Old June 5th, 2005, 08:38   #1
Ramjet
Default WIPER PROBLEMS ON JETTA
anyone experience slow and non functioning wipers on their Jettas? Mine is a 2000 TDI and the wipers will stop in the middle of the windshield and then slowly inch by inch finish the cycle. I often need to pull on the wiper arm to make them move. I'm thinking wiper motor needs replacing but who knows could be something else. Any feedback is greatly appreciated....Thanks
Ramjet is offline   Reply With Quote
Old June 5th, 2005, 08:58   #2
ymz
Fuel Economy: 5.3 l/100 km (at 115 km/h)
Your 2000 car is an A4... you posted in the A5 forum...
That said, most likely the shafts to which the wiper arms are attached have corroded inside their bushings... you need to take apart the mechanism (do a search on wiper seizing) and if you're lucky, you'll only need to "persuade" the shafts out and give them a good cleaning and lubrication... as well, the "joints" on the way from the motor to the arms may need the same treatment... This is common, but you'd better do it before the motor burns out...
Yuri.
ymz is offline   Reply With Quote
Old June 5th, 2005, 18:26   #3
Ramjet
Thanks for the info Yuri, thats exactly what the problem was, shaft on drivers side was so corroded I couldn't even move it by hand. Cleaned her all up, had to use the torch to heat up the housing in order to get the shaft out, but working good now....thanks a whole bunch..
Old June 29th, 2005, 05:21   #4
Gundalow
Fuel Economy: 47 avg 53 max
Default Re: WIPER PROBLEMS ON JETTA
99 a4 jetta 176,000mi now, Same symptoms yesterday.
Wipers went up and stopped. Then little fractional moves every now and then.
Will explore more on the weekend -- pray for no rain until
I can get at it.
Removed wiper fuse to hopefully save motor-- we'll see
Gundalow is offline   Reply With Quote
Old July 1st, 2005, 11:01   #5
A5JETTA
Rain-X applied properly before an expected rain can help; but the great aerodynamics hurts the effectiveness. It can help some, however, if your afraid of getting caught out in the rain w/o wipers.
A5JETTA is offline   Reply With Quote
Page generated in 0.13007 seconds with 9 queries
[Output: 61.70 Kb. compressed to 54.22 Kb. by saving 7.48 Kb. (12.12%)]
