Old August 26th, 2005, 18:16   #1
TDI001
Fuel Economy: 43/47/58
Default Help ! Injector Pump Seal Leaks
Hi. I've been noticing some diesel seeping through between the top cover of my injector pump on a 96 TDI passat. The cover is held down with 3 torx bits and hex bolt. My car runs fine with no smoke despite the loss of fuel.
1.Can I just replace the seal myself?
2.Where can I buy the seal? Can I use these for a quick fix?
Thanks for any comment.
TDI001 is offline   Reply With Quote
Old August 26th, 2005, 18:51   #2
TDI001
Default a pic showing where it leaks
Old August 26th, 2005, 19:56   #3
latitude500
Fuel Economy: 51/45/39
I did a search and found this.
http://forums.tdiclub.com/showflat.php?C...rue#Post1030985
latitude500 is offline   Reply With Quote
Old August 26th, 2005, 19:59   #4
runonbeer
Maintenance EnthusiastVendor
Fuel Economy: amazing/excellent/still pretty good
That ain't no hex head boy!
required tool
try a search for "pump leak fix" or the like. its been done and documented before.
runonbeer is offline   Reply With Quote
Old August 26th, 2005, 20:27   #5
whitedog
required tool
And be sure to wear eye protection like the Lawyer label says on that tool.
Old August 26th, 2005, 20:40   #6
Rickstah
Rickstah's Avatar
Fuel Economy: 49/45/41
required tool
HEY SPEAKING OF BOY!!!! How's it goin, boy??? long time not talk...hope all is well for you, Robbie.
Rickstah is offline   Reply With Quote
Old August 26th, 2005, 23:12   #7
runonbeer
All's well. Tell your wife I just got myself a fiddle. as a matter of fact 5 minutes ago I was running through the Gmajor scale. I suck!
Old August 27th, 2005, 09:22   #8
whitedog
Something that no one answered:
Those sealants would not fix your leak unless you opened up the top. smearing it on the outside may cover it for a bit, but the fuel will still be leaking past the joint. I would not put it in place of or in addition to the seal that is there. With that kind of stuff, the excess will squeeze out from the joint and get into the inside of the pump. It won't become a wear material since it is soft, but it does have the ability to plug things and, depending on which one you use, it may cause problems with the fuel.
Better to just drop the dime and get a new seal.
Old August 27th, 2005, 12:04   #9
Audi5000TDI
Banned
Fuel Economy: 44,51, 59.08 mpg
Default Re: Help ! Injector Pump Seal Leaks
Newbie,
1st things first.
Forget about owning a diesel if you are going to do things half assed or do "patch" jobs. The level of pressure and the tolerances make injector pumps quite unforgiving of shade tree mechanic tricks.
Secondly, if you don't have the wherewithall to handle a red dipstick tube top breaking while doing your own oil change, and figuring out how to handle that, forget about even turning a wrench on your injector pump. Get someone that's a mechanic to do it for you, I doubt you have the skill sets, especially when you can't even notice the special bolt head on your injector pump.
Find a good TDI mechanic in your area and don't ever piss him off, because you are going to need his services regularly with that 1996 Passat.
If you still feel up to tackling it, read this carefully and read it a full 5 times before you attempt it.
http://forums.tdiclub.com/showflat.p...art=2&amp;vc=1
If that doesn't work, try this, it's on page of of this post.
http://forums.tdiclub.com/showflat.p...;page=0#713742
and if that doesn't work, go do a search under Audi5000td and then search for a post dated June 02, 2005, around 7:20pm. Then start at the beginning of the thread and read it all the way through, several times.
Audi5000TDI is offline   Reply With Quote
Old August 27th, 2005, 16:52   #10
Audi5000TDI
Banned
Moderator,
Could you please make a"sticky" out of this "how to" in this column or the other one?
Thanks!
Old August 27th, 2005, 18:10   #11
whitedog
Moderator,
Thanks!
Either I suck, or it's a really short topic:
Old August 29th, 2005, 07:44   #12
BKmetz
Administrator, Member #10
BKmetz's Avatar
Fuel Economy: 50 MPG
Moderator, can we make this post a "Sticky" since it comes up so frequently?
Done.
BKmetz is offline   Reply With Quote
Old September 1st, 2005, 19:21   #13
BKmetz
BKmetz's Avatar
Here are the VW and Bosch part numbers for anyone else who has to change out the TOP fuel pump cover gasket/seal.
Old November 2nd, 2005, 20:13   #14
jsanch
TDI(s): 1996 Passat
Default Re: a pic showing where it leaks
Here's a kit I got but have not installed it yet
jsanch is offline   Reply With Quote
Old November 8th, 2005, 07:31   #15
wooddashman
Any one have a VW part number for the lower seal?
wooddashman is offline   Reply With Quote
Page generated in 0.15926 seconds with 9 queries
[Output: 120.30 Kb. compressed to 100.15 Kb. by saving 20.15 Kb. (16.75%)]
