Old September 24th, 2006, 21:46   #46
Bugger
Bugger's Avatar
Fuel Economy: 38
The return line your talking about. Is it the one on the fuel filter that is held on with the clip?
Thank you. Ken
Bugger is offline   Reply With Quote
Old September 25th, 2006, 04:26   #47
OilBurnerDE
Thank you. Ken
I believe so. On my 97 Passat fuel filter, the feed line come out of the right metal elbow port on the fuel filter. My feed line is clear, so you can see when fuel is being sucked through it.
The return line is connected to the plastic (check-valve?), I just removed it from the front side of the valve, hooked the pump to the rubber line and then covered the open port on the valve with my finger and started pumping.
That is what worked for me.
Eric
10 CC 4motion...
97 Passat TDI
90 Corrado Stage IV. 25 yrs and counting...
OilBurnerDE is offline   Reply With Quote
Old October 27th, 2006, 13:55   #48
Warthog
TDI(s): see Bio
Fuel Economy: VW:49-53 depends on car, 40-0n the B5
HI! No part number, but I'm talking to a Bosch shop at the moment. My 96 Passat pump started leaking, too, aboout 2.5-3 months ago. The shop reports they have been overwhelmed with diesel pump repairs recently. they say it's because the diesel fuel is different. I live in SC, and we don't have bio-diesel, but there is something going on to be sure! they say is because just recently, more sulfur is being taken out of the fuel and that creates a problem.
I'd planned to take the pump to them for rebuilding but they cannot do it because it has the electronic interface!
The nearest shop for me is about 250 miles away.
That ain't too good news!
Warthog is offline   Reply With Quote
Old October 27th, 2006, 14:54   #49
Warthog
TDI(s): see Bio
Just finished reading the illustrated instruction on replacing the top and "middle" seals...great article and the pictures are too good!
One thing I discovered about starting a dry pump...refill the pump thru the return line. Disconnect the return line at the filter, and use a tiny funnel or some sort of squirt-bottle with the nozzle modified to fit the fuel line. (You can't refill thru the intake line as it is controlled by the fuel shut-off solenoid valve.)
This trick works good enough that you don't (1) operate the pump dry at first, and (2) you don't grind away on the starter:it starts pretty quick!
PS. Nearby shop won't sell BOSCH "special" tools, either!
Old October 28th, 2006, 08:48   #50
Ray_G
Ray_G's Avatar
TDI(s): 98 Jetta TDI
I did a how to for the pump head (when the guts fall out..) If anyone gets a chance and look it over. I was in a hurry to get out of here today, so if you see something that is not right please let me know and I will correct it.
Ray
VE Pump head VE Parts illustration
06 E320 CDI Benz
98 Jetta TDI 94 F250 Powerstroke 76 911s
Ultimate cup holder for B4's Dimensions for A3/B4 and A4 timing belt tools Injection pump head how-to
Ray_G is offline   Reply With Quote
Old October 28th, 2006, 12:17   #51
jollyGreenGiant
jollyGreenGiant's Avatar
Wow, Ray_G, good job... BTW Wypij sent me an IM with the URL of a seller for 11mm pump heads fairly cheap... Don't know anything about the seller or the parts quality... (prothe link removed)
I'm having what appears might be a problem with my modulating piston getting hung up, I've been looking for some inside shots of the pump head assembly and you delivered!
BTW: anyone in MA who needs help with a leaking IP can get in touch with me and I'd be glad to help them out.
jollyGreenGiant is offline   Reply With Quote
Old October 28th, 2006, 12:35   #52
Warthog
TDI(s): see Bio
I'm on-line again to announce that I'm going to order parts and special tool from Metalnerd, and go for it!
Since I was successful in removing and replacing the 80-90 VWdiesels' fuel pumps w/o "special" tools, and having the cars run fine afterwards, I feel I can make a go of this too. I'll be using the instructions from a few posts earlier as a guide!
My pump has 990 as the last digits...the parts list shown
at the end of the instruction is a 985...anyone know if the 2 seals are any different?
Old October 28th, 2006, 13:39   #53
Ray_G
Ray_G's Avatar
Nice link on the 11mm pump head. hmmmmmm might have to think about that one. Thanks,
Ray
06 E320 CDI Benz
Old November 8th, 2006, 12:11   #54
rallymerkur
TDI(s): 96 Passat
I've e-mailed that site and not gotten any responce back. The prices look good, but I'm still new to TDI's so what do I know.
rallymerkur is offline   Reply With Quote
Old November 8th, 2006, 14:01   #55
Ray_G
Ray_G's Avatar
I just emailed them today as well, I wanted to know if the pump head they are selling is Bosch or aftermarket, and if aftermarket where is it made. They also sell new TDI nozzles that are 99.00. Kinda sounds like Chinese made nozzles to me. I just wonder about the pump heads as well.
Ray
06 E320 CDI Benz
Old November 8th, 2006, 14:04   #56
Ray_G
Ray_G's Avatar
The just responded to my email. They told me that the pump heads are made by CHJ which means nothing to me.
Ray
06 E320 CDI Benz
Old November 8th, 2006, 14:12   #57
P2B
P2B's Avatar
CHJ is chinahanji.com
Jettas for 29 years, TDIs for 13.
2003 Silver Jetta TDI GLS 220K PP520 RC3 6-Speed ERF
2003 Silver Jetta TDI Wagon 180K PP520 RC2
2000 Canyon Red Jetta TDI GLS 300K
P2B is offline   Reply With Quote
Old November 8th, 2006, 14:16   #58
Ray_G
Ray_G's Avatar
P2B, Yeah, I went on google spree and found pretty much the same thing. Chinese made.
Ray
06 E320 CDI Benz
Old November 8th, 2006, 18:11   #59
jollyGreenGiant
I wonder if these work better than the $25 B4 foglights...
Old November 8th, 2006, 18:27   #60
Ray_G
Ray_G's Avatar
Hey, those 25.00 dollar fog lights work great until you turn them on!
Ray
06 E320 CDI Benz
Page generated in 0.15983 seconds with 9 queries
[Output: 126.90 Kb. compressed to 104.96 Kb. by saving 21.94 Kb. (17.29%)]
