| Upgrades (non TDI Engine related) The place of handling, lighting and other upgrades that do not relate to the performance or economy of the TDI engine. In other words upgrades to your TDI that don't fit into TDI Fuel Economy & TDI Engine Enhancements.Please note the Performance Disclaimer |
May 31st, 2008, 10:46
#106
Fuel Economy: Depend my Foot .. :)
u can hold the handbrake a little bit ..
for automatic it's a differant story ..
June 1st, 2008, 07:00
#107
Fuel Economy: 800km/1100km/tank
Something that was touched on, but not elaborated, is the issue of DRLs and using fogs. In order to make a fog light do it's job, you can NOT have the DRLs on (defeats the purpose of the fog lights). What I will eventually do on our A4 Variant is move the DRL supply down to the fog lights (located in lower valance), with the Euro fog switch over-riding the DRL input (isolated with a diode). In that way, I have the required (and usually desireable) reduced load DRLs, but no interfering light when on fog position (if you don't know why that matters, then you haven't driven in heavy snow).
A4=2003 TDI Variant, A3=Golf CL, A2=2x1.6 Jetta TDs, Golf Syncro Country, A1=Scirocco Mk1 & 16v, Audi 5000TD, Porsche 924/M471 and a bunch of diesel trucks.
June 11th, 2008, 23:45
#108
I did mine tonight. I did a beautiful job heat-shrinking the TFL pin, plugged it in and... still had DRLs. I unplugged the connector and found the heat shrink bunched up on the harness side.
I tried a couple more times and gave up. A wide flat flate screw driver made short work of laying the TFL pin over.
No more DRLs here. To make up for it I'll get on the 5-light mod soon  .
2006 Mercury Montego Premier (FWD, 6 Sp auto)
2002 VW Jetta GLS TDI - 5sp swap, VNT 17/22, Bosio PP764, SBC Stg2 Daily SMF Clutch, Malone Stg 5, DG RacePipe, EGT / Boost Gauge, Evo Atlas skid
January 17th, 2009, 15:15
#109
To start off, I have an '06 Jetta that has a busted drivers side low beam. I was gonna do fogs but now I'm thinking an HID upgrade would be money better spent.
So, from reading this thread I guess I need to use VAG-COM to disable my DRLs. And if my dealer refuses to do it, what options do I have? Find someone locally that has VAG-COM and pay them to do it? Any other ideas? What about installing a Euroswitch? Does that disable the DRLs in and of itself?
I really want a set of HIDs installed, but I know the DRLs and the decreased voltage are an issue. Ideas and experience is appreciated.
Thanks!
Save the polar ice caps...they taste great in margaritas!
2006 Jetta TDI-EGR delete, Malone Stage 1 (best tank: 700.4mi.)
2005 Suzuki Boulevard M50-fuel sipper#2, faster!
2011 Dodge Ram 2500 CTD-crawler hauler
1994 Jeep Wrangler-Rock Crawler
January 18th, 2009, 06:00
#110
Yep, finding someone with vag-com is about your only option.
Installing a Euroswitch is also a good idea, but you actually have to disable DRLs (or change to Scandinavian DRL mode) before the Euroswitch works right: the parking light-only mode gets overridden by the DRL mode.
2009 Jetta Sportwagen TDI, Grey, DSG, Pano Sunroof, OEM Foglights, Trailer Hitch, FrostHeater, Hella Projectors
January 21st, 2009, 12:09
#111
Fuel Economy: Best on Road was 53/48 in Town
No Female connection!
On my wife's 05 Beetle, I found there is no wire connection for the TFL pin to attach to....Is there another pin that should be taped?
January 21st, 2009, 13:42
#112
Fuel Economy: Worst ever 40.9 l/100km
Sometimes the wire is connected to the "B" pin, not the "TFL" pin.
I think some 3B Passats were connected that way for a while.
January 22nd, 2009, 18:46
#113
Pre-Forum Veteran Member
Fuel Economy: Which VW diesel? There have been Twelve of them!
Post quoted from the first page of this thread
Originally Posted by burningmoney97
Do not remove relay 173 to disable the DRLs! There is a lot of work involved to remove the relay, and you lose the hand brake warning light in the instrument cluster. The chances of damage to the wiring harness are also greater than if you follow the instructions below.
False, and nearly a lie. The presence of this misinformation on Fred's was brought to my attention by a poster asking on another thread why his handbrake warning lamp continues to work after he simply unplugged his DRL relay 173. Mine continues to work too.
The reason is because the warning lamp for the handbrake being engaged is a parallel connection from the handbrake switch. The hand brake switch operates two circuits, one to turn on the red alert lamp in the dash, the other to turn off the power to the coil of the DRL relay.
Unplugging and removing the complete DRL relay does nothing to the handbrake alert lamp circuit.
Svante Arrhenius 1896
January 22nd, 2009, 19:01
#114
On mine, I just opened up the relay and put a piece of electrical tape in between the internal moving connections. The relay is still in place for any other items that may use it, but my drl's are disabled. I like it better that way. Mostly because you don't forget to turn on your headlights at night or in the fog.
Originally Posted by Lug_Nut
Post quoted from the first page of this threadFalse, and nearly a lie. The presence of this misinformation on Fred's was brought to my attention by a poster asking on another thread why his handbrake warning lamp continues to work after he simply unplugged his DRL relay 173. Mine continues to work too.
2002 Red New Beetle TDI, auto tranny.
Mods so far: Coolant migration mod, Ventectomy, Kerma line pressure mod, Euro headlight switch, Modded relay DRL disable, Nokian I3 205/55/16 tires for summer
I can't believe how much crap I can fit in this thing.
March 18th, 2009, 22:22
#115
Thanks...this is an easy mod.
There are no more pictures in the first post. Newbies or other less mechanically inclined may benefit from pics .
To add a small note to original poster's instructions:
Once you disconnect the wires (module) from the actual switch, turn the switch around, and you will see many metal pins protruding out. Some have numbers, some have letters. Choose the pin labeled " TFL" , and either bend it 90 deg , or tape it off.
Then reconnect the wire module to the switch...and push in and turn switch counterclockwise to install.
Takes only 2 minutes for first timer....even quicker once you know how.
THANKS.
2012 Jetta TDI- Premium Nav. My car now..
2002 Jetta TDI -RIP 6/15/12.
1999 Stillen Suburban, all custom supercharged.
2003 Jetta TDI wagon, 01M sold
2004 Corvette Z06 TwinTurbo, twin Bosch fuel inj 1145 horses. Sold
March 19th, 2009, 14:53
#116
Love this mod as it seems my jetta would go through headlight bulbs too often because they were always running with the drl's. I truly hated changing the headlight bulbs on this car! Err.
01 Jetta TDI 5 speed, Stock VNT-15 Turbo, 11mm IP, Evolution Skid Plate, TDIHeater, TT Bushings, Cold Weather Air Filter w/Snow Screen Deleted, CAT air filter restriction gauge, New South EGT & Boost Gauges w/Steering Column Pod, CAT Fuel Filter w/Nicktane Filter Head, 5 Light Brake Mod, Bosio PP520 nozzles, DG EGR & Cooler Deleted, Catalytic Deleted, Southbend Stage 3 Clutch (DMF version).
March 21st, 2009, 20:31
#117
Personally I simply cut the wire on the back side of the switch when i replaced it with a euro switch and soldered (yes soldered) on a set of male / femal connectors so if i for some reason want to DRL's again i just pop the switch out and connect the wire.
Personally I know DRL's are supposed to be a safety thing but i think they are over rated and simply burn out headlights even faster. Its also rather annoying because it seems there are a lot of people with DRL's in poor driving conditions that now forget to turn on their headlights because they can see fine, problem is their tail lights are not on so you cant see them till you are on top of them.
VW Jetta 2001 TDI
Vag-com
RCII : SBC stage 3
Shine suspension
June 7th, 2009, 15:09
#118
Fuel Economy: lifetime 46mpg
Thanks for the SAVE
Ony my wifes 06 TDI Beetle, it was def. Pin B, and the parking brake indicator still works!! Thanks, as everyone said it was the TFL pin even on newbug forums!! Hecho en Mexico, not EU version of Beetle
Cheers,
Riquo
Go TDI
June 7th, 2009, 15:51
#119
I forgot to add on my previous post about opening the relay up. My DRL's are disabled, but the light for my parking brake still comes on. Just in case anyone was interested.
June 7th, 2009, 19:18
#120
I totally agree with this! When it's really rainy and foggy here (all the time in BC), people don't turn their lights to "on" because they are used to having day time running lights. That make is SUPER unsafe because there are no tail lights anywhere...
About this whole thread. Why are people modifying the relays when they can just pull out the switch and unplug the cable going to TFL, then zap strap it back to the bunch of wires so it's not loose in the dash? 30 seconds and much easier to "undo".
Just my $0.02,
-Chris
