Not sure if this is a performance topic of not. For the last few days I noticed that my golf with slight steady increase in pedal would yield 24-26psi. This is not at full throttle and I wasn't accelerating hard. Yesterday I got a 30psi spike. I call it a spike but its only because I let off the throttle.
To day as I left the gym. In third gear at slight thottle I could maintain 22psi. At this point the engine cut out a few times then went into limp mode. BTW limp mode proved to me that a vnt17 can allow the tdi to operate with less than 1psi. Need to get with Jeff and see if I can get a custom program that will allow for that low boost during normal driving MPG's!!!
The limp mode threw two codes: 17969 - Quantity Adjuster (N146): Control Deviation and 17965 - Charge Pressure Control: Positive Deviation.
EDITED Trouble shooting: cleared the codes. checked all hoses, vnt moves freely, cleaned both check valves, cleaned N75, replaced N75 with N18 (same part #, lengthened vnt rod, adjusted vnt stop for less boost and replaced the black/white check valvle. Took for a test drive. With ease the engine put out enough boost to put the gauge needle at the bottom.. I guess 35psi...
I was no were near full thottle. no codes thrown.
Also ran the car without the vnt vacuum line connected. No overboost. Lack of power and smoked.
UPDATE-------
Problem solved. I removed the EGR block off plate and stuck a small hose into the exaust manifold. I then sprayed a some seafoam small amounts at a time. I then applied vacuum and worked the VNT. Let this set for about 30mins. Started the car and watched the blue smoke boil out. Boost will jump right up to 22psi then hold.
http://www.seafoamsales.com/deepCreepConsumer.htm http://www.seafoamsales.com/deepCreepTech.htm
I used my old vnt15 as a test. I could see the hose reaching the center hole and sprayed alot of seafoam and NONE reached the exhuast ports. But I do recommend that the car be faced up hill. Let gravity help.
UPDATE-------
