Hello all!!!
INTRO (skippable)
I have a problem: My clutch just went toast. (dunno what failed) The clutch pedal started working harder and harder (it depressed very slowly) and I suspected problems with the hydraulic circuit but later during the day as I had to go back home it shortened the working trip of the pedal to about 1-2 mm then the whole clutch became noisy and harder and harder to engage a gear and there was noises coming from the clutch area at idle and when I pressed COMPLETELY the clutch I could feel a powerful knocking (repeat FEEL not only hear) in the clutch pedal... All in all something is toast in the clutch box.
I will have the car towed to my mechanic to take off the transmission and inspect the clutch. At minimum the release bearing is toast but probably the pressure plate is gone too.
I thought this is the best moment to upgrade my clutch disc and pressure plate to a VR6 kit.
MY QUESTION
Will a VR6 kit fit a 1Z engine? As I read (and I searched a lot) it will but this is an european 1Z from 1994 and the gearbox code is CTN not O2 or other. Plus there are 2 versions of VR6s here: AAA (engine code) and ... (another code).
Is the clutch disc and pressure plate dependent on what gearbox I have or is it irrelevant?
I will post part numbers from ETOS (ETKA like software) regarding pressure plates, clutch discs, release bearings and complete kits for 1Z, AAA and the other VR6 engine code.
Thank you for your time!
