? That is the only thing I could get out of the Vag-Com site.
Also, I am unclear if the engine should be running or not. Can it be done both ways?
Doing this on Sunday and would really like some feedback if possible.
Check out Marvin's Website
marvins_dad is offline   Reply With Quote
Old January 5th, 2007, 06:43   #74
whitedog
Marvin, in case I wasn't clear before, just take a scribe and scribe through that yellow paint and line up the marks when done. Then check and do the tap-tap.
Old January 5th, 2007, 10:38   #75
marvins_dad
Fuel Economy: 38
Got the scribing thing, but the Vag Com element to fine tune it and check for exact alignment is what I am unclear of.
Page generated in 0.25816 seconds with 9 queries
[Output: 122.89 Kb. compressed to 101.97 Kb. by saving 20.93 Kb. (17.03%)]
