Old August 4th, 2005, 11:28   #1
shakerattlensoot
Fuel Economy: 42/37/35
Default where is cooling fan relay
where is the cooling fan relay located. Fans will not come on.
shakerattlensoot is offline   Reply With Quote
Old August 8th, 2005, 07:45   #2
Wingnut
Wingnut's Avatar
Fuel Economy: 4.5L/100km
Under the battery tray. It looks like this (mine is unbolted from its location so I could take the picture):
If the fans are not working, you can disconnect the plug that attaches to the radiator and jump 2 of the wires to bypass the relay. That way you can test to see if the fans work or not. If they work, test the sensor in the rad. I'm not sure what the ohm range should be as I don't have my bentleys with me. Maybe someone else can chime in with that info. Also, don't forget to check the fuses. The center fuse under the battery cover is for the fans.
Good luck.
Wingnut is offline   Reply With Quote
Old August 14th, 2005, 21:04   #3
GTDI4
Fuel Economy: 53/?/48
Does the A/C work? With the A/C on The fans should work.If they don't come on it's the control module. As in the pic part #1J0 919 506 N ( VW ). If the fans work with the A/C on then don't fot get to check #16 fuse in the car and the fuses on top of the batt.- S164 and S180
let me know if that helps before going farther
GTDI4 is offline   Reply With Quote
Old September 14th, 2005, 17:32   #4
pmkg
I'm having a problem with my 2000 beetle did timing belt yesterday. Runs great but when I turn the key on the radiator cooling fans cycle on and off and this 506 relay clicks on and off I also do not have any a/c which was fine before the tb. When driving at night when the fan goes on and off the lights dim slightly. Any ideas?
pmkg is offline   Reply With Quote
Page generated in 0.11723 seconds with 9 queries
[Output: 58.24 Kb. compressed to 51.89 Kb. by saving 6.35 Kb. (10.91%)]
