Old April 2nd, 2005, 14:11   #1
durban97
Default Low brake pedal on Jetta
Hi ! I have a 2003 Jetta TDI, bought new. The brake pedal seems to have a lot of travel, although the brakes work very well. Mileage is 30,000. Checked the rear pads, about 3/16th of an inch left before metal. The front pads have a lot more pad area left.The rotors are fine as well, front and rear.
Brake fluid level is fine.
I believe its time for a brake fluid change and replacement of the rear pads.
Any comments would be appreciated.
Frank
durban97 is offline   Reply With Quote
Old April 2nd, 2005, 14:14   #2
dieseldorf
top post dawg
dieseldorf's Avatar
Default Re: Low brake pedal on Jetta
It's been my experience that these cars have long pedal travel, not to be confused with a soft pedal. Since your pads are nearing replacement, you be noticing it even more.
Have you done your (bi-annual) brake bleeding?
Old April 2nd, 2005, 16:24   #3
durban97
Not yet!
Will replace pads at the same time.
many thanks
Frank
Old April 2nd, 2005, 17:23   #4
pruzink
Fuel Economy: 42
I bought my daughter a 2001 Jetta 2 years ago. I was never happy with the brake pedal (just felt there was too much travel). When I bought it they installed all pads and rotors, it brought the pedal up some but still not to where it should be. I recently flushed the fluid thoroughly with absolutely no improvement in the pedal. When I bought the car I took out an extended warranty policy so I figured I would bring it in to have it checked out. The Dealer diagnosed the Master Cylinder as needing to be replaced. I feel much better knowing that as I have never been happy with the brakes on it.
pruzink is offline   Reply With Quote
Page generated in 0.13249 seconds with 9 queries
[Output: 57.47 Kb. compressed to 51.15 Kb. by saving 6.32 Kb. (11.00%)]
