Old March 24th, 2005, 00:33   #1
onehotspud
onehotspud's Avatar
Fuel Economy: 59/45/36
Default DIY Dawes Device
I've made my own Dawes Device. I didn't want to wait for one to arrive in the mail. I'd post a picture, but my server isn't working right now. It looks and acts just like the Dawes Device at half the cost and one tenth the wait. Has anyone else done this?
onehotspud is offline   Reply With Quote
Old March 24th, 2005, 05:52   #2
Growler
Got Soot Vendor
Growler's Avatar
Default Re: DIY Dawes Device
please email pics/instructions to:
ibbruck(at)excite(dot)com I will post them for you.
you could also login to the picture server here and host them yourself.
I am sure others would love to see what you have done
Old March 24th, 2005, 06:05   #3
juli0s
Fuel Economy: 48/45/40
i just got my Dawes a few weeks ago,
my friend tells me its just a couple of plumbers fixings bolted together....
i'd be interested to see what you've used !
juli0s is offline   Reply With Quote
Old March 24th, 2005, 07:55   #4
onehotspud
onehotspud's Avatar
And, you're right. It's just some plumbing fittings. The relief valve is Grainger part #5Z763. The nipple fitting on the one end and the copper tubing were both from a mom & pop hardware store.
The problem with this is the nureled end. All that is there is a hole. I thought there might be threads to screw a fitting in to. There isn't. Thus the reason for the copper tubing. I found some that was just big enough to slide in tightly. I then used glue to seal things up.
***EDIT: The glue didn't hold that long. I ended up soldering the copper tubing in.
I'm not trying to take money away from the guy that's selling these or make anything off it. His website said 10-15 days to recieve the product. I don't want to baby my car for that long. My turbo vanes might get stuck by then.
Thank you to brucep for finding the part in this thread. I can't take credit for all the work.
Old March 24th, 2005, 09:51   #5
je
TDI(s): -
I made my own with plumbing fittings and a spring and ball from a surplus store. It took work to machine out the centre to fit the spring and provide a good seating surface for the ball (not a lot, but a lot of trial and error). It's also tricky to get a spring that works well, and to adjust the inside length of the barrel - but it does work, if not that well. If you're good at machining, it would be better.
je is offline   Reply With Quote
Old April 1st, 2007, 21:30   #6
onehotspud
onehotspud's Avatar
Updated a bit.
2001 Jetta TDI, Sprint 520s, RocketChip Stage III, G60 Flywheel & VR6 Clutch, Boost Gauge, DIY Boostvalve
Dieselgeek Shortshifter, Low Pixel Gasser MFA, VAG-COM (best tool & support ever), ECodes w/motors, SRP
ASR Retrofit.
A few steps closer to a CoolWht clone...
Old April 2nd, 2007, 20:48   #7
canadianveedub
TDI(s): 2002 Golf
Default my valve
These are some pics of my valve.
This one is an exploded view.
The parts are all from Home Depot except the ball bearing. The cap screw goes into a barbed fitting that I cut off and tapped to the correct size. After I had the parts it took 10 minutes to make. The ball bearings are from a bicycle shop (5/16 I think)
Exploded view:
Threaded fitting:
Ball bearing in seat:
Assembled view:
canadianveedub is offline   Reply With Quote
Old April 3rd, 2007, 05:44   #8
arvina
arvina's Avatar
Location: Brazoria (or as we call it, an hour south of houston), Texas
Fuel Economy: 42 min, 48 max
how much for all those parts?
2000 gl 141k
smoked bumper and side markers, PP764, 18" flik arctics, mufflerectomy, race pipe, more to come!!
arvina is offline   Reply With Quote
Old April 3rd, 2007, 17:20   #9
canadianveedub
TDI(s): 2002 Golf
Probably $10
Old August 5th, 2007, 20:13   #10
clintontull
clintontull's Avatar
TDI(s): NONE
i like the looks of this one!
KermaTDI is now on Facebook!
clintontull is offline   Reply With Quote
Old August 7th, 2007, 21:59   #11
fishjoe
how is it working?
fishjoe is offline   Reply With Quote
Old March 18th, 2008, 19:10   #12
Diesellover Andy
Fuel Economy: In metric about 6.2 to 6.6 L/100km.
Talking Fantastic valve!
This is it!Simply fantastic!
Diesellover Andy is offline   Reply With Quote
Old April 22nd, 2008, 00:40   #13
tequilaiam
tequilaiam's Avatar
TDI(s): 2000 NB
To bring this up again, I have a quick question:
Is this thing venting pressure from the intake (post turbo) into the vacuum line to the trubo actuator? I want to be sure before trying it.
tequilaiam is offline   Reply With Quote
Old April 22nd, 2008, 06:53   #14
Growler
Got Soot Vendor
Growler's Avatar
yes, it sends the extra boost pressure into the VNT actuator vacuum line between the N75 & the VNT POT to force the Vanes open inside the turbo, this reduces boost.
~Aaron~
Schmutz 2015 GSW S DSG
Schnurren 2001 Golf 2 door.
Old June 22nd, 2009, 13:00   #15
DynoJetta
DynoJetta's Avatar
Fuel Economy: best = 56, avg = 48 best tank= 765 miles
Hey Alex (canadiaveedub) could you post a list of the fitting sizes you used to make your MBC? A size list would greatly help searching through the countless bins. Thanks!
DynoJetta is offline   Reply With Quote
Page generated in 0.18445 seconds with 9 queries
[Output: 120.83 Kb. compressed to 99.93 Kb. by saving 20.90 Kb. (17.30%)]
