Go Back   TDIClub Forums > VW TDI Discussion Areas > General Automotive
General Automotive General automotive discussion. This is intended to be a discussion about other not VW and Diesel cars you may have or interested in.
Old March 5th, 2005, 23:40   #1
nicklockard
Torque Dorque
nicklockard's Avatar
Fuel Economy: No data yet.
Default Extending range in Battery Electric Vehicles (BEV)
The solution is not an alternative to chemical batteries. It is (recognizing!!!) and taking advantage of some of the unique properties of Lithium-ion polymer batteries and custom-engineering a packaging solution.
I should say I have this idea worked out to quite an extent, but have agonized over how to get it out. If I privately fund, some big company will devour me with legal fees (it happens all the time.) They'd just steal it outright and I could litigate to death. Anyway, this would fall under the category of a (chemical process) utility patent, and legal fees range from $50K-$100K. On top of that, international patent annual maintenance fees are hefty.
Worse, I was required to submit the patent outline at my former employer when I did an internship/fellowship there last two summers. They (Pacific Northwest National Labs(PNNL)) have first ownership rights, but...they do nothing, as there is little to no current interest in anything not directly or indirectly related to 'homeland security'.
So, I've debated just making a web page and releasing the idea to the world, ala: "open source." The original inspiration for it made me go back to college and get a science (chem) degree to learn enough to write the patent. I have zeroed in on what problems/issues remain to be solved, but lack R & D funding. Originally, there was much interest in the government for new battery technologies, but R&D funding for anything besides homeland security has all but dried up.
I'll say it's all a matter of packaging. I really want to get the idea out there, but don't know what to do.,. I'm conflicted. If I release it open source, probably the Chinese government will be all over it, and America would sit on its hands and lose out. It's such an elegantly simple solution. It LITERALLY stares us right in the face.
Thoughts?
nicklockard is offline   Reply With Quote
Old March 6th, 2005, 13:39   #2
uponblocks
First, as a caveat, I know virtually nothing about patent law. My understanding is you can file “pro se” for a filing fee of a few hundred dollars. If you inform the patent examiner that you are filing pro se, he is duty bound to assist you with his expertise. You will undoubtedly end up with a weaker patent, but it provides you access to the court for infringement. I think provisional patents are even cheaper. By international agreement, I believe you have a one year grace period to file internationally. Sure, someone may try to steal your idea. If only one company has interest in your idea, you are pretty exposed. But if there is a second big company with an interest, you have leverage, unless they all collude to screw you. Hopefully one will recognize the legitimacy of your patent and assist you in shutting out the others for exclusive licensing. If you want to make your idea public domain, you can use the statutory invention registration procedure to block others from patenting your invention and forcing you to pay them royalties for using your idea. Presumably you would quickly find out whether your idea has merit to justify the maintenance fees after one year.
uponblocks is offline   Reply With Quote
Page generated in 0.11987 seconds with 9 queries
[Output: 50.29 Kb. compressed to 46.41 Kb. by saving 3.88 Kb. (7.72%)]
