Old November 16th, 2005, 10:18   #16
dieselherb
Fuel Economy: 52,48, 46
Default seal#
I believe the bottom seal is the same as the top seal, it is in the kit I got.
dieselherb is offline   Reply With Quote
Old November 16th, 2005, 21:25   #17
jsanch
TDI(s): 1996 Passat
Bottom seal looks different in the kit I got
jsanch is offline   Reply With Quote
Old November 17th, 2005, 06:40   #18
John Beyer
The lower seal PN. is 2 460 206 009. The upper is 2 461 015 008. Both are in kit 2 467 010 003.
I have an exploded view of the pump with part numbers. Email me and I'll send it to anyone that wants it.
'98 Jetta TDI/GT,180k
'98 Jetta TDI,340k
'96 Passat TDI Wgn,358k (Brother's now)
'03 Jetta TDI,276k
'96 Jetta Gas,125k (Auto to Man Conv)
John Beyer is offline   Reply With Quote
Old December 1st, 2005, 15:37   #19
bowlerman
where are you getting these seal kits for the IP's? i dont know where to get one and turbo kits too? thanks
bowlerman is offline   Reply With Quote
Old December 5th, 2005, 06:26   #20
John Beyer
I got a kit from a local diesel engine repair shop (R&R Engine 330-724-5526). They work on everything from VW pumps to semis. Find someting like that or a Bosch shop.
'98 Jetta TDI,340k
'03 Jetta TDI,276k
Old March 25th, 2006, 16:19   #21
redtdi966
OK my pump may be leaking from the cover also, but it appears to be leaking form a ?? 13mm bolt, in the side of the pump between the pump and the block. The following pix shows a red arrow the points to where the bolt is. The bolt head is just below the cover where the arrow is(yes I borrowed the pix).
Also can someone provide a web site/phone # and kit number from a PO. Found this in another post, will try it.
H. G. Makelin Co., 714-978-0071, sells:
Bosch seal kit PN: 2-467-010-003-000.
Bosch socket (for special bolt head) PN: 0-986-612-605. Metalnerd's version is cheaper.
I need to order a cover gasket..., drive shafts seals and the seal the ?? 13 mm bolt.
Also if I remove the bolt does my pump self-destruct!
bruce
2003 jetta wagon 4-cyl , 2012 jetta sedan auto gassers -- Done with diesels "cost of ownership"
redtdi966 is offline   Reply With Quote
Old March 31st, 2006, 19:37   #22
redtdi966
Is there a seal that fits on the input shaft behind the pump pulley on the input shaft and case? My rabbit had one and I replaced that when it leaked.
The cover seal - gasket is 3.50 from worldimpex
http://www.worldimpex.com/search_by_...0717A&x=18&y=9
bruce
Old April 1st, 2006, 06:12   #23
John Beyer
The input shaft seal PN. is 2 460 283 001.
I think there is a seal for that bolt. PN. 1 460 105 307 and it's in the kit I mentioned. 2 467 010 003.
'98 Jetta TDI,340k
'03 Jetta TDI,276k
Old April 1st, 2006, 08:21   #24
redtdi966
cover seal, $3.52
http://worldimpex.com/search_by_part...0717a&x=11&y=2
!!!!!!!! This was wrong part for my car !!!!!!!!!!
\The seal I need is on right, the one I ordered and rec is on left.
http://home.att.net/~acr400/two_seals.JPG
bruce
Old April 15th, 2006, 06:42   #25
redtdi966
~two weeks later:
Ok 98 jetta (tdi), went to VW they ordered both seals that were listed for this car.
First attempt: wrong > 028 130 717 A
Second attempt: wrong > 068 198 051 A (contained a number of seals) not for my pump
Third attempt: going to VW tomorrow with my collection of seals 4/15/06
Forth attempt: I ordered a "kit" from local bosch jobber with the numbers in the post back a bit. He said about 40$, I'm hoping it has some cross referencing gaskets for different pumps.
bruce
Old April 27th, 2006, 05:39   #26
redtdi966
Ok got proper seal + whole kit (2.52 + 18 + 14 shipping, Mack Boring in Springfield/Union NJ).
When I assembled the lower cover there is a hanging pendulum arm that seems to fit into a sliding circular thick washer with a hole in it.
1- I assume that the hanging arm needs to fit in the hole, true?
2- It is not possible to see the final allignment, I think that I have it but you never know. Car starts and idles, I did not get to setting the pump volume with the Hammer. Just wanted to check on this issue before I run it too long
3- would car run if I did not have proper allignment?
BRuce
bruce
Old June 9th, 2006, 15:24   #27
kurtzl
TDI(s): 98 Jetta
I replaced my injector pump seals last week, many thanks to redtdi966, kneebull, & Audi5000TDI. I have just a couple things to add, that might be of some value.
As mentioned in the HOW-TO for replacing the pump seals, be sure and inspect the coolant hoses below the pump. One of mine was in desparate need of replacement:
In reading some other posts, this seems to be the hose that is most frequently compromised by leaks from the injector pump. It's a 3-way hose that goes between the water pump, head, and oil cooler. If yours is damaged, the replacement hose is part # 028 121 053 Q. $20 from www.autohausaz.com (look here) or $90+ from the dealer .
Here's a picture of the parts included in Bosch Kit 2 467 010 003-000. You can see the difference between the top cover seal (right), and the quantity adjuster seal (left). The kit should be available from your local Bosch dealer for ~$18. Be sure you're getting the correct kit - the Bosch dealer initially told me i needed kit DGK-126, but that kit only has one of the 2 seals!
Also, be aware that diesel may wash away the ink you use to mark the position of the quantity adjuster. Redtdi966 warned about this, and i used a sharp scribe to mark the pump/quantity adjuster in several places before taking it apart. I also used a black Sharpie to mark the lower left corner (as described in the HOW-TO) but the diesel washed part of that mark away. If you use a scribe to mark the pump, be sure you're looking from the same angle when you go to line up the marks again - the position can be deceiving if you're looking from the side.
One thing i should have done differently - before taking the pump apart, disconnect the fuel lines at the fuel filter, and use your MityVac to pump fuel OUT of the injector pump body. I didn't, and when i opened the pump, i ended up spilling diesel all over the coolant hose i had just replaced .
I didn't have the torque specs for the cover/QA bolts, so i put them back on by "feel" - does anyone know what the torque for those bolts should be?
One week & 500+ miles later, all's well - not even the tiniest drip.
Good luck!
kurtzl is offline   Reply With Quote
Old July 13th, 2006, 09:21   #28
jollyGreenGiant
jollyGreenGiant's Avatar
Picked up a "DGK-126" kit, was totally useless. It only had one seal that looked remotely close to fitting and in the end it didn't. I did however have them check into the top seal because at the time I assumed that the bottom one in the DGK-126 kit was going to fit. The "top seal" that they ordered ended up fitting the bottom quantity adjuster portion of the pump. I squeezed the other seal in the kit into the top cover ( I trimmed the little nubs off ) and it actually is sealing until I get the correct one from VW ( 028 130 717A ). Took a little hammering back and forth till I got the IQ exactly right.
In summary, the two correct part numbers needed for the two most common seals are as follows:
Bottom: 2 460 206 009-000 - No VW equivalent?
Top: 2 461 015 008-000 - 028 130 717A
DGk-126 Kit - Useless unless you want the copper washers and other assorted o-rings and stuff...
FWIW- Boston Fuel Injection in Chelsea got the parts for me, they were real good about everything but they did get it wrong and weren't able to find the 2 467 010 003 kit everyone talks about...
BTW - I wish I just checked Dieselgeeks site first, would have saved me some hassle...
http://www.dieselgeek.com/Categories...=TDI+Injection
jollyGreenGiant is offline   Reply With Quote
Old July 27th, 2006, 04:06   #29
ninedee_golf_tdi
Impex has the top gasket for $2.62, but do not have the kit nor bottom gasket. John did say he would try to get some kits in stock.
DG has both top and bottom gasket for $9.00 a piece.
ninedee_golf_tdi is offline   Reply With Quote
Old July 31st, 2006, 17:39   #30
gotchatdi
gotchatdi's Avatar
Fuel Economy: 46-56
Also don't use lucas fuel injector cleaner it says on the bottle for diesel but I started using it and my injector started leaking. Just giving you guys a heads up.
gotchatdi is offline   Reply With Quote
Page generated in 0.17564 seconds with 9 queries
[Output: 125.67 Kb. compressed to 104.63 Kb. by saving 21.05 Kb. (16.75%)]
