Old July 17th, 2005, 12:36   #1
keeders
Default Vag-com + Ford galaxy
Hi there,
Am relatively new to the forum but have been looking in to see whats been going on as I recently bought a 1998 Ford Galaxy tdi (AFN engine).
I have been having one or two power problems where I lose the turbo intermittently. Anyway, in looking at the Tdiclub site I think I have the problem figured and have cleaned the inlet manifold (seems to have helped but not fully solved the problem).
So, I know the VW guys have a thing called Vag-com to communicate with the ecu and herein lies my question. Can Vag-com be used on the Ford Galaxy or is there an equivalent system ?
I've scanned around the system and done some searches but I can't find this one ever having been asked before - I would be grateful for any responses.
Keeders
keeders is offline   Reply With Quote
Old July 17th, 2005, 23:48   #2
DPM
Fuel Economy: 38.5- 47 Forester, Citroen 55- 63
Default Re: Vag-com + Ford galaxy
Yes, VAG-COM is 100% for the Galaxy.
DPM is offline   Reply With Quote
Old July 18th, 2005, 15:18   #3
Sebastian
The Ford Galaxy is actually a VW Sharan or Seat Alhambra with different badges on it. All systems are diagnostic capable with VAG-COM, but only the VW engines (like the AFN) will work. The Ford engines won't.
Some of the #09 (central electronics) control modules may only work with VAG-COM 409.1 and above.
Sebastian is offline   Reply With Quote
Page generated in 0.12624 seconds with 9 queries
[Output: 52.26 Kb. compressed to 47.20 Kb. by saving 5.05 Kb. (9.67%)]
