TDI Power Enhancements Discussions about increasing the power of your TDI engine. i.e. chips, injectors, powerboxes, clutches, etc. Handling, suspensions, wheels, type discussion should be put into the "Upgrades (non TDI Engine related)" forum. Non TDI vehicle related postings will be moved or removed. Please note the Performance Disclaimer. |
August 5th, 2005, 09:10
#2
Re: Diesel Purge and Cleaning the Injector pump
When was the last time you had a new filter put on, if you do not know put a new one on and while your at it fill the filter half with diesel and half with the cleaner then replace the new filter.....standadines as good as any.
August 5th, 2005, 09:12
#3
Fuel Economy: 13.7 c, 12-15 towing hwy. 17-19
Lubromoly diesel purge. Do a search on how to do it. But the short answer is clip the plastic spout off the can once you open it. (you might want to put the contents in another container while doing this.) remove the fuel lines from the filter and insert both into the can. Wedge between the intercooler pipe and the washer bottle with a towel. Run the engine at varying RPM's until the can is empty. About 20 minutes. It will help a great deal.
August 5th, 2005, 09:37
#4
tdiparts.com sells diesel purge and i think it comes with a kit so you can hook it right up to the hose (not sure if it comes with a kit but basically you want that to go in directly to the pump )
